Zvetseni velikosti slozky PLUGINS
Zajímavosti a různé testy Azbox HD.
zbyneksk Czech Republic
Příspěvek od zbyneksk »
Par veceru jsem testoval vymeneny DOM za CF kartu v IDE adapteru. Pri tom jsem narazili na tuto relativne cerstvou informaci.
Predpokladam, ze vse je jasne. Kdyz tak si to strcte do prekladace: http://translate.google.com
Anglicky:
   Increase Capacity PLUGINS
    Hello from Spain.
    Before beginning, note that is ONLY for users who have upgraded DOM memory.
    I increased the capacity of all folders (you can put what you want to each but you should always leave a minimum available 100MB for /dev/hda4 /Download ):
    AZBox [~] $ df
    Filesystem Size Used Available Use% Mounted on
    /dev/mtdblock5 1.0M 432.0k 592.0k 42% /DISK1
    /dev/hda1 310.3M 112.2M 182.1M 38% /MMP
    /dev/hda2 310.3M 20.1m 274.1M 7% /PLUGINS
    /dev/hda3 62.4M 6.2M 53.0M 11% /DISK2
    /dev/hda4 1.2G 78.1M 1.0G 7% /Download
    First, you must have writting access to /DISK1/hdd_tools/partitions_hda.txt.
    Telnet:
    mount-o remount, rw-t ext3 /dev/mtdblock5 /DISK1
    With this you can change it.
    Modify 'partitions_hda.txt':
    , 140, L <----- This corresponds to /dev/hda1 /MMP in my case changed to ->, 320, L
    , 16, L <---- This corresponds to /dev/hda2 /PLUGINS ->, 320, L
    , 8, L <---- This corresponds to /dev/hda3 /DISK2 -> 64, L
    ,, L <---- and rest (2GB - 320MB - 320MB - 64MB > 100MB) goes to /dev/hda4 /download ->,, L
    Once changed, we save it and we go to telnet to finish writting permission:
    mount-o remount, ro-t ext3 /dev/mtdblock5 /DISK1
    Now, backup PLUGINS and channel list, click a USB with the firm we want to install and when prompted us first selected Format Application Area and then install the firm.
    When you restart after installation, you can see how capacity has increased.
    The modification in file 'partitions_hda.txt' isn't permanent, ie, installing the firm, leaving it again like before, with what you must do this each time you install a new firm.
    Best regards.
A jeste Spanelsky (par slov navic):
Aumentar capacidad carpeta PLUGINS
Hola a todos, antes de nada esto es un copy&paste de un mensaje que yo mismo he escrito en otro foro (y lo he pegado en otro y ahora lo pego en este, jejejeje).
El otro dia me decidi a cambiar el DOM de serie por uno de 2Gb para aumentar la capacidad y la velocidad de acceso, pero me encontré con que cuando la instalaba dejaba las carpetas exactamente igual en tamaño a excepcion de la carpeta download que me la dejaba con el resto.
Pues os comento como he aumentado la capacidad de todas las carpetas (podreis poner lo que querais a cada una de ellas):
AZBox[~]$ df
/dev/hda2 310.3M 20.1M 274.1M 7% /PLUGINS
Lo primero de todo es tener acceso de escritura al archivo /DISK1/hdd_tools/partitions_hda.txt que es donde aumentaremos la capacidad mas adelante. Para ello en telnet enviaremos:
mount -o remount,rw -t ext3 /dev/mtdblock5 /DISK1
Con esto ya podemos modificarlo.
El archivo partitions_hda.txt lleva:
,140,L <----- Este corresponde a /dev/hda1 /MMP en mi caso cambiado a --> ,320,L
,16,L <---- Este corresponde a /dev/hda2 /PLUGINS --> ,320,L
,8,L <---- Este corresponde a /dev/hda3 /DISK2 --> ,64,L
,,L <---- y lo que queda va a parar a /dev/hda4 /download --> ,,L
Una vez modificado, lo guardamos y nos vamos a telnet para finalizar el permiso de escritura, no sea q borremos algo accidentalmente y enviamos:
mount -o remount,ro -t ext3 /dev/mtdblock5 /DISK1
Ahora ya solo nos queda guardarnos los datos de PLUGINS y la lista de canales, pinchar un USB con el firm que queramos instalar y cuando nos lo pida seleccionamos primero Format Application Area (o algo así) y despues instalamos el firm.
Cuando se reinicie despues de la instalacion, ya podreis observar como ha aumentado la capacidad de las unidades a lo q hayais indicado.
Eso si, la modificación del archivo partitions_hda.txt no es permanente, es decir, al instalar el firm, lo vuelve a dejar como esta, con lo que tendreis q hacerlo cada vez q instaleis un firm nuevo.
Por cierto, esto es solo para los que hayais actualizado el DOM por otro de mayor tamaño o un HDD. Si no teneis mas memoria no lo modifiqueis, pues la si quitais espacio a la carpeta Download por probar si funciona, lo mas seguro q os quedeis con un deko muerto al no tener suficiente espacio para descomprimir el firm.
Bueno, no quiero enrrollarme mas. Espero q os sirva aun cuando no es q haya de momento mucha utilidad para necesitar mas memoria en PLUGINS (pero todo se andará).
Un saludo
Zpět na „Zajímavosti a různé testy Azbox HD“
