http://product-us.review/electronics-sc ... -card.html
muze mi nekdo pomoc ???
mam ho pripojeny do xtrend 9200 s openpli4 do esata portu
ale vidi bohuzel jen jeden hdd
je tu nejaky linuxak co poradi???
vypis dmesg:
root@et9x00:~# dmesg
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
cfg80211: Calling CRDA to update world regulatory domain
Switching to clocksource upg
FS-Cache: Loaded
NET: Registered protocol family 2
TCP established hash table entries: 4096 (order: 3, 32768 bytes)
TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
TCP: reno registered
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
NET: Registered protocol family 1
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
PCI: CLS 0 bytes, default 64
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
fuse init (API version 7.20)
msgmni has been set to 567
io scheduler noop registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x10400b00 (irq = 22) is a 16550A
serial8250.0: ttyS1 at MMIO 0x10400b40 (irq = 66) is a 16550A
serial8250.0: ttyS2 at MMIO 0x10400b80 (irq = 67) is a 16550A
loop: module loaded
sata_brcmstb 0000:01:00.0: version 4.0
__clk_enable: sata [1]
PCI: Enabling device 0000:01:00.0 (0000 -> 0003)
sata_brcmstb 0000:01:00.0: setting latency timer to 64
scsi0 : sata_brcmstb
scsi1 : sata_brcmstb
ata1: SATA max UDMA7 mmio m4096@0x10510000 port 0x10510000 irq 42
ata2: SATA max UDMA7 mmio m4096@0x10510000 port 0x10510100 irq 42
Broadcom STB NAND controller (BrcmNand Controller)
bcmemac: Broadcom STB 10/100 EMAC driver v3.0
bcmemac: registered interface #0 at 0x10080000 as 'eth0' (00:16:b4:05:a0:ac)
bcmemac: not registering interface #1 at 0x10090000 (no PHY detected)
usbcore: registered new interface driver zd1201
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
__clk_enable: usb [1]
ehci-brcm ehci-brcm.0: Broadcom STB EHCI
ehci-brcm ehci-brcm.0: new USB bus registered, assigned bus number 1
ehci-brcm ehci-brcm.0: irq 62, io mem 0x10480300
ehci-brcm ehci-brcm.0: USB 0.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
ehci-brcm ehci-brcm.1: Broadcom STB EHCI
ehci-brcm ehci-brcm.1: new USB bus registered, assigned bus number 2
ehci-brcm ehci-brcm.1: irq 57, io mem 0x10480500
ehci-brcm ehci-brcm.1: USB 0.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
ohci-brcm ohci-brcm.0: Broadcom STB OHCI
ohci-brcm ohci-brcm.0: new USB bus registered, assigned bus number 3
ohci-brcm ohci-brcm.0: irq 63, io mem 0x10480400
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 2 ports detected
ohci-brcm ohci-brcm.1: Broadcom STB OHCI
ohci-brcm ohci-brcm.1: new USB bus registered, assigned bus number 4
ohci-brcm ohci-brcm.1: irq 64, io mem 0x10480600
hub 4-0:1.0: USB hub found
hub 4-0:1.0: 2 ports detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
usbcore: registered new interface driver btusb
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
TCP: cubic registered
NET: Registered protocol family 17
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Bluetooth: HIDP socket layer initialized
Key type dns_resolver registered
EBI CS1: setting up NAND flash (primary)
mtd->oobsize=0, mtd->eccOobSize=0
NAND_CS_NAND_XOR=00000000
B4: NandSelect=50000200, nandConfig=16152300, chipSelect=1
brcmnand_read_id: CS1: dev_id=ecda1095
After: NandSelect=50000200, nandConfig=16152300
Block size=00020000, erase shift=17
NAND Config: Reg=16152300, chipSize=256 MB, blockSize=128K, erase_shift=11
busWidth=1, pageSize=2048B, page_shift=11, page_mask=000007ff
timing1 not adjusted: 5363444f
timing2 not adjusted: 00000fc6
eccLevel=15, 1Ksector=0, oob=16
nbrBitsPerCell=2, cellinfo=0, chip->cellinfo=00000000
BrcmNAND mfg ec da Samsung K9F2G08U0A 256MB on CS1
Found NAND on CS1: ACC=d7ff1010, cfg=16152300, flashId=ecda1095, tim1=5363444f, tim2=00000fc6
BrcmNAND version = 0x0302 256MB @00000000
Found NAND flash on Chip Select 1, chipSize=256MB, usable size=256MB, base=0
brcmnand_scan: B4 nand_select = 50000200
brcmnand_scan: After nand_select = 50000200
page_shift=11, bbt_erase_shift=17, chip_shift=28, phys_erase_shift=17
Brcm NAND controller version = 3.2 NAND flash size 256MB @10000000
ECC layout=brcmnand_oob_bch4_4k
brcmnand_scan: mtd->oobsize=64
brcmnand_scan: oobavail=50, eccsize=512, writesize=2048
brcmnand_scan, eccsize=512, writesize=2048, eccsteps=4, ecclevel=15, eccbytes=3
-->brcmnand_default_bbt
brcmnand_default_bbt: bbt_td = bbt_main_descr
Bad block table Bbt0 found at page 0001ffc0, version 0x01 for chip on CS1
Bad block table 1tbB found at page 0001ff80, version 0x01 for chip on CS1
nand_read_bbt: Bad block at 0x00460000
nand_read_bbt: Bad block at 0x06a00000
nand_read_bbt: Bad block at 0x08c40000
nand_read_bbt: Bad block at 0x09740000
nand_read_bbt: Bad block at 0x09cc0000
nand_read_bbt: Bad block at 0x0e900000
Adjust partition complete size from entire device to ff00000 to avoid overlap with BBT reserved space
Adjust partition rootfs size from entire device to f900000 to avoid overlap with BBT reserved space
Creating 3 MTD partitions on "brcmnand.0":
0x000000000000-0x00000ff00000 : "complete"
0x000000000000-0x000000600000 : "kernel"
0x000000600000-0x00000ff00000 : "rootfs"
PM: CP0 COUNT/COMPARE frequency depends on divisor
UBI: attaching mtd2 to ubi0
ata1: SATA link down (SStatus 4 SControl 300)
usb 2-1: new high-speed USB device number 2 using ehci-brcm
hub 2-1:1.0: USB hub found
hub 2-1:1.0: 4 ports detected
usb 2-1.2: new full-speed USB device number 3 using ehci-brcm
ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
ata2.00: ATA-8: WDC WD10EACS-00D6B0, 01.01A01, max UDMA/133
ata2.00: 1953525168 sectors, multi 0: LBA48 NCQ (depth 0/32)
ata2.00: configured for UDMA/133
scsi 1:0:0:0: Direct-Access ATA WDC WD10EACS-00D 01.0 PQ: 0 ANSI: 5
sd 1:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/931 GiB)
sd 1:0:0:0: Attached scsi generic sg0 type 0
sd 1:0:0:0: [sda] Write Protect is off
sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sda: sda1
sd 1:0:0:0: [sda] Attached SCSI disk
UBI: scanning is finished
UBI: attached mtd2 (name "rootfs", size 249 MiB) to ubi0
UBI: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
UBI: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
UBI: VID header offset: 2048 (aligned 2048), data offset: 4096
UBI: good PEBs: 1987, bad PEBs: 5, corrupted PEBs: 0
UBI: user volume: 1, internal volumes: 1, max. volumes count: 128
UBI: max/mean erase counter: 11/4, WL threshold: 4096, image sequence number: 1811753357
UBI: available PEBs: 0, total reserved PEBs: 1987, PEBs reserved for bad PEB handling: 35
ALSA device list:
No soundcards found.
Warning: unable to open an initial console.
UBI: background thread "ubi_bgt0d" started, PID 49
UBIFS: background thread "ubifs_bgt0_0" started, PID 50
UBIFS: mounted UBI device 0, volume 0, name "rootfs"(null)
UBIFS: LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
UBIFS: FS size: 245952512 bytes (234 MiB, 1937 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs)
UBIFS: reserved for root: 0 bytes (0 KiB)
UBIFS: media format: w4/r0 (latest is w4/r0), UUID C57311B5-0A38-42BE-A4C5-774B27E7FA76, small LPT model
VFS: Mounted root (ubifs filesystem) on device 0:10.
devtmpfs: mounted
Freeing unused kernel memory: 260k freed
usbcore: registered new interface driver tpm
dvb: module_layout: kernel tainted.
Disabling lock debugging due to kernel taint
Console: switching to colour frame buffer device 160x45
input: dreambox remote control (native) as /devices/virtual/input/input0
input: dreambox advanced remote control (native) as /devices/virtual/input/input1
DVB: registering new adapter (dvb0)
platform dvb0.0: DVB: registering adapter 0 frontend 0 (DVB-S2)...
platform dvb0.0: DVB: registering adapter 0 frontend 1 (DVB-S2)...
input: front panel as /devices/virtual/input/input2
Console: switching to colour dummy device 80x25
NET: Registered protocol family 10
ata2: exception Emask 0x10 SAct 0x0 SErr 0x4040000 action 0xe frozen
ata2: hotplug
ata2: SError: { CommWake DevExch }
ata2: hard resetting link
ata2: SATA link down (SStatus 4 SControl 300)
ata2: limiting SATA link speed to 1.5 Gbps
ata2: SATA link down (SStatus 4 SControl 310)
ata2.00: disabled
ata2: EH complete
ata2.00: detaching (SCSI 1:0:0:0)
sd 1:0:0:0: [sda] Synchronizing SCSI cache
sd 1:0:0:0: [sda]
Result: hostbyte=0x04 driverbyte=0x00
sd 1:0:0:0: [sda] Stopping disk
sd 1:0:0:0: [sda] START_STOP FAILED
sd 1:0:0:0: [sda]
ata2: exception Emask 0x10 SAct 0x0 SErr 0x0 action 0xe frozen
ata2: hotplug
ata2: link is slow to respond, please be patient (ready=0)
ata2: COMRESET failed (errno=-16)
ata2: EH complete
sda: sda1
root@et9x00:~#
SATA 1 to 5 Port Multiplier Card
