OSD capture plugin
Plugin umoznujuci snimanie OSD (teda menu a info panelu) . Instaluje sa do adresaru /var/bin/ - ako standartny plugin.
Po spusteni ostava bezat na pozadi a snimku OSD vytvori po stlaceni tlacitka oznacenie/zaskrtnutie na dialkovom ovladaci.
Vytvara rastrove obrazky vo formate bmp a uklada ich do adresara /var/ .
Plugin sluzi skor pre uzivatelov, ktory radi poskytuju navody na ovladanie,alebo spristupnenie niektorych funkcii. Tento plugin pracuje vo verzii fw 1.07.97
OSD capture plugin
Užitečné programy pro HD-BOX.
OSD capture plugin
Re: OSD capture plugin
Plugin allowing the OSD imaging (ie, menu and info panel). Installs in / var / bin / - Standard as plugin.
After running still run in the background and images to create OSD after pressing the button labeling / uncheck the remote control.
Creates bitmaps in bmp format and store them in / var /.
Plugin serves rather for users who like to provide guidance for controlling or access to certain functions. This plugin works in fw version 1.07.97
Zpět na „Utility pro HD-BOX FS-9200-9300 PVR“
