fw 1.09.35
Odkaz na stažení firmware a diskuze k aktuálnímu firmware.
fw 1.09.35
Ver 1.09.35
Common Issue
1. fdu & plugin files server upgrade (fdu only currently) : Supported
2. ST codec MP3 Player : Supported
3. Mosaic screen broken issue : Amended
4. Press recall key during booting display "Run..." mode : Deactivate plugin Auto Start
HD 7xxx & 8xxx
1. Play YouTube video : Available
2. Persian TTX : Added
3. Can not reverse font color in the specific menu with OSD color 2 : Amended
<Free TV+>
1. Free TV+ bugs : Amended
- Change Youporn's parental control default : Amended (default is Lock)
- Download status bar disappearing when changing full screen : Amended
- Hang up intermittently when moving cursor in downloaded video list: Amended
- Initializing setting value after installing addon : Amended
- Setting Pop-up window broken : Amended
- Can not renewal the screen : Amended
- Showing the message box if Free TV+ is not access network : Added
- Disappearing the cursor in the movie list : Amended
- Hang up when changing the service SVT to Youtube : Amended
- Screen Resoultion : Supported
- Information for movie duration : Supported (if available)
- Showing up the message if there is any proper storage : Added
- Changing only full screen enlarged over the PIG during PIG movie play if press the V.FORMAT button : Amended
- Fashion TV added : Added
- Metacafe content : Available to add
- Hang up when choosing F parties category in Fashion TV service : Amended
- List up only 4 when choosing the specific category in YouTube service : Amended
- Hang up when changing specific category in Fashion TV
- letter is disappeared when user inputs the wrong PIN code : Amended
- Setting OSD boards are blinded with more than 7 server list : Amended
- PIG screen crushed with not complete download contents : Amended
2. Addon Version : Updated
- Working with only v1.01
- Addon should be installed newly and previous version will not be working
** Addon works with only compatible Free TV+ version. If incompatible version of addon is installed with Free TV+, it will not be updated on the addon list.
:arrow: Tu klikni pre stiahnutie
gizmosk
Re: fw 1.09.35
Příspěvek od gizmosk »
Uz to niekto skusal na 9100-vke? Oplati sa tento FW?
maiden
Re: fw 1.09.35
Příspěvek od maiden »
Včera som ho nahodil, zatiaľ v pohode. Len na predvoľbe č.1 stále to isté. Vyhadzuje hlášku zakódované. Tak som tam dal opäť TA3. Podľa môjho subjektívneho pohľadu je obraz trochu horší akos 1.09.20.Inak zatiaľ žiadne problémy. Mám teraz iba Mcas, Oscam som ešte neskúšal.
HD Box 9100, DM500s,Samsung 40LE650, 23,5E, 19,2E, 13E, 1W
kajvet
Re: fw 1.09.35
Příspěvek od kajvet »
Mě po chvilkách kostičkuje obraz... Vrátil jsem se k 1.9.20 a ten je ok...Dle mé zkušenosti je 20 nej
vald
Re: fw 1.09.35
Příspěvek od vald »
Dnes sa mi stala taká blbá vec: počas aktualizácie firmwaru mi vyhodilo istič a aktualizácia sa nedokončila.
Po spustení sa zobrazí krátko LD 2.23 a potom vypíše ERR 0x71. Mohol by mi prosím niekto pomôcť? (išlo o aktualizáciu z fw.1.09.09 na fw.1.09.35)
Viem, že sa to tu už niekde riešilo ale jak na potvoru, keď to potrebujem, nie a nie to nájsť.
:118:
Humax IRHD 5100S, Showbox S-500, Openbox X820, offset al85 na 28,2E-23,5E-19,2E-5E, 2x DiseqC 2.0 SUS 44, LNB 3x GI + 1x Inverto, 3x Skylink, Tv Panasonic TX-P42X10Y
tulino
Re: fw 1.09.35
Příspěvek od tulino »
staci zadat tvoju chybu do vyhladavania na fore v sekcii HDBOX, heslo a liek je porter:
viewtopic.php?f=172&t=3601
ale najprv by som este skusil restart so zasunutym usb klucom s 1 fw, ak nie tak porter, alebo servis ak si netrufas
vald
Re: fw 1.09.35
Příspěvek od vald »
V sekcii rady a návody som našiel toto:
viewtopic.php?f=166&t=6834
Postupoval som presne podľa návodu len neviem či sa to podarilo, lebo už cca 25 minút svieti "LD 2,23" !??
tulino
Re: fw 1.09.35
to co si nasiel riesi iny problem - prepneny VAR
ty mas nedokonceny update fw
vald
Re: fw 1.09.35
Příspěvek od vald »
Tak nepomohlo ani prečistenie var a ani porter.. :sad:
gizmosk
Re: fw 1.09.35
A ako to updatujesh? Dolezite su odpovede na tieto otazky:
1. Mas v PC / NTB seriovy port alebo to robish cez nejaku redukciu USB to SERIAL ?
2. Mas WIN XP alebo W7 ?
3. Seriovy kabel mas overeny ze je OK?
Pytam sa preto lebo mne minule zdochol tiez update. A kym som dal dokopy box tak som si poriadne ponadaval.
Pod W7 a s redukciou z ciny USB to SERIAL mi to padalo. Win XP + redukcia to slo ale na 80% to zasa zdochlo.
Nakoniec som zavolal kamosovi a zo stareho NTB s WIN XP + poctivym HW serial portom a serial kablom dlzky 1m mi to preslo ako ma ;)
Vsetky ostatne kombinacie zlyhali :(
vald
Re: fw 1.09.35
Příspěvek od vald »
Doteraz som updatoval vždy len z USB klúča (vždy úspešne). Po RS-232 som siahol až teraz, keď sa vyskytol problém.
Seriový kábel (krížený) je na 100% funkčný. Používal som ho na Openboxy a nemal ho nikto iný.
Updatoval som (teda lepšie povedané som sa pokúšal) zo stolného PC (Win.XP) cez seriový port - t.j. nie je tam nijaká redukcia.
Systém spojenie aj detekoval, ale updat sa nerozbehol. (zostalo to stále stáť na 0%)
gizmosk
Re: fw 1.09.35
A aky errorcode ti box vypise?
Skus pozriet tu viewtopic.php?f=166&t=7910
podla errorcodu ze co mas za problem. Zrejme bude problem v komunikacii PC <-> BOX.
Skus vypnut antivirak a ine aplikacie v PC, ktore by mohli sahat na kominukaciu cez seriaovy port ci to nepomoze...
vald
Re: fw 1.09.35
Příspěvek od vald »
Vypisovalo to ERR 0x71, ale už je to vyriešené. Pomohol mi jeden chlapík tu od nás čo sa tým zaoberá. (díki kámo). Vraj to robil cez RS-232. (nechápem prečo to nešlo mne). V každom prípade ďakujem všetkým čo sa mi snažili poradiť. Osobitne tebe gizmosk - veľmi si cením tvoju snahu. Príjemný deň všetkým.
Zpět na „Odkaz na firmware a diskuze k firmware - HD-BOX FS-9100 PVR“
