MultiCAS
Re: MultiCAS
Multicas MultiCAS v1.62E-C09D
- vikino
Re: MultiCAS
MultiCAS
-DATE : 2011/01/05
-Version : v1.62E-C10
FIX : Fixed AustriaSAT
MOD : Updated new_biss.key
ADD : Added support camdata and camkey from external txt file for Irdeto card (See the 'example-cardkeydata.txt')
-DATE : 2011/01/05
- vikino
Re: MultiCAS
MultiCAS-v162E-C11B
-DATE : 2011/01/24
-Version : v1.62E-C11B
FIX : Fixed small bug of ECM for Irdeto
-DATE : 2011/01/24
- vikino
Re: MultiCAS
MULTICAS v1.62E-C11D
MultiCAS
-DATE : 2011/02/08
-Version : v1.62E-C11D
FIX : Fixed minor bug about log-in part of Newcamd
FIX : Fixed about make to slow something by CCcam
MOD : More improvement about EMM for Cryptoworks Card
MultiCAS
-DATE : 2011/02/08
- vikino
Re: MultiCAS
MultiCAS
-DATE : 2011/02/17
-Version : v1.62E-D01
MOD : Update BISS key (see included new_biss.key)
FIX : Fixed bug for New HD+ card
-DATE : 2011/02/17
Re: MultiCAS
New Unofficial Multicas 1.62E-D0x
Whats New?
-Austria-Sat KeyFix ,ok!
Whats New?
Re: MultiCAS
MultiCAS-v162E-D01B
Azbox Cabo 11/03/2010
AZ Box Premium HD E2-Open RSI 3.0(cccam 2.3.0)+2xSG2100,Illusion M5, Sky link,T&T a celá Európa:-), LG 50PK350&Samsung LE32R71B
Re: MultiCAS
MultiCAS
-DATE : 2011/03/23
-Version : v1.62E-D01C
MOD : More improvement about Found Best Server for CCcam
ADD : Added mode 'CCCAM_NEWCAMD_WORK_TOGETHER = 2' it's using for Local Server Client + CCcam + Newcamd
-DATE : 2011/03/23
Re: MultiCAS
MultiCAS-v163
MOD : More improvement about NDZ card (Part of EMM and initialize)
ADD : Added BISS key (See include new_biss.key and below)
- Turner, Globecast feed (Cartoon Network Arabic) @ 13E
- Opap Tv (13.0°E)
- Monitor Games (13.0°E)
- CNN Turk (42.0°E) TURKSAT 2A (42.0°E)
- Opap Tv (13.0°E)
Re: MultiCAS
MultiCAS
-DATE : 2011/04/28
-Version : v1.63A
ADD : Added option about EMM Blocker for Cryptoworks card
: See 'example-cardkeydata.txt' possible to control by cws_emm_blocker = 0 or 1
- NBA TV (EutelsatW2A @ 10°E)
MOD : More improvement about Irdeto Card
edit dempsey: pokúšame sa fixnúť CRW karty ale emm spôsobujú problém takže ak necháte načítať zápisy a potom ich zakážete, tak Vám CRW karty pôjdu bez zásekov.
-DATE : 2011/04/28
-Version : v1.63A
- vikino
Re: MultiCAS
MultiCAS
-DATE : 2011/05/18
-Version : v1.70
-DATE : 2011/05/18
-Version : v1.70
- Al Jazeera Channel (Eutelsat W4/7 @ 36°E)
ADD : Added Re-Sharing (CCcam via Local Share, see as below)
--- How to use Re-Sharing of CCcam share ---
Use one CCcam account for more Azboxes with MultiCAS
1. Azbox connected to CCcam server
a. Get CCcam account.
b. Go to Plug-Ins->OpenXCAS->MultiCAS and smart Card Splitter & CS Menu
c. Select Mode as Server and set the sub-menu as follows ;
- My IP Address : this is the IP adres of your Azbox. This will be the server IP address in the client.
- Port : 3000 (default value) - Please set the value between 1000 and 9000.
- Time Out : 2.0 sec (default value). If you use more clients this time-out value must be higher. Please keep it below 4.0 seconds.
- Save the changed values by pressing RED button on RCU.
2. Client Azbox
a. Go to Plug-Ins->OpenXCAS->MultiCAS and Smart Card Splitter & CS Menu
b. and select Mode as Client and set the sub-menu as follows ;
- Server Domain Name Use : OFF (or ON if you use DNS.)
- Server IP Address : Set the IP address of the Server STB.
- Server Domain Name : If the Server Domain Name Use is ON, put the domain name.
(if you use local share between Azboxes in your house the Server IP Address will be like 192.168.xxx.xxx)
- Port : 3000 (default value) - Please set the same value with that of Server STB.
- Time Out : 1.0 sec (default value will 1.0 sec, but 3.0sec will be better)
- Check Server : Press OK button for checking the Server STB. If the server information is correct, you will see Server CAS ID : 0x0000.
- Go to TV and check the channel is working well.
- If you would have more sets to use Client please follow the above procedure again.
- If the TV channel on Client STB is not working please try to adjust the value of Time Out.
MultiCAS v. 1.70B
MultiCAS
-DATE : 2011/06/10
-Version : v. 1.70B
MOD : More improvement about Hops control for NDZ (CCcam)
ADD : Add support Timeout limit control for CCcam, this for Found Best Server or Found Best ShareID (see example-timelimitcaid.cfg)
ADD : Show Entitlement for NDZ card (can found at /tmp/card_slot.info)
-DATE : 2011/06/10
-Version : v. 1.70B
