HDF-Teamimage
Images pro přijímač Clarke-Tech ET9000 HD , Xtrend ET9x00
HDF-Teamimage
HDF-Teamimage v2 23.01.2011
ET9000 HDF-Teamimage based on OpenPLi2.0 - 23.01.2011
20110123
-fancontrol: 'auto' mode (fan inactive when in standby, and no active recordings)
-report more realistic SNR percentage
-improve aspect ratio detection
-VOB improvements
-use analog audio output for external pip (2nd tv): use /dev/dvb/adapter0/audio1
-fix mute on ac3 passthrough
Clark-tech ET9000 Image v2 based as always on the proven PLi.
ET9000 folder on a USB flash drive to unpack, plug in and reboot the receiver to switch.
Either the image is in the display itself will be offered or you have to think when you start the menu button.
After flashing automatically installs an addon pack.
As long as the on-screen "First Boot please wait ". Depending on the line takes a few minutes.
So do not be impatient or cancel.
When the box is not on the Internet, this process is skipped.
The First Boot package can be installed separately later in the HDF-Toolbox.
In the First Boot EMU's are Picon's package included plugin's, Skin's.
General information:
Red - Timer Editor
Red Cross - Bitrate Viewer
Green - submenu
Green Cross - free
Yellow - Timeshift
Yellow Cross - Mount info
Blue - Extensions
Blue Cross - Zap-History
Info - Cool Multi Guide
Long Guide - Channel Info
Info Lang - current station info
Exit - Virtual Zap with PIP
Channel + / - Express zap
D-pad up / down - Channel Selection
D-pad left / right - quick zap
VKEY - Access to recorded movies
EMUs and softcams:
The configs are in / var / keys and in / etc.
Download: HDF-Teamimage v2
Re: HDF-Teamimage
Par screenshotov z img HDFreaks v2 s aktivnym skinom hd_line_tv pro/1
Re: HDF-Teamimage
HDF-Teamimage V3 vom 05.06.2011
ET9000 HDF-Teamimage based on OpenPLi2.0 vom 05.06.2011
Red - Timer Editor
Green - submenu
Green Cross - free
Yellow - Timeshift
Blue - Extensions
Info - current channel EPG
Guide - Cool Multi Guide
Info Lang - Zap History
EMUs and softcams:
Drivers are updated to 16.05.2011
Thanks to the HDF team!
Download (50,5 MB)
Re: HDF-Teamimage
HDF-Teamimage v3.1 /11.06.2011
ET9000 HDF-Teamimage based on OpenPLi2.0 vom 11.06.2011
Dôležité!!!
Pred instalaciou tohoto image je potrebne najskor instalovat novy bootloader z 19.5.2011!.
viewtopic.php?f=288&t=7248
Update V3.1:
- komplett aktualisiert Stand 11.06.2011 (Plugins, Enigma, Picons, Senderliste)
- Cool TV Guide 4.0.0
- Im MultiQuickbutton können jetzt alle Tasten verwendet werden (soweit sinnvoll)
- Fullimage mit ~85MB (neuer Bootloader ist Pflicht)
Download
Re: HDF-Teamimage
HDF-Teamimage v4 30.07.2011
ET9000 HDF-Teamimage v4 based on OpenPLi2.1 vom 30.07.2011
Clark-tech ET9000 HDF Team Image v4 based as always on the proven PLi only this time OpenPLi 2.1.
ET9000 folder on a USB stick unpack, plug in and reboot the switch at the receiver.
Either the image is in the display itself will be offered or you have to hold down the Menu key on startup.
Red - Timer Editor
Red Cross - free (multi-button quick change over)
Green - submenu subchannels
Green Cross - free (multi-button quick change over)
Yellow - free (multi-button quick change over)
Long Yellow - free (multi-button quick change over)
Blue - Extensions
Blue Cross - Plugins
Info Cross - Cool music guide
Guide long - Cool Easy Guide
Channel + / - quick zap
Control Pad right / left - quick zap
<> - Zap History
File List - Movie List
Playlist - Media Player
Timeshift - will start immediately shift
VKEY - access to various installed plugins
VKEY long - TV Chart Plugin
Mark - Timer Editor
Search - Current Channel EPG
Pip - Pip Pip and Zap mode selection
Changelog:
- Driver dated 07/07/2011 http://www.et-view.com/download/drivers/
- Changes OpenPLi 2.1
- Enigma2: http://openpli.git.sourceforge.net/git/g ... gma2 a = shortlog
- OpenEmbedded: http://openpli.git.sourceforge.net/git/g = refs/heads/2.1 ...
- Plugins: http://openpli.git.sourceforge.net/git/g ... gins, a = shortlog
contained Plugins / Addons:
- SHOUTcast recording with a functioning
- Multi-button quick-date version
- YTTrailer (TV, text, radio button in the EPG Overview of current trailer for the EPG to see entry)
- Youtube player (also as a basis for YTTrailer)
- Sports Portal (Formula 1 and football)
- TV charts (current rates of TV Charts User)
- Weather Information
- Bitrate Viewer (red and long VKEY)
- Cool Multi-Guide 4.0.0
Important!
Current boot loader must be installed.
Bootloader in the Annex to download and install via USB flash drive as an image. The boot loader in the appendix is ​​the current loader which supports up to 100MB flash and the splash screen has.
Download
Re: HDF-Teamimage
HDF-Teamimage v4.1 01.08.2011
ET9000 HDF-Teamimage v4.1 based on OpenPLi2.1 vom 01.08.2011
Pred instalaciou image instalujte najskor Bootloader_ET9000_splash z v4.
Download
Re: HDF-Teamimage
ET9x00 HDF-Team Image v4.2 based on OpenPLi2.1 on 16/10/2011
Clark-tech ET9x00 HDF Team Image v4.2 based as always on the proven PLi 2.1.
Et9x00 folder on a USB stick unpack, plug in and reboot the receiver.
Anyone who has problems should try flashing the folder on the USB stick to rename in 'ET9X00 "(capital X).
The plugin "Auto Install" should be disabled in the old image and it should not use old backups on disk or flash drive to be present. Otherwise will be automatically restored.
For the image of the current boot loader is needed. The original boot loader from here: clarke-xtrend-support.com...
In principle, there is an updated HDF 4.1 on the new structure with current updates and drivers.
If the setup is no tuning done a prepared list of channels is included.
Instructions for use:
Red - Timer Editor
Blue - Extensions
Info Cross - Cool Single Guide
<> - Zap-History
Timeshift - timeshift starts immediately
VKEY - access to various installed Plugins
VKEY long - TV plugin Charts
Mark - Timer Editor
Search - EPG of current transmitter
Pip - Pip and Pip Zap mode selection
Changelog:
- Enigma2: openpli.git.sourceforge.net/git/g gma2 ...
- OpenEmbedded: openpli.git.sourceforge.net/git/g ...
- Plugins: openpli.git.sourceforge.net/git/g ...
contained plugins / addons:
- Multi QuickButton current version, adapted slightly
- YTTrailer (TV, text, radio button in the EPG Overview -> Info button to see trailer for the current EPG entry)
- Sports portal (Formula 1 and football)
- Live football
- Dream Explorer
- InfoBarTunerState
- Menusort
- DTS downmix plugin
- TV charts (current rates of TV Charts Users)
- Weather Plugin (Foreca, weather information)
- Bitrate Viewer (long red and VKEY)
- Multi Cool Guide 5.0.0
- Oscam-experimental with prepared configs for the Card Reader
Important!
Bootloader in Appendix download and install a USB stick as an image. The boot loader in the appendix is ​​the current loader et9x00 support.
:arrow: Download
Re: HDF-Teamimage
HDF-Teamimage v4.4 27.11.2011
ET9x00 HDF-Teamimage v4.4 based on OpenPLi2.1 vom 27.11.2011
So hier dann mal das aktuelle Bastelimage 4.4 von uns.
Es handelt es um das HDF-Teamimage 4.2 komplett aktualisiert.
Update Stand ist vom 27.11.2011 12:24:45 Uhr.
Enthalten sind die aktuellsten Versionen der installierten Plugin und das HbbTV Plugin.
Außerdem ist das neue OpenWebif dabei. Zu erreichen über http://IP-Adresse_der_Box:8088.
Skin ist der army.pli in einer gemoddeten Version mit HbbTV Anzeige und ein paar anderen kleinen Sachen.
Die Picons können über die HDF-Toolbox nachinstalliert werden.
Bedienung wie hier beschrieben: HDF-Teamimage v4.2 16.10.2011
- Timeshift Pfad auf default eingestellt
- aktuelle Updates PLi und Plugins
- HbbTV auf ARD & ZDF funktioniert wieder
- Skin army.mod Änderungen
- aktuellste Version vom OpenWebif
Viel Spass damit.
:arrow: Download
Re: HDF-Teamimage
HDF-Teamimage v4.5 23.12.2011
ET9x00 HDF-Teamimage v4.5 based on OpenPLi2.1 vom 23.12.2011
So hier dann mal das aktuelle Image v4.5 von uns.
Es handelt es um das HDF-Teamimage 4.4 komplett aktualisiert.
Update Stand ist der 23.12.2011 um 11:10:53 Uhr. Linux mips 3.1.0 #1 SMP Sun Dec 18 02:02:08 CET 2011.
Enthalten sind die aktuellsten Versionen der installierten Plugin und das HbbTV und Weblinks Plugin.
Die aktuellen Picons von Licher können über die HDF-Toolbox nachinstalliert werden.
Bedienung des Images wie hier beschrieben: HDF-Teamimage v4.2 16.10.2011.
Weitere Informationen bitte in der ET9x00 FAQ und Linksammlung nachlesen.
- Treiber vom 12.12.2011 (DTS Downmix, AC3 passthrough etc.)
- Speedfix in den Menüs
- HbbTV Plugin in der neuen Version 1.1
- Neues Plugin Weblinks mit einigen angepassten Links.
- WebradioFS aktuelle Version
- Webmedia 4.2
- Oscam Experimental 1.20 build#6121
- Timeshift Pfad auf default eingestellt.
- aktuelle Updates vom PLi und Plugins.
- UPnP Server MediaTomb integriert (Beschreibung dazu: ET9x00 UPnP Server Mediatomb).
- UPnP AV Client djmount integriert (UPnP Server sind dann mit dem MediaPlayer unter /media/upnp zu finden).
- aktuelle oscam, cccam und scam versionen integriert.
- Skin army.mod kleine Änderungen.
- aktuellste Version vom OpenWebif.
:arrow: Download
Re: HDF-Teamimage
HDF-Teamimage v4.6 14.01.2012
ET9x00 HDF-Teamimage v4.6 based on OpenPLi2.1 vom 14.01.2012
Clark-tech/Xtrend ET9x00 HDF Teamimage v4.6 basierend wie immer auf dem bewährten PLi 2.1.
Den Ordner et9x00 auf einen USB-Stick entpacken, anstecken und den Receiver neustarten.
Wer Probleme beim Flashen hat sollte versuchen den Ordner auf dem USB Stick in "ET9X00" (großes X) umzubennen.
Das Plugin "Autoinstall" sollte im alten Image deaktiviert sein und es sollten keine alten Backups auf Platte oder Stick vorhanden sein. Sonst wird automatisch wiederhergestellt.
Für das Image wird der aktuelle Bootloader benötigt. Der original Bootloader ist von hier: http://www.clarke-xtrend-support.com/Fo ... Bootloader
Im Prinzip ist es ein HDF 4.5 auf die neue Struktur aktualisiert mit aktuellen Updates und Treibern.
Wenn beim Setup kein Sendersuchlauf gemacht wird ist eine vorbereitete Senderliste enthalten.
Hinweise zur Bedienung:
Rot - HbbTV
Rot Lang - Timer Editor
Grün - Submenü Unterkanäle
Grün Lang - frei (Änderung über MultiQuickButton)
Gelb - frei (Änderung über MultiQuickButton)
Gelb Lang - frei (Änderung über MultiQuickButton)
Blau - Erweiterungen
Blau Lang - Plugins
Info - aktuelles Sender EPG
Info Lang - Cool Single Guide
Guide lang - frei (Änderung über MultiQuickButton)
Exit - frei (Änderung über MultiQuickButton)
Programm +/- schnelles zappen
Steuerkreuz hoch/runter - Channel Selection
Steuerkreuz rechts/links - schnelles zappen
< > - Zap-History
Filelist - Enhanced Movie Center
Timeshift - startet sofort Timeshift
Vkey - Enhanced Movie Center oder frei belegbar
Vkey lang - frei (Änderung über MultiQuickButton)
Mark - Weblinks Plugin
Search - EPG aktueller Sender mit OK Auswahl auf die Sendung AutoTimer
Pip - Auswahl Pip und Pip Zap Modus
Changelog:
- Änderungen OpenPLi 2.1 http://twitter.com/#!/openpli
- Enigma2: http://openpli.git.sourceforge.net/git/ ... a=shortlog
- openembedded: http://openpli.git.sourceforge.net/git/ ... a=shortlog
- Plugins: http://openpli.git.sourceforge.net/git/ ... a=shortlog
Änderungen im Image 4.6:
- alle PLi Updates bis 14.01.2012
- aktuelle Kernel 3.1.0 #1 SMP Fri Jan 13 18:51:46 CET 2012 mips GNU/Linux
- Media Player wieder enthalten
- DVD Player wieder enthalten
- aktuelle Version des AutoTimers enthalten
- Seekbar Plugin angepasst (vorspulen mit links/rechts in Videos und Aufnahmen)
- aktuelles army.mod Skin
- Oscam ymod 18 t23
- funktionierender Dreamexplorer und Filebrowser
- überarbeiteter Softcam Cardserver Manager
- Simple Unmount (auf Wunsch)
- aktuelle Version Webbrowser und Weblinks.
- ET Portal (auf der Mark Taste)
- eCasa (Google Picasa Bild Betrachter)
- LCD4Linux (vorkonfiguriert nur das Pearl Display anklemmen wenn es gehackt ist)
- OSD 3D Setup (automatisches Umschalten auf 3D wenn ein 3D Sender gewählt wird)
- Open Webif auf Port 80 (das alte Webif ist auf Port 8088 )
- ansonsten die bewährten Sachen aus den Images davor.
Wichtig!!!
Aktueller Bootloader muss installiert sein.
Der Bootloader ist von hier: http://www.clarke-xtrend-support.com/Fo ... Bootloader
Bootloader im Anhang herunterladen und per USB-Stick wie ein Image installieren. Der Bootloader im Anhang ist der aktuelle Loader mit et9x00 Unterstützung.
:arrow: Download
Re: HDF-Teamimage
ET9x00 HDF Teamimage v4.7
ET9x00 HDF-Teamimage v4.7 based on OpenPLi2.1 vom 10.02.2012
Clark-tech/Xtrend ET9x00 und ET6x00 HDF Teamimage v4.7 basierend wie immer auf dem bewährten PLi 2.1.
Den Ordner et9x00/et6x00 auf einen USB-Stick entpacken, anstecken und den Receiver neustarten.
Im Prinzip ist es ein HDF 4.6 mit aktuellen Updates und Treibern.
Rot - HbbTV
Blau Lang - Plugins
< > - Zap-History
Changelog:
Änderungen im Image 4.7:
- alle PLi Updates bis 10.02.2012
- aktuelle Kernel Linux et9x00 3.1.0 #1 SMP Wed Feb 8 02:02:49 CET 2012 mips GNU/Linux
- Media Player enthalten
- DVD Player enthalten
- Oscam ymod 18 t23
- TuxBox Commander
Wichtig!!!
:arrow: Download ET9x00 HDF v4.7 bei Mediafire
Re: HDF-Teamimage
ET9x00 HDF Teamimage v4.8
ET9x00 HDF-Teamimage v4.8 based on OpenPLi2.1 vom 04.04.2012
Clark-tech/Xtrend ET9x00 HDF Teamimage v4.8 basierend wie immer auf dem bewährten PLi 2.1.
Beim ET6000 warten bis die grüne und orange LED leuchten. Dann Taste nach oben an der Front drücken und warten bis der Flash erfolgt ist.
Das ET6000 Image ist ein ET9x00 Image mit angepassten Treibern und Hostname. Ansonsten sind die beiden Images gleich.
Das 4.8 wurde komplett runderneuert, aufgeräumt und ein bissel entkernt.
Ich habe versucht alle Wünsche aus dem 4.7 Thread umzusetzen.
Es sind keine EMU, Softcams und Configs enthalten. Die können aber bequem über den HDF-Downloader installiert werden.
Rot - HbbTV
Rot Lang - Bitrate Viewer
Grün Lang - Wechsel 16:9, 4:3 Pillarbox,PanScan
Gelb - Audio Einstellungen
Blau - Erweiterungsmenu
Blau Lang - Erweiterungen
Info - Senderinfo
Info Lang - Einfacher EPG des Senders
Guide lang - Zap-History
Ok Lang - Virtual Zap
0 - Senderwechsel zwischen aktuellem und letzter Sender
< > - Sender History vor und zurück
Playlist Lang - frei (Änderung über MultiQuickButton)
Vkey - Aufnahmen mit Enhanced Movie Center
Vkey lang - EPG Plugins
Search - EPG Suche
Search Lang - Softcam Cardserver Manager
Menü Lang - EPG Erweiterungen
TV Lang - TVCharts
Radio Lang - SHOUTcast oder WebradioFS
Changelog:
Änderungen im Image 4.8:
- alle PLi Updates bis 06.04.2012.
- aktuelle Kernel Linux et9x00 3.2.2 #1 SMP Tue Mar 20 23:00:16 CET 2012 mips GNU/Linux (ohne Pinguine zur Zeit)
- Aktuelle Version HDF-Toolbox mit HDF-Downloader.
- Aufnahmen aus dem Deep Standby per Timer (auto) sollten jetzt funktionieren.
- Uhrzeit vom Transponder wenn die Box offline ist (wenn die HDF-Toolbox installiert ist und bleibt).
- Treiber vom 04.02.2012 (wegen DTS Downmix, die neuen Treiber können bei Bedarf über den HDF Downloader installiert werden).
- Media Player enthalten mit EMC 3.0.0 Frontend und PLi Fix.
- DVD Player enthalten.
- aktuelle Version des AutoTimers enthalten.
- Seekbar Plugin angepasst (vorspulen mit links/rechts in Videos und Aufnahmen).
- aktuelles army.mod Skin.
- überarbeiteter Softcam Cardserver Manager.
- Simple Unmount (auf Wunsch).
- ET Portal (auf der Mark Taste).
- OSD 3D Setup (automatisches Umschalten auf 3D wenn ein 3D Sender gewählt wird).
- Open Webif auf Port 80 (das alte Webif kann bei Bedarf gestartet werden).
- Bundesliga und Ligaticker (Sport Portal über den HDF Downloader).
- IMDb und OFDb
- Partnerbox Mod
- YYtrailer (in der Single EPG Liste lange I Taste auf die TV Taste drücken für Treiler von Youtube).
- NFS Server, uShare und djmount als DLNA/upnp Client.
- Full-Backup 9.1 von Pedro_Newbie.
Anmerkung!
Der Clean Kernel ist der jetzt aktuelle vom 20.03.2012 ohne Pinguine. Im HDF 4.8 wird der automatisch mit geflasht.
Der ist also nur für Leute interessant die beim 4.7 bleiben und regelmäßig das PLi und Spinnerupdate machen.
Wichtig!!!
:arrow: Download ET9x00 HDF v4.8 bei Mediafire
Re: HDF-Teamimage
ET9x00 HDF Teamimage v4.9
ET9x00 HDF-Teamimage v4.9 based on OpenPLi2.1 vom 08.04.2012
Änderungen vom Image 4.8 zum Image 4.9:
- Kernel 3.3.0 mit aktuellen Treibern, PLi Update Stand 08.04.2012 (zur Zeit mit Pinguinen)
- Fritzcall Plugin entfernt
- Fonts für army.mod hinzugefügt
- libcrypto-compat für MGCamd 1.38 eingebaut
- Common Interface Assignment entfernt
- InfobarTunerState hinzugefügt
- NFS und Samba Freigabe der Box überarbeitet
- Einige Fehler im HDF-Downloader Bereich gefixt
- kleine Anpassung in der FB Belegung
Bekannte Probleme!
NTFS Schreiben funktioniert mit dem aktuellen Kernel nicht. Workaround über Telnet:
opkg remove --force-depends ntfs-3g
Wichtig!!!
:arrow: Download ET9x00 HDF v4.9 bei Mediafire
Re: HDF-Teamimage
ET9x00 HDF Teamimage v4.9.2
ET9x00 HDF-Teamimage v4.9.2 based on OpenPLi2.1 vom 21.04.2012
Änderungen vom Image 4.9 zum Image 4.9.2:
- Kernel 3.3.0 mit aktuellen Treibern, PLi Update Stand 21.04.2012 (zur Zeit mit Pinguinen)
- aktuelles GST Mediasink (Audio Problem bei AC3 Filmen gefixt)
- Skin army.mod überarbeitet (wegen PLi Änderungen)
- Skin Nobile überarbeitet mit neuer Second Infobar
- Anpassungen in der HDF-Toolbox (wegen PLi Änderungen)
- Anpassungen im HDF-Downloader (wegen PLi Änderungen)
- Anpassungen im Softcam Cardserver Manager (wegen PLi Änderungen)
- ext2 und ext3 Kernel Module im Image enthalten
- soweit möglich alle Plugins auf aktuellen Stand gebracht
Bekannte Probleme!
 opkg install kernel-module-ntfs
Damit wird der Kernel interne NTFS Lesezugriff aktiviert.
Alternativ kann man auch in der Datei /etc/filesystems den Eintrag "ntfs-3g" entfernen.
Ich hoffe das wird in einem nächsten PLi Update behoben.
Wichtig!!!
:arrow: Download ET9x00 HDF v4.9.2 bei Mediafire
Re: HDF-Teamimage
ET9x00 HDF Teamimage v4.9.3
ET9x00 HDF-Teamimage v4.9.3 based on OpenPLi2.1 vom 27.05.2012
Dieses Image wird das letzte Image mit Basis PLi 2.1 sein. Das nächste Image wird auf PLi 3.0 basieren aber das wird noch ne Weile dauern.
Das 4.9.3 ist komplett durchaktualisiert und kann für neue Flashs benutzt werden. Wer ein aktuelles 4.9.2 hat braucht nicht unbedingt zu flashen.
Allerdings sind ein paar Plugins dazu gekommen die dann fehlen würden.
Clark-tech/Xtrend ET9x00 HDF Teamimage v4.9.3 basierend wie immer auf dem bewährten PLi 2.1.
Änderungen vom Image 4.9.2 zum Image 4.9.3:
- Kernel 3.3.0 mit aktuellen Treibern, PLi Update Stand 27.05.2012 (zur Zeit mit Pinguinen)
- aktuelle HDF-Toolbox
- Devicemanager/Datenträgerverwaltung eingebaut (als Ersatz für den MountManager)
- aktuelle Senderliste mit den neuen HD-Sendern incl. Picons
- EMC Beta 3.0 V632 enthalten
- EPG Pfad ist auf /etc/enigma2 eingestellt (kann über EPG Cache Setup geändert werden)
- InfobarTunerState in Version 1.0
- Merlin Music Player enthalten
- Music Charts Streamer Top100 mit Aufnahmefunktion enthalten
- Swap Manager um bei Bedarf Swap Partitionen anlegen zu können
- webradioFS in Version 7.83 mit Aufnamemöglichkeit
Bekannte Probleme!
Wichtig!!!
:arrow: Download ET9x00 HDF v4.9.3 bei Mediafire
Zpět na „Clarke-Tech ET9000 HD , Xtrend ET9x00 Images“
