Emu Manager Panel
Emulátory/softcamy E2
Moderátoři: schmegea, gorick, monkus
vikino Slovakia
Poděkoval: 5 krát
Poděkováno: 1 krát
Emu Manager Panel
Příspěvekod vikino » 25 říj 2010, 19:25
Quote:
Originally Posted by arcibald
and/or
enigma2-plugin-glasssysutil_2.39_mipsel.ipk
Once these are installed, you just have correct the path for the file CCcam.cfg:
SGC_menu:
From SGC panel installed the CCcam 2.14 and go to the correct path and the environment (-dC /etc/CCcam.cfg) in the startup script CCcam_2.1.4.sh:
/usr/bin/CCcam_2.1.4
/etc/CCcam.cfg
/usr/cams/CCcam_2.1.4.sh
Glasssutil:
This will install various emu in the path:
/usr/UCM_CamSrv_bin # including cccam (2.0.11) & cccam214.
The startup scripts will find them in /usr/UCM_CamSrv_script:
Cccam_Cam.sh
Cccam214_Cam.sh
Then enter here the path and the environment (-dC /etc/CCcam.cfg) and you're done.
Now you can manage your CCcam from panel with their emu_manager and having a complete list of additional features.
Thanks ... to development teams of these plugins
Regards
Naposledy upravil(a) vikino dne 25 říj 2010, 19:38, celkem upraveno 1 x.
| Clarktech ET9000 | HDD Seagate Baracuda 500GB | LNB Diavolo QUAD | SG2100 | LG LED TV |
vikino Slovakia
Poděkoval: 5 krát
Poděkováno: 1 krát
Re: Emu Manger Panel
Příspěvekod vikino » 25 říj 2010, 19:29
Po instalacii Emu managera je mozne priamo cez neho instalovat addony, alebo cez telnet:
ipkg install /tmp/kompletny_nazov_balika
priklad: ipkg install /tmp/enigma2-plugin-camd-mgcamd.1.35a_2.4-r1_mipsel.ipk a stlac enter.
predtym instalacny balik rozbaleny nakopirovat do tmp cez ftp.
Cvs emu:
Quote:
again, a big shift mower and others in the co
congratulations
those who threw the last enigma and video driver for codirane channels
here's my little contribution
cccam and mgcamd
cccam and mgcamd for azbox the plugin can start / stop / restart / cam info / autostart / desable autostart
installation
can manually via telnet but also with management software>> install local extensions>> internal flash
copy one by one file in / (that is the root of the image) to say totalcommander
upon installation, delete files or install in the order written down
and then delete one by one.
The order of installation
1.enigma2-plugin-extensions-userscripts_2.4-r4_mipsel.ipk
2.enigma2-plugin-camd-mgcamd.1.35a_2.4-r1_mipsel.ipk
3.enigma2-plugin-camd-cccam.2.1.4_2.4-r0_mipsel.ipk
4.napravi folder / var / etc for your cccam files
restart box
5.otidji the main menu plugins-user scripts user-execute script from / usr / script
there can do anything for the emu
for mgcamd course should you put in your config files if you use to cccam gbox or cs in / var / keys
6.a this is very important to put the emu radio mg_cfg for azbox with everything needed for cccam gbox or configuration
# box type
# 00 autodetect, change only if you think wrong type detected.
# 01 dbox2
# 02 dreambox
# 03 triple-dragon
# 04 relook
# 05 openbox
# 06 dreambox / mips
# 08 entered / kathrein
# 09 entered / ipbox
# 11 entered / openbox
b: {06}
so you have to make any necessary changes to your way of use in all files for mgcamd 1.35
it seems to me that mgcamd now works better than the azbox cccam but it takes longer to test.
Thanks to its author:thum:
