AzIPTV
AZBox IPTV player based on Sigma rmfp_player
It works on all AZBox receivers including Me, MiniMe, Elite, Premium, Premium+ and Ultra
How to install:
1. unpack AzIPTV.zip
2. enter in AzIPTV /usr/lib/enigma2/python/Plugins/Extensions/ and there You will see AzIPTV folder,
3. connect by FTP to your receiver and copy AzIPTV folder to
/usr/lib/enigma2/python/Plugins/Extensions/ and then
4. reboot your receiver and after that You will see AzIPTV in main menu
How to edit channel list:
Edit .m3u files located /usr/lib/enigma2/python/Plugins/Extensions/AzIPTV/Lists and add streams there
Short Info about AzIPTV:
AzIPTV - in his root folder is located config file - for now only settings for pre-buffering:
# Buffer size - must be >= 128
<buffersize>512</buffersize>
Folder Lists have .m3u list of channels and bouquets (list of bouquets)
0.m3u - is All channels
1.m3u - first bouqeuet
2.m3u - second bouqeuet
Picons folder have smal png pictures - standard Picons
Name of Picon file must be same as name of channel in *.m3u ch list
If Picon dont exist - AzIPTV load default picon : picon_default.png (AZBox Logo)
Plugin is easy for use , have Menu - for picture size/strech
Up, Down, Left, Right, OK ... standard keys in use
http and rtsp work ok (but only for WMA/WMV not for other codecs) user can use local proxy for other - standard way/solution for rstp - through rtmpgw and so on.
Diskusia
Channel list pre AzIPTV
:arrow:Download AzIPTV OAM
EDIT:
- test1 v OAM, verzia AzIPTV OAM OK
- test2 v OpenRSI 3.0, verzia AzIPTV pre OpenRSi 3.0, obraz sa spustil az po pridani suboru rtmpgw (v prilohe) do usr/bin (atributy na 755 a restart)
AzIPTV
Pluginy a utility E2
- gorick
- Mazák
Zpět na „Pluginy a utility E2“
