TYto informace jsou odvislé od verze firmware ..
MKV Media Files Limitation:
MKV can be packaged with different AUDIO and VIDEO format, however, this production can not support the full video/aduio format;
Here to list the detail Video and Audio format supported:
1.1 VIDEO
1.1.1. MPEG-1 and MPEG-2 main profile at main and high level, including
non-standard resolution;
1.1.2.MPEG-4 visual simple profile up to level 5 and advanced simple profile
level 5 including non-standard bit rate;
1.1.3.MPEG4 AVC / H.264 (ISO/IEC 14496-10). Baseline profile up to level 3
at standard definition and including non-standard bit rates and
resolutions at standard definition. Main profile up to level 4. High
profile up to level 4. Arbitrary frame size as specified in the
standard, compressed bit stream in byte stream format;
1.1.4.VC1 elementary streams (SMPTE 421M), simple profile up to medium
level, main profile up to high level, advanced profile up to level 3,
non-standard bit rates and resolutions;
1.1.5.DivX 3.11, DivX 4, DivX 5, DivX 6;
1.2: Audio
1.2.1.MPEG1 layer 1 and layer 2 with variable and constant bit rates up to 448 Kbits/s;
1.2.2.MPEG2;
1.2.3.MPEG4 AAC and MPEG4 AAC-HE (AAC+);
1.2.4.Dolby Digital (AC-3) with bit rates up to 640 Kbits/s;
1.2.5.LPCM up to 48 KHz
1.2.6.MP3
1.3 Limitation:
1.3.1 If the Audio/Video format are out of this standard, for example some MKV files coded with MPEG-4 level 5.1 can not be surpported;
1.3.2 Memory Limitation: H/W with 128M Memory will limit to play some compelex midia files, if the MKV Ref Frames are more that 8, it will not allowed to play it.
Co lze přehrávat ,,, MKV specifikace apod
Utility pro přijímač Dreamsky NXP256 HD
Zpět na „Utility Dreamsky NXP256 HD“
