Newcs 1.67 RC1 pre AZBOX
NewCS 1.65
NewCS 1.65 pre AzBox HD Elite and Premium .
It can read all kind of Cards, including t0 and t1 cards.
Sú dve možnosti inštalácie
Automatická :
Choď do Home - Plug-ins - OpenXCAS - Manual Install - Edituj adresu azboxworld.com , a stiahni čo potrebuješ .
alebo
Manuál:
Po stiahnutí odtiaľto ho prekopíruj cez FTP.
Lepšia je automatická inštalácia.
Automatická :
alebo
Manuál:
Re: NewCS 1.65
Vysla nova verze NewCS 1.66-RC1, ale bohuzel binarku pro azbox jsem tam nenasel.
newcs.ppc -> NewCS binary for dreambox, tripledragon and other powerpc machines.
newcs.ppc.pcsc -> NewCS with support for the PC/SC for powerpc machines.
newcs.ppc.usb -> NewCS with support for the Infinity-USB programmer for powerpc machines.
newcs.mips -> NewCS binary for the 7025/800/8000 dreambox.
newcs.mips.pcsc -> NewCS binary with support for PC/SC for the 7025 dreambox.
newcs.mips.usb -> NewCS binary with support for the Infinity-USB programmer for the 7025 dreambox.
newcs.i686 -> 32bit NewCS binary for linux on Intel compatible machines.
newcs.i686.pcsc -> 32bit NewCS binary for linux on Intel compatible machines, with PC/SC support.
newcs.i686.usb -> 32bit NewCS binary with support for the Infinity-USB programmer for Intel compatible machines.
newcs.x86_64 -> 64bit NewCS binary for linux on AMD64.
newcs.x86_64.pcsc -> 64bit NewCS binary for linux on AMD64, with PC/SC support.
newcs.x86_64.usb -> 64bit NewCS with support for the Infinity-USB programmer on AMD64.
newcs.openwrt-mips -> NewCS binary for OpenWRT-kamikaze (this only support phoenix as type)
newcs.openwrt-mips.pcsc -> NewCS binary with support for PC/SC for OpenWRT-kamikaze. (this only support phoenix and pcsc as type)
newcs.openwrt-mips.usb -> NewCS binary with support for the Infinity-USB programmer for OpenWRT-kamikaze. (this only support phoenix and infinity as type)
newcs.openwrt-arm -> NewCS binary for NSLU2. (this only support phoenix as type)
newcs.openwrt-arm.pcsc -> NewCS binary with support for PC/SC for NSLU2. (this only support phoenix and pcsc as type)
newcs.openwrt-arm.usb -> NewCS binary with support for the Infinity-USB programmer for NSLU2. (this only support phoenix and infinity as type)
newcs.cris -> NewCS binary for the Axis Etrax 100LX.
newcs.cris.pcsc -> NewCS binary with support for PC/SC for the Axis Etrax 100LX.
newcs.cris.usb -> NewCS binary with support for the Infinity-USB programmer for the Axis Etrax 100LX.
newcs.st40 -> NewCS binary for the Kathrein box..
newcs.st40.pcsc -> NewCS binary with support for PC/SC for the Kathrein.
newcs.st40.usb -> NewCS binary with support for the Infinity-USB programmer for the Kathrein.
newcs.qnap -> NewCS binary with support for the QNAP NAS.
newcs.qnap.usb -> NewCS binary with support for the Infinity-USB programmer for the QNAP NAS.
newcs.qnap.pcsc -> NewCS binary with support for the PC/SC for the QNAP NAS.
newcs.freetz -> NewCS binary with support for the Freetz Routers.
newcs.freetz.usb -> NewCS binary with support for the Infinity-USB programmer for the Freetz Routers.
newcs.freetz.pcsc -> NewCS binary with support for the PC/SC for the Freetz Routers.
newcs.readynas -> NewCS binary with support for the readyNAS.
newcs.readynas.usb -> NewCS binary with support for the Infinity-USB programmer for the readyNAS.
newcs.readynas.pcsc -> NewCS binary with support for the PC/SC for the readyNAS.
newcs.xml -> The configfile that NewCS reads, should be placed in /var/tuxbox/config.
AZBOX HD - elite, Skystar2 - VDR 1.60 (gentoo), Triple Dragon, DB500
Re: NewCS 1.65
Binarka tam nieje, tak isto ako vyssie pridana je verzia 1.20 RC11 - doplnena o podporu, ktora v oficialnej verzii bola skutocne len v newcs 1.65 . Treba ale povedat, ze newcs je uz od verzie 1.50 doplneny o chameleona a feynmana, co azbox verzia samozrejme nevie.
Re: NewCS 1.65
Ahoj,
a bude delana binarka pro Azbox primo vyvojari newcs? Nebo to newcs pro azbox neni primo od vyvojaru? Nejak tomu moc nerozumim. Vzdyt pokud maji toolchain tak preci neni problem aby byla binarka vydavana primo v novych verzich.
Dekuji ti za odpoved.
grantec píše:Binarka tam nieje, tak isto ako vyssie pridana je verzia 1.20 RC11 - doplnena o podporu, ktora v oficialnej verzii bola skutocne len v newcs 1.65 . Treba ale povedat, ze newcs je uz od verzie 1.50 doplneny o chameleona a feynmana, co azbox verzia samozrejme nevie.
Re: NewCS 1.65
myslim,ze v buducnosti aj ano. zatial je len verzia patchnuta azteamom. tazko byt prorokom - vsetko je o peniazoch . A netreba zabudat ani na zakulisne tahy konkurencnych teamov a vyrobcov - vid incubuscamd . :)
newcs.sigma -> NewCS binary with support for the Sigma Mips Cpu's (Azbox).
newcs.sigma.usb -> NewCS binary with support for the Infinity-USB on the Sigma Mips Cpu's (Azbox).
newcs.sigma.pcsc -> NewCS binary with support for the Infinity-USB the Sigma Mips Cpu's (Azbox).
Interná čítačka v tejto verzii pre AZ HD nie je podporovaná, takže táto verzia poteší tých ktorí chcú použiť USB čítačku
Re: Newcs 1.67 RC1 pre AZBOX
newcs.xml 1.67RC1
ice_newcs
Test
newcs 1.66 - verzia upravena pre citanie kariet ICE v internej citacke- pre klasicku verziu fw !!
kedze mam v azboxe enigmu, , kto pouziva klasicky sw a ma ICE kartu - moze odskusat.
skylink ICE - to je biela karta s napisom ICE pod SIM zo strany chipu.
