fw 1.08.26
fw 1.08.26
IRD.HD BOX.FS 9100PVR.v1.08.26
Changes :
- STB hang-up when aging fix.
--> SSeveral optimisations in main SW !
- No signal when AC power Off/On fix.
- Move finction problem in service list manager fix.
- Timer : UI when setting the timer and if duplicate with the previous timer - Improved
- New Function in Timer Settings Menu :
--> Menu - System Tools - Timer Setting : Blue Button - Delete All
- Playlist (Playback) EPG Info durch INFO Taste
--> [INFO] button excute in recording file - improved : EPG, Time & REC file details
- Samba Turkish char support (8859-9 default)
- Turksat (42E), latest TP List - Updated
- Incorrect channel number display in REC info bar when recording fix.
- Incorrect recording time in recording file fix. (Trick Mode Problem)
- OSD message box - Improved
- SAT Name add. by Service Search Mode
- New Function in Infobar :
--> Menu - Configuration - Display Setting :
--> Info Box Event Name : present event with time, present and follow event
- Volume Control in TXT Mode (Volume v+ v-) add.
- BISS + DCW input (keymanager) adjusted
--> Menu 8282 ...DCW key new functions add.
--> SID ONID TSID . & SID PMTPID ECMPID
download tu 1.08.26
Changes :
download tu 1.08.26
- aaahtr1
Re: fw 1.08.26
v1.08.26 tak tento chodí zatial naj , dokonca čita aj upc kartu vo vrchnom slote len pre samotnu kartu, aj ked ju mi nevypisuje v menu, ale s nou pracuje, pri vložení oznami že je vložena dokonca dva krát otazka je či ju aj ,,update_ne,, , napravila sa aj funkčnost mcas čo tiež nebežalo zrovna naj musel som tam mat vloženu nejaku pamätovku aby to šlo plynule, akurat neviem že či pre firmware alebo nejaka novšia verzia mcas, každopadne to už chodi ovela lepšie
ešte taka otazočka, dokaže a ked tak ako zdilat kartu v stanby režime
.HDboxFS_9100_PVR. .Formuler F1. Amiko Mini HD RE. + zopár pc DVB S2 kariet
Re: fw 1.08.26
dokaze- vypnut cardreader, nainstaluj si Oscam a mozes aj server mas postaveny - vlastne zadarmo .
http://www.forum.satdigitalne.cz/viewto ... 173&t=5379
- Duce
Re: fw 1.08.26
Tak to je neuveritelne skvelý FW, smekám
AZ BOX HD PREMIUM, HD BOX FS-9300, HD BOX FS-9100,COOLSTREAM ZEE, AB IPBOX 200S, OCTAGON SF 908, SAT Elita 2000 HD, FW takmer vždy čerstvý,rotor-takmer celý orbit
Re: fw 1.08.26
zdravim..po prehodeni fw na 1.8.26 mi na boxe ostane svietit nápis hdbox. skusal som aj obnovit nastavenie na tovarenske...co to moze sposobovat???? poradte
Re: fw 1.08.26
len ti svieti napis hdbox, alebo prijimac inak funguje ? lebo jas toho napisu sa da nastavit v menu prijimaca.
Re: fw 1.08.26
box funguje ako doteraz. vsetko sa vypne nic nesvieti ani display ĺen ten napis HDBOX.
Re: fw 1.08.26
aha - skontroluj si typ vypinania- ci mas standby napajanie zpanute, alebo vypnute. a je tam este ejdna polozka na nastavenia jasu duisplaya - ale nastavuje sa tym jas toho napisu - da sa aj celkom vypnut. Da sa dokonca nastavit aj ako dlho po vypnuti bude ten napis svietit.
Re: fw 1.08.26
tak som spravil vsetko ako si pisal - standby rezim je vypnuty, jas displaya vypnuty, a doba podsvietenia po vypnuty je 10 sek.. no stale mi po vypnuti boxu ostane svietit ten napis, nevypne sa to po tych 10 sek ako je to nastavene
Re: fw 1.08.26
riso80221 píše:tak som spravil vsetko ako si pisal - standby rezim je vypnuty, jas displaya vypnuty, a doba podsvietenia po vypnuty je 10 sek.. no stale mi po vypnuti boxu ostane svietit ten napis, nevypne sa to po tych 10 sek ako je to nastavene
nápis HDBOX nelze vypnout tak jako u starších verzí, je to hold chyba softu.
Re: fw 1.08.26
Jede vam bez problemu timeshift ? Jak velkou flash potrebuju dat do USB abych mel timeshift na HD programy cca 2 hodiny ?
Re: fw 1.08.26
pod 4GB tam nema vyznam pripajat usb kluc. ostatne - dnes sa daju zohnat za ozaj smiesnu cenu . 8GB na hd by mohlo stacit. ale nemam to odskusane- ja timeshift nepouzivam .
- prco007
Re: fw 1.08.26
8GB (okolo 7,5 GB v reále) je málo. Na HBO HD stačí, ale keď budeš pozerať kanál ktorý má väčšiu prenosovú rýchlosť, tak to stačiť nebude.Jak velkou flash potrebuju dat do USB abych mel timeshift na HD programy cca 2 hodiny ?
Napr.: Film z HBO HD, ktorý trval 2h 11min s prenosovou rýchlosťou 8418 kbps má veľkosť 7,97 GB
Pri 16 GB máš aj rezervu a istotu, že ti tam tie 2 hodiny vojdu
HD-BOX FS-9100 - fw v1.10.13
- Motoroko
Re: fw 1.08.26
Napis sa vypina korektne ak mas zapnuty standby mod, ak nemas je jedna cesta ako to sprevadzkovat:riso80221 píše:zdravim..po prehodeni fw na 1.8.26 mi na boxe ostane svietit nápis hdbox. skusal som aj obnovit nastavenie na tovarenske...co to moze sposobovat???? poradte
1. zapni stand-by mod
2. nastav jas na Off
3. vypni do stand-by, zapni
4. vypni stand-by mod v menu
Potom pri uplne vypnutom prijimaci logo nebude svietit, az kym nezmenis uroven nastavenia v menu, potom to opat blbne.
Btw meral niekto kolko ma odber 9100vka v stanby rezime?
Re: fw 1.08.26
zdravím, môj prvý príspevok a hneď otravujem. Snažil som sa stiahnuť tento soft , a napíše že neexistuje. Dal by sa reup ?
