IncubusCamd - manual install
Rady a návody pro majitele HD přijímače.
Instalacia IncubusCamd - manual . anglicka verzia , preklad spravim neskor.
ImuleT
Re: IncubusCamd - manual install
Příspěvek od ImuleT »
Chlapi, som v koncoch. Stale trapim IncubusCamd voci CCcam 2.0.11 a nejde a nejde (Dream ide). Skusal som manualnu aj automaticku instalaciu. conf file je taky jednoduchy, ze tam nie je co pokazit. Na nemeckom fore som nasiel "debug" info od E.T. http://forum.azbox.to/thread.php?threadid=25
moje vypada takto:
MMP[OpenXCAS]$ ls
MultiCAS addons.conf incubusCamd module.seq newcs sh
MMP[OpenXCAS]$ cd inc*
MMP[incubusCamd]$ ls
^HincubusCamd.conf incubusCamd.sh openxcas.conf
incubusCamd.prio incubusCamd.sigma
MMP[incubusCamd]$ ./inc*sigma
MMP[incubusCamd]$ [OPENXCAS_CHANNEL] openxcas_create_channel
[OPENXCAS_CHANNEL] openxcas_module_open_channel(incubusCamd)
osdep_msq_server_open : key_request 0x263CD7B6 key_response 0x263CD7B7
osdep_msq_server_open : request msq is already created
osdep_msq_server_open : response msq is already created
[OPENXCAS_CHANNEL] openxcas_adaptor_open_channel(incubusCamd)
osdep_msq_client_connect : key_request 0x263CD7B6 key_response 0x263CD7B7
[OPENXCAS_CHANNEL] openxcas_module_send_msg(incubusCamd): success to send message(200)
[OPENXCAS_CHANNEL] openxcas_module_send_msg(incubusCamd): success to send message(201)
Vypada to, akoby to frcalo, no na obrazovke stale svieti "Zakodovane". V mojich vypisoch chyba sprava 204.
Dalsia otazka: mam mat aktivny aj MultiCAS, ci iba incubusCamd?
DM7020-S, AzBox HD Premium, PopcornHour 110, FullHD LCD Samsung, ...
voci 2.0.11 nepojde. To by si musel flycam nainstalovat , alebo ako server mat starsiu verziu CCCam - napriklad 2.0.9 .
ImuleT
V clanku http://www.digital-kaos.co.uk/forums/f9 ... 8-a-33475/ uplne dole pisu:
Originally Posted by jellybee007 View Post
"Hi,
Are you sure your cccam version is not higher then 2.09?
Otherwise it doesn't work."
its only cccam 2.1.** or above that had the anti incubuscamd
basically dream multimedia have now adopted a way of stopping incubuscamd to connect to cccam , for the time being.
so if your connecting to cccam stay with versions 2.0.11 or older versions
to platilo o incubuse s verziou 080 a vyssou. Na azboxe ide ale len verzia incubus 0,5 a ta ide na server s CCcam 2.0.9 a starsim .
ImuleT
To si ma potesil aj nepotesil zaroven. Uz som ozaj zacal o sebe pochybovat. Ako si to myslel s tym Flyccam?
fevlad
Příspěvek od fevlad »
grantec píše:to platilo o incubuse s verziou 080 a vyssou. Na azboxe ide ale len verzia incubus 0,5 a ta ide na server s CCcam 2.0.9 a starsim .
Ahoj chcem sa opýtat či bude fungovat share medzi IP BOX a AZ BOX, musíby t starší ccam v ipboxe?
neo177
Příspěvek od neo177 »
pri terajsej stabilite incubusu to pojde ale velmi nestabilne :D
online: DM800 HD + cccam
offline: AZBox Elite HD + cccam
Zpět na „Rady a návody HD“
