PKT SF1018 E2 HAARP v2 Image
- tommix
Enigma2 OpenSource SH4 Duckbox Project GIT-2704 PKT mod SVN-1156 HAARP v2 Image
Image is designed for installation SATA/USB device
Support receiver: Octagon SF1018/HDBOX/AT-7000
Added by sh4 Duckbox Team:
- [stm24] OSS SND kernel configs not needed any more (e.g. CONFIG_SND_PCM_OSS)
- [stm24] added lzma patch for squashfs
- [stm24] ext4 can now be used for ext2/3
- [make/ffmpeg] - updated ffmpeg 0.6.1
- [multicom-3.2.4_rc3] add new multicom driver
- [eplayer3] playback aac-he streams with aac-lc
- adding opkg binary to default build
- fix timing problem in filepush
- [Player2 179/191] possible fix for chopped DTS sound on some files
- [libeplayer3] support for OSD 3D modes for subtitles
- [libeplayer2, libeplayer3] Close directory file handles after looking for subtitle files
- [stm24] added squashfs-tools 4.0 lzma patch
- add busybox 1.18.5 stable
- extend streamproxy to support linuxdvbapi5
- [player2_191/player2_179]resturucture dts fix. The fix now only applys to DTS streams and the playback time is only corrected on time differences up to 50ms this MAY fix some issues with async sound
- [player2_191] fsynth bugfix
Added by PKT:
- first build on stm24 kernel
- add new WebInterface v 1.6.7
- new function "live ecm" in infobar
- show Channel Number on Front Pannel + ON/OFF in setup menu
- fast switching channel
- upgrade CrossEPG svn 268
- fix qwerty VirtualKeyboard
- fix Backup/Autorestore function | LABEL=RECOVERY required
- fix channel number showing on VFD if long channel name
- set home directory to /root
- EPG description on channel list -> ON
- change reading of ecm.info
- new converters and skins modifications
- fix dimmer action when channel switch
- fix parsing PROV, CAID, PID
- moving EPG support to KeyMapper
- ReferencePKT optimization
- set PKTGoldHD as default skin
- fix CIFS mount if passwd is empty
- MPlayer fix GS of EOF
- upgrade formating device in Install Manager
- update API of MyTube based on last CVS source
- update EmuManager v1.0.6: add sh4Cam support & gbox fix
- font FIX moved to Skin setup
- remove unnused files or BP menu settings modification
- fix showing processes
- res_emu in standby add in BP->Settings
- tune and fix sys_info
- add showing /Loaded modules/ in BP ->Menu ->System
- update WIFI scripts:
* add detecting of supported USB WLAN adapters
* user is informed about unsupported device
* optimize selecting WLAN driver
* optimize starting WLAN driver
- fix show event-progress in channel selection
- fix crossEPG
- PKT InstallManager 1.2.2
- PKT KeyMapper 1.5
- update Permanent Clock
- fix EMUManager russian translate
- add green button support in Media Player
- fix streamproxy after reboot
- Add Auto 3D Skin Switch by Dr.Best
Known issue:
- subtitles in MediaPlayer not working good
- some Polish HD channels not support
FTP login: user: root, passwd: pkteam
http://www.edisk.cz/stahnout-soubor/044 ... .03MB.html
Added by PKT:
- fix crossEPG
- PKT KeyMapper 1.5
Known issue:
AZBOX Premium
Tuner B : motor SG 2100
Tuner C : DVB-T
AZBOX Premium
Tuner C : DVB-T
Re: PKT SF1018 E2 HAARP v2 Image
velmi podařený image, při cvilce natočím video jak rychle přepíná programy, to čumím jak výr
s posledním oscamem jede zatím velmi stabilně. oscam jede jako klient cccam v2.1.4.
Kartu mám jen cslink 0666 a to jsem zatím nezkoušel rozjet - mám pocit že to zatím ani nejde.
- galm
pani a poradite ako ste do toho dostali oscam? pod modrym tlacidlom sice najdem managera, ale nenasiel som ako tam doinstalovat plugin :oops:
xTrend et8K, ATV, scam freesat, mediaportal, CSFD, Samsung 1TB, Multibeam E85 (23.5E+19.2E+13E+0.8W)
AB 450HD, skylink vymena, Offset 90 (28.2E+23.5E+19.2E)
RIP: VU+Duo, OpenBox X820
"poriadok je pre blbcov, inteligent zvladne aj chaos"
no problem až budu doma , tak ti napíšu , teď z hlavy to nedám ..... :)
- galm
vopred vdaka. uz sa tesim na testovanie
tááákže
1. modré
2. Pluginy
3. Stáhnout pluginy
4. EMU
5. najít v seznamu "oscam.config" a nainstalovat
6. najít v seznamu "oscam_4158_bin_only" a nainstalovat
umístění v boxu je následovné: (připojení FTP - heslo na roota je "pkteam" )
oscam.config - /var/keys/
binárka - /var/emu/
7. Binárku nahradit třeba tímhle Oscamem "OSCAM 1.20-unstable_svn build #5961" , jede mi naprosto stabilně.
přikládám tu binárku + můj config - není nastavený na karty ale jen na cccam servery 0d0f a 0d03 ale testoval jsem i
ICE skylink s configem od Grantece někde tady z fóra. Configy se vlastně ani moc neliší , mám pocit že jen "boxtype" je jiný
než u origo FW ale nechcu kecat... :)
Dále přikládám plugin CSFD - parádní věc - více info na cssf fóru....
náhrát do /tmp/ pak ....
modré - Addons - Instaluj soubor - jdi do IPK menu - instaluj IPK
POZOR - mě to při instalaci hodilo zelenou smrt ale po najetí je to v pořádku a funkční
Funguje i v image od AAF
další dotazy klidně zodpovím - škoda že polák nedělá verzi pro flash, hned bych to tam nahrál, jsem s tímto zcela spokojen.
AAF je taky dobré, ale můj subjetivní pocit je že PKT je rychlejší při přepnutí programu.
1. modré
2. Pluginy
3. Stáhnout pluginy
4. EMU
binárka - /var/emu/
- galm
no skoncil som hned na 2-om bode ... modre-pluginy
pod modrym mam len: disk, system, addons,moduly, nastavenie, info
Tak som to nakopcil cez FTP, ale stale neviem najst Pluginy-EMU :sad:
Edit: tak vypnuti a restarte som to uz nasiel co zn. pokracujem od bodu 3
Jo a ještě jsem si vpoměl na jednu věc u image PKT:
Modré - addons - Aktualizace
Stáhnout aktualizace - jinak nepůjdou karty
- galm
tak uz sa mi to podarilo rozbehat, ale teraz mam otazku. Ked by som chcel rozbehat Austria TV musim do configu pridat oscam.keys?
mozem ho nakopirovat z klasickeho oscamu pre standartny FW?
tak to asi nepude, v klasikém FW se na oscam.keys používá modifikovaný oscam.
Tohle jsem neřešil, mě stačí skylink a cslink :)
Ale v EMU se myslím nabízí mgcamd, tam by to s aktuálními klíči mělo jet...
narazil jsem na problem se zobrazovanim cestiny diky mmirouskovi jsem vedel kde hledat a nejednoduzsi reseni je nasledujici:
Když se pripojite do boxu přes ftp IP boxu jmeno root heslo pkteam tak v polozce :/usr/local/share/enigma2/ je soubor skin.xml ten je potreba editovat konkretne dva radky které obsahuji font nmsbd.ttf (<font filename="nmsbd.ttf" nahradis <font filename="FreeSans.ttf" ) to same prijde udelat i ve slozce skinu který pouzivate tam je taky soubor skin.xml provedete tu samou upravu a to je cely. Od te chvile uz s cestinou problemy nejsou. Samozdrejme se da pouzit i jiny font ktery by se vam libil ale tohle je nejsnazsi cesta. Fonty ktery v boxu jsou nahrany najdete /usr/local/share/fonts/
takze staci vhodne pouzit nazvy.
font nmsbd.ttf neobsahuje vsechny ceske znaky a nmsbd2.ttf je na tom podobne, doporucuju fonty sathnout do PC a prohlidnout me tam nejvic sedi prave ten freesans.ttf
Jinak zatim nejlepsi enigma2 pro hdbox 9200
- galm
PKT HAARP v3a
http://www.2shared.com/file/H5OCmyWc/P ... Image.htmlImage is designed for installation in USB device
Support receiver: SF1018
Kernel stm24-207
- [e2 nightly-0]introduce 3D Mode for OSD ( paint OSD twice in Side by Side or Top and Bottom )
- new BusyBox 1.19.2 (stable) config and patches
- [player191] adoptions from p179; bugfix for 710x receiver (HD channel problems)
- fix ufs910 audio on scart
- use utf8 as python default
- adapt wrong page_offset and improve mem
Added by PKT:
- fix crossEPG
- PKT KeyMapper 1.5
- add support for fake cccam
+ change only in HAARP V3a version
- picons update
- added BPanel activation in MoviePlayer ( key blue )
- added compatibility to standard non PKTeams skins
- fix dot on VFD if channel number is not available
- fix for radio mode wallpaper
- fix showing picons on channels list, when are located in /hdd/picon folder
- added /media/usb/picon to picons search folders
- 2nd generation of speed up channels zap
- add standby smooth extingushing TV
- channel list update 28-10-11
- display quality improvement
- new BluePanel 2D v3.1.19 with graphic interface:
-- added function to check update is needed
-- added color & numeric keys actions support to immidiate plugin/function/menu activation
-- 1st row - keys: 1, 2, 3, 4
-- 2nd row - keys: 5, 6, 7, 8
-- 3rd row - keys: red, green, yellow, blue
-- added menu key action support
-- added changelog information menu
-- added synchronization of local time and date from NTP server
-- added on/Off the smooth extinguish TV while switching to standby mode
- fix missing reference.dat
- fix international fonts switch in Skin Setup
- [SF1018/SF1008/SF1008+] fix cardreader driver
- screenshot OSD fix
- fix GS on GlassHD skin
- [SF1008+] fix deepstandby
- [SF1008+] now cardreader is all time active
- gombi
To Galm,
mám v3 už asi 3 dni, ale nedarí sa mi rozchodiť oscam 5961. Vo v2 mi aj dekodoval, ale teraz oscam naštartuje a nedekoduje.
Kartu mám 0D03. Asi som dal iný config. Ak môžeš pomôž prosím.
Táto E2 sa mi veľmi páči, je rýchla, veľmi rýchlo a ľahko som nakonfiguroval oba tunery. Beží motor aj prepínač diseqc AB.
Vopred ďakujem G.
Vopred ďakujem G.
Openbox X-770CIPVR
- galm
Zdravim,
ja som ju zatial len narychlo hodil na USB a otestoval nastartovanie. Viac som nemal cas, nakolko som momentalne mimo SVK, tak Ti neporadim, pozriem sa na to az v pondelok 21/11.
Ale nedal sa Ti stiahnut klasicky cez managera?
- gombi
Ahojte,
podarilo sa mi v oscame rozchodiť 0D03 pomocou starého configu čo mi kedysi poskytol grantec. Skúšam, ale nedarí sa mi v oscame rozchodiť EMU. Prosím vás chlapi v akom programe sa dajú otvoriť configy, aby som si ich mohol porovnať???
Viem si ich pozrieť iba v RCC. Vopred vám ďakujem za pomoc G.
Openbox X-770CIPVR
