cez telnet som prikazom ninstaloval plugin enigma2-plugin-feed-enigma_1.0_sh4.ipk aby som rozbehal citacku,ninstalovalo ho a v moduloch aj uz ukaze staiahnut oscam ale ani jeden co je na vyber nenainstaluje,tu je aj protokol o chybe uz 4 den neviem prist kde robím chybu
protokol
Installing enigma2-plugin-swapemus-oscam.5168 (5168) to root...
Downloading http://97.74.32.10/svn/ipk/sh4/enigma2/ ... 68_sh4.ipk
Checking your Boxtype....
Some Plugins will not work correctly on your at7000!
Boxtype: at7000 OK
checking swapstick
swapstick found....
installing Oscam 5168 to swapstick...
syncing disk
cat: can't open '/etc/.buildgroup': No such file or directory
checking OS
BusyBox v1.18.5 (2011-07-09 09:31:33 CEST) multi-call binary.
Usage: grep [-HhnlLoqvsriwFE] [-m N] [-A/B/C N] PATTERN/-e PATTERN.../-f FILE [FILE]...
Search for PATTERN in FILEs (or stdin)
Options:
-H Add 'filename:' prefix
-h Do not add 'filename:' prefix
-n Add 'line_no:' prefix
-l Show only names of files that match
-L Show only names of files that don't match
-c Show only count of matching lines
-o Show only the matching part of line
-q Quiet. Return 0 if PATTERN is found, 1 otherwise
-v Select non-matching lines
-s Suppress open and read errors
-r Recurse
-i Ignore case
-w Match whole words only
-F PATTERN is a literal (not regexp)
-E PATTERN is an extended regexp
-m N Match up to N times per file
-A N Print N lines of trailing context
-B N Print N lines of leading context
-C N Same as '-A N -B N'
-e PTRN Pattern to match
-f FILE Read pattern from file
DONT USE this IPK Package!!
Only for Image!!
preinst script returned status 1
An error ocurred, return value: 1.
Collected errors:
Aborting installation of enigma2-plugin-swapemus-oscam.5168
>>> DONE <<<
AAF-at7000:~# ipkg-cl list > /tmp/ipkg-list.tmp; echo ">>> DONE <<<";
>>> DONE <<<
AAF-at7000:~#
AAF-at7000 kde robím chybu
Diskuze o Enigmě2.
- forsajd
Re: AAF-at7000 kde robím chybu
podarilo sa mi to konecne korektne nainstalovat emus aby mi sneho instalovalo ale ked stiahnem oscam 5866 alebo 6201 a v AAF panely - Softcam panel activujem tak mi nejde nic le free programy treba este nieco stiahnut? alebo sa to este niekde inde ativuje podotykam z aaf robim prvi krar
HD-BOX FS-9200 PKT E2 HYPERION , VU DUO
- robino2580
Příspěvek od robino2580 »
forsajd, ty vôbec nečítaš fórum
pozri tu a nepotrebujes instalovat ziadne pluginy viewtopic.php?f=224&t=9373
ICECRYPT S4000 (HDBOX FS9300), FW v1.11.57, Skylink ICE, OSCAM 1.20 build #6426, interný TIME-SHIFT 80GB HDD, externý NAS
- forsajd
dal teda tam oscam ver 6145 ICE.zip ale mi ho nechce ukazat softcam paneli by som ho mohol aktyvovat ja mam AAf verziu v PKT mi to ide
- robino2580
ahaa, tak prepac ja AAF nemam, mne sa AAF enigma moc nepaci. PKT je super az na tie nestastne vertikalne programy, nemam ani paru kde by mohol byt problem
Ak chces inu verziu oscamu ako stiahnutu zo servera AAF, jednoducho len prepis binarku vo var/bin - treba dat rovnaky nazov suboru ako je tam. Ak ale chces mat inu verziu zvlast, mohol by fungovat tento postup, ktory som davnejsie uvadzal v inej sekcii:forsajd píše:dal teda tam oscam ver 6145 ICE.zip ale mi ho nechce ukazat softcam paneli by som ho mohol aktyvovat ja mam AAf verziu v PKT mi to ide
"Aj emu sa ale da manualne prekopirovat, binarka je vo var/bin (u mna oscam_5866), potom treba este prislusny subor s priponou emu (u mna oscam_5866.emu) dostat do var/etc a samozrejme konfiguraky do var/keys. Ak chcete, aby sa emu spustilo po starte, treba este upravit subor start-config vo var/etc/autostart, doplnit do prveho riadku, kde asi bude emu=off pozadovane emu (u mna emu=oscam_5866.emu)."
Samozrejme, ten subor oscam*.emu treba prislusne upravit - zmenit nazov aj obsah.
Zpět na „Diskuze E2 pro HD-BOX“
