fw 1.08.94 FAC
fw 1.08.94 FAC
v downloade najdete dostupnu novu verziu fw 1.08.94 FAC .
http://www.forum.satdigitalne.cz/viewto ... 234&t=5214
Re: fw 1.08.94 FAC
--> Front vol. & ch. buttons interchanged issue solved (7105)
--> Blindscan works twice & Not running Blindscan solved
--> Calculating time error in recording information solved
--> Showing WAIT OFF on front display during recording in standby mode solved
--> Searching problem in specific TP in AsiaSat 3 solved
--> Freezing symptom in specific TP (12266 H 27500 Astra19) amended
--> Differences OSD language with OSD menu text display amended
--> Portuguese OSD Language : added
--> OSD Languages Translation ammended :
--> french, dutch and english
--> Spelling error as Power Saving in Standby Mode in A/V output setting menu amended
--> T1 & T2 Icons are presented on Service List and Service List with Single Tuner model solved by presenting only T1
--> USALS freezing issue solved
--> Playback problem in Standby Mode solved
--> Tuksat42E & Eutelsat7E night Ch. problem solved
--> Plugin OSD Jitter problem solved (7110+7105)
--> Plugin Interface upgrade : Plugin API V1.07
--> Pls. use NEW Plugins and WebZeal V1.80 !
--> PanScan Format for TV Aspect Ratio 16:9 added
--> Full Format for TV Aspect Ratio 4:3 added
--> Build Version 4551
- SuiVanOrton
Re: fw 1.08.94 FAC
Takže ten NTFS tam nakonec není co ?
HD-BOX 9200, karta Skylink (Irdeto výměna)
HDD Samsung Story Station Plus 1TB (připojeno přes eSata)
TV Panasonic TX-L42E30E
Re: fw 1.08.94 FAC
fefe88 píše: --> Pls. use NEW Plugins and WebZeal V1.80 !
chápu dobře, že s xCamem z předchozích verzí by mohl být problém ?
Re: fw 1.08.94 FAC
Asi bych to bral prinejmensim jako doporuceni jak se vyhnout pripadnym problemum.fefe88 píše:
Zajima me, jestli jste uz nekdo ten WebZeal V1.80 zkousel a jestli stoji za namahu to na instalovat.
HDBox FS-9100 PVR
Amiko SHD-8900 Alien
Optibox TSCX PVR Ready
Dreamsky NXP256HD
GOLDEN MEDIA UNI-BOX 9080 CRCI HD COMBO
Dreamsky NXP256HD
Re: fw 1.08.94 FAC
Neviem ako xCam , ale ja som skopcil komlet plugin oscam 4846 CS/SKY s predchadzajuceho firmw.mmirousek píše:fefe88 píše: --> Pls. use NEW Plugins and WebZeal V1.80 !
a vsetko bezi ako predtym teda zatial, 1/2 hod - testujem
WebZeal som stiahol - vyzera to zaujimavo, testovat budem az nebude doma zena
Re: fw 1.08.94 FAC
... od kud jsi stahoval a jakou verzi? Delam neco blbe a nebo verze nejdou mezi boxi zamenovat. To co jsem v rychlosti nasel a zkusil stahnout vcetne doporucovane 1.80 mi na HDBox nejde zadnym z uvedenych postupu nijak instalovat.siso.tt píše: WebZeal som stiahol - vyzera to zaujimavo, testovat budem az nebude doma zena
HDBox FS-9100 PVR
Dreamsky NXP256HD
Dreamsky NXP256HD
Re: fw 1.08.94 FAC
dk_line píše:... od kud jsi stahoval a jakou verzi? Delam neco blbe a nebo verze nejdou mezi boxi zamenovat. To co jsem v rychlosti nasel a zkusil stahnout vcetne doporucovane 1.80 mi na HDBox nejde zadnym z uvedenych postupu nijak instalovat.siso.tt píše: WebZeal som stiahol - vyzera to zaujimavo, testovat budem az nebude doma zena
myslim ze odtialto : http://www.dark-sat-world.com/downloads ... le&id=2853
Re: fw 1.08.94 FAC
Tak WebZeal 1.80 jde stahnout i bez registrace ZDE. Bohuel, jestli jsem spravne pochopil, tak na HDBOXu 9100 si to standardnim postupem neodzkousim, pro mount a nasledne spusteni je treba nit dve USB, presniji tedy predni USB :sad:
HDBox FS-9100 PVR
Dreamsky NXP256HD
Dreamsky NXP256HD
Re: fw 1.08.94 FAC
Neni náhodou tento plugin pre iné modely / s iným chipsetom / ?
Re: fw 1.08.94 FAC
ja myslim ze nie http://.....dempsey píše:Neni náhodou tento plugin pre iné modely / s iným chipsetom / ?
Re: fw 1.08.94 FAC
Tak jsem nahodil tento nový firmware 1.08.94 na HDBOX FS-9100. Taky se vám nezobrazuje š a ž v menu a podnabídkách? Všude mám pouze mezeru. Třeba Obnovení systému - Vyma e ulo enou pozici
- ShaMan
Re: fw 1.08.94 FAC
Webzeal a NTFS se týká zatím nové řady s jiným procesorem tzn HD-BOX FS-9105 apod Fortis based ,
tím pádem je třeba dávat bacha na changelogy , pravděpodobně budou některé pro a jiné pro jiné .
Re: fw 1.08.94 FAC
hmm... tak ted jsem uplne mimo, jeste ze jsi me tou tyci prastil. Chtel jsem verit tomu, ze Octagon SF1008SE+ a SF1008 jsou na totoznem zeleze jen rozsirene o ty usb a e-satu:???:dempsey píše:Neni náhodou tento plugin pre iné modely / s iným chipsetom / ?
HDBox FS-9100 PVR
Dreamsky NXP256HD
Dreamsky NXP256HD
- SuiVanOrton
Re: fw 1.08.94 FAC
taky taky, místo "živě" je tam " ivě" apod.gatecomputers píše:Tak jsem nahodil tento nový firmware 1.08.94 na HDBOX FS-9100. Taky se vám nezobrazuje š a ž v menu a podnabídkách? Všude mám pouze mezeru. Třeba Obnovení systému - Vyma e ulo enou pozici
A ještě mám problém trošku s manuálním nahráváním, když třeba zapnu manuální nahrávání tak se stává že mi to hodí hlášku program zakodovan. Bud hned, nebo po chvíly když se vrátím na ten program který zrovna nahrávám. Jinak ale když nejsem doma tak se to nahraje ok. (tunery mám oddělené).
