PKT SF1018 E2 NEBULA v1 Image
- robino2580
Vyskúšajte si novú enigmu od chlapcov z PKT http://www.2shared.com/file/2arfSn4A/PK ... Image.html
Od včera mi šlape bez problémov a musím povedať že oproti HAARP v3c je o pekný krok ďalej.
Enigma2 OpenSource SH4 Duckbox Project GIT-3448 PKT SVN-1571 NEBULA v1 Image
Support receiver: Octagon SF1018
Kernel stm24-207
Added by sh4 Duckbox Team:
- [lirc] update lirc to 0.9.0 and add patch which increases response time on spark
- fix portmap
- [directfb] fix input driver
- [p191] fix artefacts in minitv picture if watching 1080p tv channels
- [enigma2] fix skinselector bug
- [spark] fix enigma2 keymapping behaviour
- fix aotom vfd subversion error
- [python] force largefile support
- [player] propose fix for missing audio for at least one channel on bard 26 east sat which broadcasts in aac-hen (not tested)
- [spark] improve nand write speed from 5.8mb/s to 6.8mb/s by decreasing partition size, 64mb is enouth. also add padding to flash image generation to eliminate jffs2 filesystem errors due to invalid areas in partition
- [p191] fix aspect of 352x288 channels
- [add] enable rtmpdump ffmpeg
- [FORTIS_HDBOX] fix driver/frontend/stv090x
- [add] libpng-1.5.6
- [busybox] - update to 1.19.4
- [aotom] - small syntax fixes
- deactivate manifester fix only for 576i
- [libeplayer3] fix externel subs segfault
- [boost] - Update to v1.49.0
Added by PKT:
[ALL] add PKT Hdd Manager v1.1
- automount support
- manual mounting of 10 defined points to /media
[ALL] add PKT Backup Manager v1.5
- change backup to /hdd/backup location
- quick backup of e2, settings, emu, network, crossepg
- full backup of whole image
[ALL] add PKT SMB Server Manager v1.2
[ALL] add PKT VPN Client Manager v0.7
[ALL] add PKT DLNA Manager v1.1
[ALL] add PKT Auto DeepStandby
[ALL] add PKT Video Setup ( brightness, saturation, tint )
[ALL] add PKT FrontPanel Setup 1.2
- fan speed control for ipbox 9900 and ufs922
- VFD brightness
- LED ON/OFF
- VFD utilities
[ALL] add NetworkBrowser for CIFS/NFS management
[ALL] add net patch in /media for CIFS/NFS manager
[ALL] Network changes:
- code optimalization
- fix more bugs
- fix wifi network start
- reorganization WiFi Menu,
- add all WiFi adapter setup to one place
- add support for rt5370 wifi drivers
- fix network setup at first start
[ALL] reorganization of BluePanel: Mount Manager replaced by Mount Center Menu
[ALL] reorganization of Multimedia Menu in BluePanel
[ALL] fix HelpMenu
[ALL] add missing WebBouquetEditor
[ALL] swap size changed 128 -> 64
[ALL] EPG data preserve, to restore after system crash like GS or hard reset.
[ALL] progress fix
[ALL] remove VidBrowser
[ALL] change hard reset code to OK->0->0->0->0 sequence. After activation appears info on VFD - to be sure it was user call
[ALL] remove Moderate Standby
[ALL] added DD Subtitle Player support to new version of KeyMapper
[ALL] fix BitrateViewer
[ALL] DD SubtitlePlayer updated to v.3.09 and added support in KeyMapper
[ALL] VFD in standby fix for days names ( native only for Polish and German, other languages use English, cause of national signs )
[ALL] HDD Temperature fix - process starts only if activated in SkinSetup
[ALL] add WebMedia 5.0
[ALL] GraphMultiEPG - close plugin after zap channel ( key OK pressed)
[ALL] fast AspectRatio switch - added OSD info
[ALL] some fixes for DVDPlayer -now DVDPlayer should work on SD and HD skins
[ALL] fix MyTube
[ALL] add CEControl plugin - only on STI7111 STI7105 STB
[ALL] fix FTDI & PL2303 status display
[ALL] remove Media Center from BP, now available only from download
[ALL] fix EXIT in keymap
[ALL] fix Timeshift - 4:3 channels : restore aspect ratio after TS activation from the letterbox format
[ALL] add 1080p50 mode should work on STI7105, STI7111, STI7110 especially: SF1028, UFS912, HS7810A, HS7110
[ALL] BP added to main menu
[ALL] update PKT FEED - group in categories
[IP9900] VFD REC, HD, Dolby icons fix. REC icon blink On/Off
[IP9900] fix TXT
[IP9900] clear VFD incons on startup.
[IP9000] Pg Up/Dn in EPG
[IP9000] keymap for show Favourites
[IP9900] autodetect available nims for mgcamd patch
[IP900] fan absence GS fix
[UFS910] fix memory check
[UFS922] fix cooler speed setup
[SF10X8] fix evremote speed and active long keypress in SF1008SE+
[SF10X8] added SleepTimer for SLEEP key
[SF10X8] new map all keys in remote control
[SF10X8] fix VFD Icons
[SF1028] fix audio drops
[SF1028] fix multituner in flash version
[SF1008SE+/918SE+] fix playback video files
[SF1028] improve playback video files
Known issue:
- on some channels TimeShift turns off after few seconds if time of shift < 7 sec.
- if DVD player make restart GUI, run first any movies in Media Player during 5 sec and next use DVD Player
- [UFS910] instalation on some hardisk make trouble it is probably u-boot bug
- external subtitle work only by DD Subtitle Player
- Image dedicated for SF1008P SE+ will be release a couple days later
THX for Germany translate by daTa deVil
THX for Russian translate by spartak73
FTP login: root, passwd: pkteam
Kernel stm24-207
- fix portmap
Added by PKT:
- automount support
- VFD brightness
- LED ON/OFF
- VFD utilities
- fix more bugs
[ALL] fix HelpMenu
[ALL] progress fix
[ALL] fix MyTube
[IP9900] fix TXT
Known issue:
ICECRYPT S4000 (HDBOX FS9300), FW v1.11.57, Skylink ICE, OSCAM 1.20 build #6426, interný TIME-SHIFT 80GB HDD, externý NAS
Re: PKT SF1018 E2 NEBULA v1 Image
Má E2 od PKT integrované webové rozhraní s možností streamovat programy, tak jako u enigmy od AAF?
- robino2580
ano mákocosh píše:Má E2 od PKT integrované webové rozhraní s možností streamovat programy, tak jako u enigmy od AAF?
- forsajd
pekor píše:Můžeš prosím napsat postuo instalace?
postup na instalaciu multiboot najdes
viewtopic.php?f=223&t=4785
pripadne priamo tu je cely pekne spracovany navod od Granteca
viewtopic.php?f=224&t=4803
HD-BOX FS-9200 PKT E2 HYPERION , VU DUO
Skusal niekto rozbehat project-valerie na FS-9200 na tomto PKT image?
Dakujem,
Andy
Dakujem,
Andy
- gombi
7andy7 píše:Skusal niekto rozbehat project-valerie na FS-9200 na tomto PKT image?
Dakujem,
Andy
Skúšal som to rozbehať v 9300-vke na usb, ale nepodarilo sa mi to v tomto image.
Podarilo sa mi to nainštalovať v 9300-vke na usb PKT - Haarp v3c.
Projekt Valerie je hneď v hlavnom menu a po kliknutí naň sa otvorí. Spustil som v systéme synchronizáciu a potrebujem naštudovať nastavenia a ako s projektom pracovať /používať/
Čiže mám to v plienkach, ale snáď sa niekam dopracujem. S pozdravom G.
Openbox X-770CIPVR
Ahoj
nema nekdo napad proc kdyz postupuju podle navodu instalace na usb to zustane viset na tomto ??
1947426 bytes read
## Booting image at a5000000 ...
Image Name: Linux-2.6.32.28_stm24_0207
Image Type: SuperH Linux Kernel Image (gzip compressed)
Data Size: 1947362 Bytes = 1.9 MB
Load Address: 84001000
Entry Point: 84002000
Verifying Checksum ... OK
Uncompressing Kernel Image ... OK
Starting kernel console=ttyAS1,115200 root=/dev/sda1 rw mem=128m ip=192.168.150.100:192.168.150.106:192.168.150.1:255.255.255.0:AT700:eth0:off coprocessor_mem=4m@0x10000000,4m@0x10400000 rootdelay=5 nwhwconf=device:eth0,hwaddr:00:1E:B8:00:7F:39 init=/bin/devinit - 0x00000000 - 0 ...
1947426 bytes read
- robino2580
fonta píše:Ahoj
1947426 bytes read
off topic> nechcem riesit preco ti nejde nabootovat enigmu2, ale poviem ti, ze aj keby si ju nainstaloval a budes chceciet nahravat, budes mat velky problem, ktory sa do dnesneho dna neporiesil. Ak by si poslal prijimac do stand-by rezimu s programom na vertikalnej polarizaci, ked zapnes prijimac uvidis len ciernu obrazovnku a pokial neprepnes na horizontalny kanal, budes mat len ciernu obrazovku. Ak by si chcle nahrat nejaky film v stand-by a bude to film beziaci na vertikalnej polarizacii, nahra sa ti len cierny obraz. Je to problem v SH4 duck projekte, co je jadro enigmy a aj ked sme to avizovali, nevim zatial ziadne zlepsenie :-p
