ViX Team Image
Images pro přijímač Clarke-Tech ET9000 HD , Xtrend ET9x00
ViX Team Image
ViX Team ET9000 Image v2.1 - 05/03/2011
New VIX Image ET9000 - v2.1
05/03/2011 - Open ViX 2.1
Based on Open PLi 2.0
From VIX Team
Enigma: 04-03-2011.
Enigma Plugins: 04-03-2011.
GCC Version: 4.4.4.
Drivers: 20110214.
Team ViX Enchancements
ViX Bootlogos, Radio Logo and Shut Down Logos.
ViX Team Spinner.
ViX Team Vu_HD Skin.
ViX Team softcam manager (softcams will need to be installed manually).
ViX Team Cron Manager - Allows you to create cron jobs from scrips in /usr/script/ and set them to run at pre-defined times by you. For more info, look at the screen shots below.
ViX Team Power Manager - This allows you to enable standby at a specific time, enable deep standby at specific times, do a GUI restart at specific times, or do a full reboot at specific times. If standby is set after deep standby, then it will wake the box up and return the box to the state it was before deepsleep was initiated... For more info, look at the screenshots below.
ViX Team Device Manager - This enables you to choose where you want to mount USB Sticks, USB HDDs, etc. This can be found in Menu -> Setup -> VIX -> Device Manager. Please also note that USB / ESATA devices NEED there mount points setup in Device Manager (green button whilst in Device Manager) in order for them to work correctly.
ViX Team Image Manager - This enables you to backup and restore your image (nb, we are talking the whole image, not just settings). This can be found in Menu -> Setup -> ViX -> Image Manager. You can choose where to store your backups to, either HDD or USB. /media/hdd/imagebackups or /media/usb/imagebackups folder (setup by pressing menu, whilst your in Image Manager).
ViX Team Overscan fix - This is the fix to remedy any overscan people had in the previous release. To use this, go to Menu -> Setup -> VIX -> Skin Settings and alter the "Menu Overscan amount" to suit your display.
ViX Team Swap Manager - Allows you to create/use swap files on usb/hdd, and also allows you to use swap partitions.
ViX-EPG - This is a simpler, faster version of CoolTVGuide, modified for the image.
ViX QuickEPG - This is VIXs' version of QuickZap. You can see the full epg data for the channel, not just now and next. Picons work within QuickEPG. Also includes channel preview.
ViX Quick Event Info - This is the new way to receive the event info on the ViX image. Press OK button once to get the info bar up, press it once more (i.e. a second time) to receive the information about what is currently showing...
ViX Single EPG (with channel preview) - The is new and unique to vix, after you open the ViX single EPG (short RED) you can view the 7 day epg for that channel, now to see another channels epg, either use the Channel up/down buttons on your remote or just key in the channel number. if you want to preview the channel your currently viewing the EPG for (ie you want to see what the current program is like) just press 'OK' on your remote, this will change to that channel showing you the program in the small video window. if you don't like it, go find another channel to preview by keying in new channel number (or up/down buttons). or if you do like it and want to go fullscreen on it, just press 'OK' again. but if you feel you want to return to the original channel you where watching (whilst still in ViX Single EPG) just press 'EXIT" button, this will return to where you where before you entered ViX Single EPG)
ViX Network Manager added to VIX Menu - This allows you to stop and start certain network features. The features you can stop/start are: FTP, NFS, VPN, Samba and Telnet.
USB DTT - To install dvb-t, you just need to go to the plugins downloads, and select the stick you have. This will then install the drivers for your stick. You will then need to restart your receiver. Once restarted, go to Menu -> Setup -> Service Starting -> Tuner Config, and you should notice Tuner C as your USB DTT...
IPK Installer - Just copy your .ipk fle into '/tmp' and go to the menu option.
AutoTimer plugin integrated into image - Create an AutoTimer (Series Link), using Blue button in Current Channel EPG info.
XMLTV EPG Importer - Thanks to Rytec for his support on this Importer. This has been updated so that the Import automatically updates itself from the servers, so there is no need to download and install new source files. Thanks to Rytec for the idea and andyblac for coding it.
CrossEPG included in image as default - Settings for this can be found in Menu -> Setup -> VIX -> CrossEPG.
EPG Download from transponders - This incorporates the EIT, MHW, FREESAT, NetMed & VIASAT downloads. To enable/disable, change your settings in the Menu -> Setup -> System -> Customise.
EPG load patch - Image patched to allow EPG data to be loaded without the need for a restart.
WebInterface and Help Screens - The Web Interface Remote Control correctly shows the ET9000 remote control, with all buttons mapped correctly. As well as this, in all Help screens, the remote control has been updated to the ET9000, and all references of Dreambox removed.
Added option to disable the spinner (egg timer) - Change the setting of "Show Animation while busy" in Menu -> Setup -> System -> Customise.
Added option to disable the channel numbers in Channel List - BMCC bouquet's have Channel Numbers in their channel name, so you get them twice in channel list.
Panic Button - Added option to enable/disable panic button (goes direct to channel 1).
Subserivice Option - This option allows you to assign the Subservice shortcut to a long green press. To change this option, go to VIX Menu -> VIX Setup.
Option to disable ViX coloured buttons - This should ensure that if users want to use MultiQuick button plugin, it should work without issue
Added Wireless Lan Support - This is automatically enabled in the image. To set up, use the Network manager on first boot, or from the Menu -> Setup -> System -> Network.
NFS Server added to image and set to run automatically - To edit the folders you wish to share, you will need to edit file /etc/exports.
Network Browser - Added Network Browser to help you setup share mounts.
OpenVPN Support - This will need to be configured to your need first then use the manager to setup to autostart.
Added Smargo Support - This is automatically enabled in image.
Recorded Items - Recorded Items list modified to move item, browse directories, etc. Works similarly to suomipoeka plugin. Can be selected to load via the recorded items button, or from the tv button.
Permanent Timeshift Plugin integrated (Disabled by default, turn on via Timeshift settings).
Integrated AutoTimer
Integrated EPG Search
Integrated IMDb Search
Button Mappings
Short Red** & *** - Show current channel EPG info (ViX Single EPG).
Long Red*** - Show current event.
Short Green** & *** - Timers.
Long Green*** - AutoTimer Timers.
Short Yellow*** - EPG Search.
Long Yellow*** - IMDB Database.
Short Blue - Extensions.
Long Blue*** - Plugins Menu.
EPG - Opens ViX EPG.
Left/Right** - Opens ViX QuickEPG.
** Can be changed in ViX Menu
*** Can be turned off in ViX Menu
Known Bugs
None that we know of
Special thanks to the following members:
vu+nl for skinning his magic skins for ViX Team image
rytec - for his continued support.
PLi Team for their great base image and allowing us to use it.
zoka.cc for his Picon sets
Coolman and all other developers for their plugins used in the feeds of this image.
All of the ViX Beta team for their hours of testing and dedication on getting this image and DTT working
DOWNLOAD: ViX-2.1-et9000_usb
Alternativny download: ViX-2.1-et9000_usb
Screeny su v skine HDGlass 16_2.30
Re: ViX Team ET9000 Image
ViX Team ET9000 Image v2.2 - 11/06/2011
New VIX Image ET9000 - v2.2
11/06/2011 - Open ViX 2.2
Enigma: 11-06-2011.
Enigma Plugins: 11-06-2011.
GCC Version: 4.4.4.
Drivers: 20110516.
ViX is now embedded within the image even more. A lot of settings have been moved out of the ViX menus, and incorporated within the image. Settings from previous images may not be 100% compatible, and it might be best to re-setup your image without restoring system settings for 100% reliability.
If you have previously used NetworkBrowser to mount network mounts, please remove '/etc/*******/automounts.xml' BEFORE tying to setup news ones.
ViX Bootlogos, Radio Logo.
ViX Team Spinner.
ViX Team ViX_HD Skin.
ViX Team softcam manager - Lots of changes have been made here. You can now choose whether you want to check whether your cams are running by pressing menu in the softcam screen. You can also check the status of your cam checks by pressing the info button. Also, lots of behind the scenes checks to ensure no restarts of cams when it is actually running.
ViX Image Manager Update - This has been overhauled, and now has the option of creating a schedule to do daily, weekly or every 30 days backups for you.
ViX Cron Manager Update - This has been updated to allow more detailed and specific cron jobs to be created.
ViX Single EPG (with channel preview) - This has been updated to now support picons.
ViX Release notes - This is just a little screen within the Menu -> Information -> About, that appears when you press EPG/Info button, to tell you the latest updates for the image.
ViX Update Checker - This is a feature that lets you know of any available online updates by a little globe symbol in the infobar. This is set to check every 12 hours whether there are any updates for the image (can be changed in settings). If so, the icon will change from inactive to active...
ViX Logs Manager - This allows you to manager your crashlogs and system logs (if enabled). If you have a crash, you can email your bugs to us directly from the image. Go to Menu -> Setup -> System -> Logs. When in the Logs Manager, you can edit the configuration to show your forum username, and your email address by pressing the Menu button. Please ensure you do this before submitting logs!
ViX Settings - These are now found in the main System Menu.
ViX Simple TV List - This is a simple selection to show your bouquet lists, just showing the channels and current event (if in EPG). To access the Simple TV List, do a long up/down arrow button press. You can customised it to be the default option instead of Full Screen Channel List, in which case, Up/Down buttons are reversed. It can also be set in the ViX Settings for the TV button.
AutoTimer plugin integrated into image - Create an AutoTimer (Series Link), using Blue button in Current Channel EPG info. This has been updated to use threading, so that it will work in the background. No more spinning when checking for lots of timers. Default behaviour has been changed so that it does not check in standby only, and will check every 30 minutes.
*****Info - *****Info plugin built directly in to image.
OscamInfo - OscamInfo plugin built directly in to image.
Blindscan Support Added - This allows you to access blindscan within the Service Scanning menu.
CrossEPG - Updated to latest release to allow better EPG importing.
Movie Player - Now, when playing a recorded item, you can search EPG and add Auto Timers for the particular recording. When watching your recording, press yellow to search the EPG, then press blue to add an AutoTimer.
Button Mappings
Up/Down** - Open Full Screen Channel List.
Long Up/Down** - Open Simple TV List.
TV Button** - Open Full Screen Channel List.
Long TV Button - Open Bouquets List.
Known Bugs
"Link-Icon" in network doesn't show up (= grey instead of green).
Radio mp3 stream crashes after some time (sometimes only > 1 hour). Once that occurs, TV is also without sound. A reboot is then required. There might be a relation with Shoutcast (in use or just installed).
A second subtitle in AVI, MP4 etc doesn't show up. Debugging in E2 just stops.
In Partnerbox (remote TV-Player) the audiobutton causes a crash.6
Special Thanks
Download
ViX Team ClarkeTech/Xtrend ET9000 Image v2.2.100 - 21/07/2011
New VIX Image ET9000 - v2.2.100
21/07/2011 - Open ViX 2.2.100
From VIX Team
Enigma: 21-07-2011.
Enigma Plugins: 21-07-2011.
GCC Version: 4.4.4.
Kernel Version: 2.6.18.
Drivers: 2011-06-25.
If you wish to perform an online update, then you will be able to upgrade your v2.2 image to v2.2.1 via the online functions. This full image is available for those who do not have online functionality on their box, or wish to perform a full reflash...
New Features
BackupManager - Lets you create scheduled backups of your system files (not full Image like Image Manager).
RestoreWizard - This a wizard that detects and restores you backup (created with BackupManager), with option to restore your extra plugins.
ImageManager - Major code rewrite, now handled by Job task, view progress of image creation in extension list (blue button)
ViX Menu - Added PackageManagement & Software Update, so SoftwareManager is now not needed. It is also now translatable into different languages.
NetworkInadyn - Add new network setup screen Inadyn.
OScam/CCam Info - Added options to show in Extension List. (the Menu item will now only show IF the softcam is installed).
OnlineVersionCheck - Added option to disable online check by setting check value to '0' and set a maximun timer to 48 hours.
Recording List - Added a new option in MovieList Settings to use a "Slim" list like the "Slim" Channel slection screen.
EPG Graphical - This is now in core, no longer a plugin (was ViXEPG), added the option to show Bouquets on launch.
EPG Menu - Add Load/Save item, this allow you reload/save the EPG cache.
E2-Plugin's - Updated all to plugin's to the latest GIT from PLi.
ZAP Timer - This will create a zap timer (rather than a recording timer) for the selected event in the EPG/Single EPG etc. To activate this, select the event from the EPG, and do a long button press on the record button. This is a non-configurable timer, so will use all defaults, and just set the record to a zap, rather than a record. When adding a zap timer, the clock icon will show on the previous event. This is to do with the pre-start timer.
Fixes
SwapManager - Code cleanup, for better activation/detecion.
About Screen - Updated infomation screen, better layout, more information. VFD now shows image version.
EPG Search - Fix a bug where the yellow button just opened a blank EPGSearch screen instead of actually perfoming a search on the current event. Also, added 'Show History' to long yellow button press whilst in EPGSearch.
EPG Cache - Updated so now it does not require 2 reboots in order to use new location.
EventView - Fix GS on opening Similar List.
PluginBrowser - fix it not installing picons.
ShoutCast - Fixed plugin.
SoftcamManager - Add Timercheck for OScam to support no username or password in Webif, fix GS when pressing coloured buttons, if no softcams installed, also code clean up.
Translation - Updated NL language files.
Permantent TimeShift fix and embed PTS.
Updated KeyMap - Fixes a few MoviePlayer remote control issues.
ViX HD skin - PNG fix for selected items in lists, Tweaked the Jobview screen, 'New Online Version' icon now flashes to remind you of an update.
VIXEPG fix - The < > keys for jumping +/- 1 day.
NetworkBrowser - fix GS when creating CIFS mounts.
RemoteSetup fix GS when showCoolTVGuide is selected.
Button Mappings
Known Bugs
Second subtitles in AVI, MP4 etc often need a stepskip to enable them to show up.
Shoutcast has no genrelists and menu is not working.
Special Thanks
Download
K dispozicii je online aktualizacia image ViX na verziu 2.2.109 z 2011-08-03
menu-nastavenie-VIX-software update
New VIX Image ET9x00 - v2.3
07/12/2011 - Open ViX 2.3
From VIX Team
Enigma: 07-12-2011.
Enigma Plugins: 07-12-2011.
GCC Version: 4.4.4.
Kernel Version: 3.1.0.
Drivers: 2011-11-05.
This image requires the latest bootloader (attached to this post) to be flashed. This is because Xtrend have changed the way the drivers work. So, before updating your image, you will need to first flash the bootloader, then flash the new image. Flashing of new bootloader only takes a few seconds, so once flashing's completed, then just turn off the box, transfer the new image to the usb stick, and flash with that. Also, it is recommended to NOT use older images with this new boot loader, as this may result in a bricked box.
Because of a lot of changes behind the scenes of the image and building, you will not be able to perform an online update. A full flash is required for this version of ViX image
This revision of the image has undergone many different builds, hours and hours of coding/fixing, and we hope that you are now happy to reflash with the latest ViX image!
New Features
Updated to kernel 3.1.0 - This new kernel is much faster and better than the previous kernel, and finally you all get to test it if you held off updating to other images. If you did update, you can finally come back to the ViX image
VFD Icons fully working - Unique to the ViX image. The VFD icons on the front of the box are working correctly how the manufacturer intended them. Seperate icons for Timeshift (rather than using the recording icon), Sat icons, LAN icon, USB icon and HDD icons, all working perfectly. View the pictures below to see what they look like.
Added items to the Information Screen - Added Devices and System Information to Menu -> Information. In Devices, you get all the information about connected devices on your box (HDD, USB and Network Shares), and System Information will show you your memory on your box (Swap, Free memory etc). See screenshots below for more information.
Added OSD Settings - This replaces the overscan option within the ViX image. Go to Menu -> Setup -> System -> OSD -> OSD Setup, and ensure the screen fills your TV set exactly to ensure that all menu options are shown correctly for your TV.
Updated Blindscan - Now, ET9000 and Vu+ Uno both have blindscan ability incorporated in to the image. And, best of all, a nice simple scan routine for it. You can choose to scan all horizontal and vertical polaritys, as well as high and low bands all in one pass. Save having to run the blind scan for each individually :thumsbup:.
Added support for HDMI-CEC - This image now allows you to control your box using your tv remote. Remember, this is still experimental at the moment, and can work differently between different brands of TV makes/models.
Added uShare - Allow the box to be detected by your DLNA devices that support this protocol. This can be configured under Menu -> Setup -> System -> Network -> uShare Setup.
Added MiniDLNA - Same as uShare, but some people were having problems with uShare, so we have added a different version for people to use.
Added AFP - The Apple Fileshare Protocol makes it easy for your OSX devices to find your box and use the box natively within the OS. This can be configured from Menu -> Setup -> System -> Network -> AFP Setup.
Added EPG Automatic Refresh - This is useful for members who keep a single EPG datasource on a network share with multiple boxes. In Menu -> Setup -> System -> EPG -> Settings, you have the option to choose a network location (as long as configured within the Mount Manager). If you use this, you might want to update the EPG data from this location automatically. So now you can using the Automatic Refresh option.
Added Automounts option - This allows the box to automatically recreate network mounts. If you've had times where the NFS of CIFS server has been restarted, or lost power etc, then you'll know that your box cannot access this network share. Well, as long as you have configured the share through the Mount Manager, then you can configure the Automount to automatically remount the share as often as you like by going to Menu -> Setup -> System -> Network -> Devices -> MountManager.
Default Skin Change - The Default skin has been changed from ViX HD to ViX Night HD. This is a new ViX skin that has been developed for those who want a darker skin for their image. See the screenshots below for comparisons between the two. If you prefer the old ViX skin, it can still be downloaded from the download server, and is now called ViX Day HD. Please report any skin issues you may find with the ViX Night HD skin. We think we have them all covered, but can't be too sure...
Many plugins translated/made translatable - Allows the plugins to display correctly the information in your own language (as defined on original setup).
Deleted a number of plugins - Due to the "war on licences", a number of plugins whose license has changed, has been reverted to the non-licensed version of the plugin, or had to be removed from the image indefinitely.
Added seekbar functionality to the image - Allow you to seek within a recording playback to where you would like to be within the playback. To utilise this, please hold down the << or **** buttons on your remote, and the seekbar will appear at the top. Use the arrow keys on the remote to choose where you would like to seek to in the playback, and press OK to start playback from this point.
Added Image Download to Image Manager - This allows you to download the latest full image from the server, and flash it to your box (Vu Only). To access this, go to the Image Manager from with ViX menu, and press the help button. This will list all available images to download.
Added playback support for FLV files - Now you can add FLV files to your recordings drive and play them natively within the system.
Lots more under the hood updates/enhancements - A few menu options and screens have become more integrated to their respective menus. For example, the Recording Paths menu is no longer required, as Timeshift Path is defined in Timeshift Setup, and Recording Path in Recording Setup.
Fixes:
Tweaked SoftCam manager.
Corrected a number of plugins.
Updated network components, including better support for WiFi.
Updated translatability; updated German & Dutch translations.
Hidden several ViX-core functions from the plugin-browser.
Better handling of SWAP partitions by the Mount Manager.
Tweaked TimeShift Code.
Remove SD/HD split from ChannelSelection as it was buggy.
Magic skin updates
MenuSort fix.
Button Mappings
Known Bugs
Nope
Special Thanks
-rytec - for his continued support.
-zoka.cc for his Picon sets
-Coolman and all other developers for their plugins used in the feeds of this image.
-All of the ViX Beta team for their hours of testing and dedication on getting this image and DTT working
Requests
If anyone is interested in doing any translation work for the plugins and the image itself, please contact either Andy of Sicilian...
Thx VIX Team
:arrow: Download
Diskusia tu: http://www.forum.satdigitalne.cz/viewto ... 287&t=7216
Online Update for ET9x00 now active to bring to Build 204.
Also available below is the USB File for flashing a clean build of 204.
Enjoy it guys.
2.3 Build 204:
enigma2: LogManager update for log locations.
enigma2: CrashLogs, both types (normal crashlog and Debuglog) now share the same location (user definable) the new default is '/home/root/logs'
enigma2: EpgSelection, fix multiepg channel preview and clean up all epg code.
enigma2: fix issue with timers and standby and new trashcan.
enigma2: EPGSelection: graphical epg update.
enigma2: TrashCan: fix possible error screen, Deepstandby issues.
enigma2: InfobarGenerics: fix 2nd info bar timeout.
feeds: add 'dvb-usb-af9035'
linux: add dvb-usb patches by Gennar1 (etx000 and vuplus)
xmltv-importer: add auto creation of swap in needed.
ViX-core: BackupManager: now allows more than one backup per day.
ViX-core: RestoreWizard: now does not show if no backup are found, also backups are now listed last backup at top of list, also fixed a bug where if a device did not have any backups on but another did both devices listed same backups.
ViX-Night/Day skins: updated QucikEPG to include description.
:arrow: Tu klikni pre stiahnutie
Re: ViX Team Image
New VIX Image ET 9x00 Series Version 2.4 15/05/2012
15/05/2012 - Open ViX 2.4.96
From VIX Team
Enigma: 04-05-2012.
Enigma Plugins: 04-05-2012.
GCC Version: 4.4.4
Vu + Kernel Version: 3.2.2
Vu+ Drivers: 2012-03-23
If you have not already done so you will need to flash the latest bootloader
All Users
A full flash is required for this version of ViX image. Because of extensive changes you will not be able to perform an online update or restore any settings/plugin backups
New Features
Blindscan
Now uses RF values in GUI not IF.
C band searches possible.
Supports symbol rates from 1 - 45MHz.
Channel Selection
Support added to change font sizes and number of rows.
Support added to have a 3rd event showing (skin dependent)
Support added to display start time and end time for all events shown.
EPG Selection
Added help screen to all epg selection screens.
Added support to change font sizes and number of rows.
Language Selection
Added English (UK) to available languages.
Translations
Added support for English (UK).
Sorting
You may now sort Menus, Settings and Plugin Browser alphabetically.
Network Browser
Uses less memory during Scan.
Moved to new Setup Mounts screen.
Openwebif
New style webif now accessed using default port 80
Old style webif still available if required for use with certain PC signal meters and Fancontrol 2
About Screen
Added network info.
Plugins
As part of streamlining the image, removed NFS, AFP, Samba, OpenVPN, Inadyn, MiniDLNA & uShare from default image (still available to install through feeds)
Bootlogo's
Now available for direct install via plugins feed.
On Screen Hints
Now available as options are selected.
USB DVB
Added dvb-as102 support (by Gennart1).
Skin
Brand New skin ViXBMC by markus625 added to feeds.
Native skins updated and optimised.
Instant Record from channel list, EPG or current channel.
Enhanced Movie List Features
Latest Drivers (23/3/2012).
Loads of under the hood changes made for a smoother user experience.
Button Mappings
Long Red*** - HBBTV ( ET series and select channels only).
Long Yellow*** - Instant IMDB Database search on the current programme.
Special Thanks
All developers for their plugins used in the feeds of this image.
All of the ViX Beta team for their hours of testing and dedication on getting this image working.
Rob van der Does, belierzz, rimas, Henkka, raivo, eesatfan, Zartmy, Trial & june8 for their translation work.
Silverfox0786 for channel settings, picons and bootlogo's.
Huevos for his work on blindscan
Gennart1 for dvb-as102 support
Markus625 for skin ViXBMC
Note: Not all 3rd party plugins have been tested or are guaranteed to be compatable.
Requests
If anyone is interested in doing any translation work for the plugins and the image itself, please contact either Andy or Sicilian
Download
Download site for Latest Open Vix Builds (Beta's) http://www.openvix.co.uk
Stable release below
Bootloader for those that need it is the first file
Sicilian píše:To let all ET users know, we are aware that the Xtrend images are still on kernel 3.2, we will be upgrading to 3.3 in the very near future. Please do not load kernel 3.3 drivers to this image.
Re: ViX Team Image
ViX 2.4-112 NOW ONLINE
This update is largely un-tested therefore would all users please backup their images prior to updating. To update to 111 you will need to enable unstable updates. Menu > Setup > System > Online update > Set allow unstable updates to YES.
If you do not wish to use or risk unstable updates please wait until the stability icon @ http://www.openvix.co.uk is green for stable again.
All Xtrend receivers have been updated to linux kernel 3.3, although an online update should be ok we strongly advise to re-flash if you expriance any issues.
2.4 Build 112:
enigma2: HelpMenu: fix posible BSOD.
enigma2: fix 3D setting on Vu's.
openwebif: add new ViX setting menu to Menu Panel (still needs work).
picons: update zonka.cc to 2012-05-17
system: merge from PLi 18-05-2012 - this includes Linux 3.3 for ET's.
vix-skins: update transponder info for new PliExtraInfo, fix simple channelselection screen title.
OpenViX 2.4-119 ONLINE NOW.
2.4 Build 119:
enigma2: PliExtraInfo, fix for terestrial tuners.
enigma2: more detailed MemoryInfo screen thanks to Ralf.
translations: updates, thanks 'jerry00', 'Ralf', 'Rob'
vix-skins: fix IMDB stars (thanks regarto)
OpenViX 2.4-124 NOW ONLINE.
2.4 Build 124:
feeds: remove channelsettings, bootlogos & picons by silverfox0786 at his request.
Translations: CS update thanks 'jerry00', 'Rob'
ViX 2.4-128 NOW ONLINE
2.4 Build 128:
enigma2: made DolbyDigital audio tracks default, as most channels use NAR on pcm tracks.
ViX 2.4-134 NOW ONLINE
2.4 Build 134:
enigma2: fix possible none starting box.
ViX 2.4-135 NOW ONLINE
2.4 Build 135:
also fixed some other minor bugs introduced into the image in Build 134:
OpenViX 2.4-143 NOW ONLINE.
No real update to the changelog this time, but andy has put a lot of work in under the hood so to speak and fixed various minor bugs etc.
OpenViX 2.4-149 NOW ONLINE.
2.4 Build 149:
enigma2: fix seekbar activation.
enigma2: pli merge.
OpenViX 2.4-151 NOW ONLINE.
2.4 Build 151:
enigma2: fix BSOD with help/wizard screens.
Also fixed IMDB failure to download error thanks to regarto
:arrow: Tu stiahni OpenViX 2.4-151
2.4 Build 158:
bez info
:arrow: Tu stiahni ViX-2.4.158
OpenViX 2.4-181 NOW ONLINE.
2.4 Build 181:
vix-core: fix image manager.
tm-twin: update drivers 20120710
vuplus: update drivers 20120628
OpenViX 2.4-207 NOW ONLINE.
2.4 Build 207:
pli merge
e2-plugins: merge
vix-core: remove some items from vix menu and move back to Software Manager plugin, as not everyone needs those features, Software Update has been moved to System menu.
also includes some other various unlisted minor bug fixes.
OpenViX 2.4-213 NOW ONLINE.
2.4 Build 213:
enigma2: GraphicalEPG: updated so turning On/Off PIG no-longer requires epg close,
enigma2: GraphicalEPG: added ability to ';live switch' between PIG / List using TV button
enigma2: GraphicalEPG: added ability for remotes that have a 'real' epg button (Xtrends, Venton) to open Single EPG when pressed.
Re: ViX Team Image
New ViX Team ET 9x00 OE3.0 Release
Brand New VIX Image ET 9x00
15/08/2012 - OpenViX 3.0.204
From VIX Team
GCC Version: 4.4.4
ET Kernel Version: 3.4.3
ET Drivers: 14-07-2012
All Users - A full flash is required
You can not use backup restore or online update from 2.4 with this image
In this image the core has been extensively rewritten by Andy in conjunction with the OE Alliance.
You are advised to take a full image backup before flashing.
Features
VIX EPG
Graphics and Text mode available.
Video Playback
All EPG screens now available while watching a recording, for easy switching back to Live TV or setting timers.
Channel Selection
Support added to have a 3rd event showing (Skin Dependent)
EPG Selection
Language Selection
Translations
Sorting
Network Browser
Openwebif
About Screen
Added network info.
Plugins
As part of streamlining the image, removed NFS, AFP, Samba, OpenVPN, Inadyn, MiniDLNA & uShare from default image (can now be installed/de-installed through Network setup screen)
On Screen Hints
Instant Record
It is now optional to play next movie, when the a movie reaches end, setup in menu of movie selection screen.
Latest Drivers (28/6/2012).
Button Mappings
Long Red ** & *** - Sort single EPG info when in channel list.
Special Thanks
:arrow: Download
a_le_bo
:arrow: Tu stiahni openvix-3.0.204-et9x00
Re: ViX Team Image
OpenViX 3.0-237
e2-git changelog
openvix: build 237
 [epglist] fix BSOD when disabling service name in graphepg
 openvix: build 236
 openvix: build 235
 [keymap] fix some remote buttons.
 openvix: build 234
 openvix: build 233
 openvix: build 232
 openvix: build 231
 [channelselection] fix possible BSOD when trying to preview none existent service. 2nd attempt.
 [epgselection] add options to control picon/servicename widths in graphing.
 openvix: build 230
 [getecminfo] fix MGcam
 [epgselection] cleanup, and fix BSOD leaving single epg when opened from channel selection.
 [ZapTimer] add channel to zap history and change to current service in channel selection screen.
 [translations] RU remove duplicates.
 [translations] RU updated thanks to 'WadimArt '
 [translations] ET updated thanks to 'rimas'
 Merge remote-tracking branch 'pli/master'
 [epgselection] fix BSOD if no channel is currently playing when trying to exit.
 openvix: build 229
 InfoBar: Slightly streamline my previous path
 InfoBar: Add confirmation before exit Movieplayer
 openvix: build 228
 openvix: build 227
 openvix: build 226
 openvix: build 225
 dvbtime: enable transponder time sync by default
 servicemp3: do not enable progressive download buffering by default
 listboxservice: fix potential buffer overflows
 listboxservice: fix illegal format specifiers
 fix GSOD if eventView is not exist
 When press exit in movieplayer also hide OSD when it is shown
 Leave movieplayer on exit only when OSD is not shown
 httpstream: recognise more playlist content types
 [epgselection] fix exit after browsing epg without previewing.
 little change in preview/zap
 httpstream: add basic http authentication support
 [MovieSelection] fix an issue where when browsing movie list when playing a avi/mkv on exiting movie list the current media file would restart from beginning.
 httpstream: add redirect and playlist support
 repair zap/prev in EPGs
 openvix: build 224
 openvix: build 223
 servicemp3: enable GST_PLAY_FLAG_TEXT
 openvix: build 222
 epgcache: Add a "startswith" search type and a few optimizations
 [About] fix possible BSOD
 servicemp3: avoid setting GST_STATE_PLAYING repeatedly when buffer hits 100%
 servicemp3: only set "user-agent" property if the property exists
 openvix: build 221
 servicemp3: no longer put the sinks in sync mode for stream playback
 servicemp3: no not respond to buffering messages for live streams
 openvix: build 220
 openvix: build 219
 servicemp3: add progressive download buffering support for streams
 ServiceInfo: Add capability to put HbbTV URL on a skin
 openvix: build 218
 openvix: build 217
 openvix: build 216
 openvix: build 215
 openvix: build 214
 openvix: build 213
 openvix: build 212
 openvix: build 211
 Merge remote-tracking branch 'pli/master' (skipped all EPG related items, as they are not need for ViX)
 GraphMultiEPG: Handle preview and zap correctly together with pipzap
 modify string for gettext. Thanks to Dima73
 openvix: build 210
 openvix: build 209
 openvix: build 208
 openvix: build 207
 cosmetics in **.po
 grade for temperature in C and F
 Improved English translation
 Improved Slovenian translation
 Finetuning of degree sign in orbital positions
 repair - do not close chanelselection
 PliExtraInfo: Display degrees sign before orbital position
 openvix: build 206
 repair bug in zap-preview, less code
 GraphMultiEPG: Highlite the current previewed service
 [About] fix scrolling in NetworkInfo screen (add missing actions).
 [About] fix scrolling in NetworkInfo screen.
 GraphMultiEPG: Close recursive when zap is used
 GraphMultiEPG: Allow to exit after zap
 preview with TV button and close EPG after ZAP
 preview in channelEPG and ZAP for single channelEPG
 openvix: build 205
 [ChannelSelection] clean up after merge
 [About] fix BSOD
 GetEcmInfo: Try to fix stuff for mgcamd
 openvix: build 204
 Channelselection: Declare startRoot in the correct place
 ChannelSelection: Small improvements regards previewzap
 ChannelSelection: Zap back to start service regards to preview
 InfobarGenerics: Remove some white spaces
 [Translations] DE update thanks Ralf
oe-git changelog
openvix: build 237
 openvix: build 236
 [enimga2-3rdparty-feeds] buyukbangpanel fix filename.
 openvix: build 235
 Added 3g modem manager
 Updated BuyukBangPanel
 [tmtwin] dvb-modules update 20120827
 update directfb to 1.4.16
 openvix: build 234
 openvix: build 233
 [enimga2-3rdparty-feeds] fix.
 openvix: build 232
 [channel-settings] add ViX set.
 openvix: build 231
 Atmo link corrected (didn't match existing file)
 [openhdf] removed some files from plugins
 Update AtmoLight
 [AutoBouquets] fixed filename the architecture should be separate by a _ not a -
 Merge branch 'master' of github.come-alliance/oe-alliance-core
 [openhdf] update build version, Softcam plugins removed
 Deleted PartnerBox from the feeds, as it is no longer compatible.
 openvix: build 230
 vuplus-dvb-modules:20120824 update - Improve TS playback - Improve Graphic 2D acceleration - Fix Russian VFD display(duo, uno) - Fix High/low symbolrate channel scan problem.(Uno, Ultimo : Need FPGA Update) -- UNO : http://archive.vuplus.com/download/fpga/vuuno/4.5/ -- ULTIMO : http://archive.vuplus.com/download/fpga/vuultimo/4.5/ - Fix EOS detection problem in media playback - Enhance Security - Change duo's remote control to the advanced type(for HBBTV)
 add eplayer4 source
 [openhdf] removed cam-settings and various changes in bb files
 openvix: build 229
 [tuxbox-common] PR bump.
 [tmtwin] update dvb-modules 20120825
 [tuxbox] updated satellites.xml
 openvix: build 228
 openvix: build 227
 openvix: build 226
 openvix: build 225
 [tmtwin] update dvb-modules 20120823:
 Updated AutoBouquets; added BuyukBang
 Merge branch 'master' of ssh://github.com/oe-alliance/oe-alliance-core
 [openpli merge] add terratec H5 rev 3 support; Add pyload to feed; volatile-media: do not create mountpoints outside /media/
 [openhdf]: image bb's edited
 [openhdf]: hdf-toolbox.xx deleted
 [odinsupport] add extra feed config
 [openHDF] rollback to last rev from hdf-toolbox without git
 [openhdf]: build 42
 [openhdf]: various changes in plugins und build number
 [odinm9] update drivers 22.08.2012
 openhdf: build 36
 [openhdf]: various changes cause of differnt enigma2 git
 [openhdf]: changed to different enigma2 git
 Added WebMedia
 small update terrestrial.xml
 [openmips,openaaf,odinsupport] switch back INHERIT += "rm_work" not working
 [openaaf] update bootlogos
 Added 'Modem' to the not-wanted plugins
 [openaaf] bumb version
 openhdf: build 22
 openvix: build 224
 doppeltes file gelöscht
 OpenHdf: Gits als SRC_URI raus genommen
 Updated PictureFS & CamoFS
 openvix: build 223
 [openaaf,openmips,odinsupport] use INHERIT += "rm_deepwork"
 openvix: build 222
 [vuplus] update dvb-modules 20120820:
 [picons] switch to mirror download [picons] update 2012-08-19--11-41-11 [picons] add blue/black hd and sd picons [openaaf/odinsupport] add hddtemp to build
 openvix: build 221
 [tmtwin] dvb-modules update 20120819
 bumb build
 [odinm9] remove blindscan
 Bumped due to updated not-wanted-plugins-list
 Added MyTube to unwanted plugins, as the license doesn't allow usage. And besides: it doesn't work.
 Updated WebRadioFS & CamoFS
 Added AutoBouquets E2
 [openmips,openaaf,odinsupport] replace ntp with ntpdate
 [dreambox] add missing tmpd
 [dm800] fix dm800hd build thanks scp for testing and infos
 openvix: build 220
 openvix: build 219
 [openhdf] stop parsing enigma2-plugin-hdf-toolbox waiting for a fix
 [busybox] updated mount script.
 [tmtwin] dvb-modules update 20120818
 [tmtwin] linux kernel build fix.
 [odinm9] drivers 18.8.2012
 [ventonsupport] updated channel list
 openhdf added skinsnotwanted and pluginnotwanted
 openhdf: recipes initial add
 OpenHDF conf file added
 [tmtwin] dvb-modules update 20120817.1
 openvix: build 218
 openvix: build 217
 openvix: build 216
 openvix: build 215
 [twin] linux fix checksum
 [tmtwin] update machine conf
 [linux-libc-headers] add version 3.5
 openvix: build 214
 [NTP] sync time at boot, if network available.
 [ocram-picons] fix typo.
 [MC] fix for usb mouse and keyboards, thanks 'Caliban'
 [twin] linux kernel update to 3.5.1 fix file name.
 openvix: build 213
 [ocram-picons] missed include changes.
 openvix: build 212
 [ocram-picons] update package names to reflect proper recognition to the creator.
 [kernel-params] remove unneeded option
 [twin] linux kernel fixes.
 openvix: build 211
 [tmtwin] dvb-modules update 20120816.1
 [odinm9] drivers fix sum
 [odinm9] update drivers 17.8.2012
 Updated NewTube
 openvix: build 210
 [classes] add new deep remove work. this also removes 'package' and 'packages-split' folders.
 Added GoogleNewsReader
 openvix: build 209
 openvix: build 208
 openvix: build 207
 openvix: build 206
 [rtl871x] fix typo.
 [twin] linux kernel config update for linux 3.5.1
 [kernel-params] Slab allocation optimised value
 [twin] linux kernel update to 3.5.1 and dvb-modules updated.
 [rtl871x] PR bump
 Revert "[rtl871x] fix patch line endings."
 openvix: build 205
 [oe-alliance-feeds] fix and cleanup.
 Added Google News Reader and Screengrab; updated LiveFootball
 add transmission to feed
 fix CRLF patch
 add fixed patch file
 fix remove corrupt patch file
 openvix: build 204
 [gb800xx] update drivers 14.08.2012 [gb800xx] add eof file fix kernel patch
 fix set version disto PREFERRED wpa version
:arrow: Tu stiahni OpenViX 3.0-237
Re: ViX Team Image
OpenViX 3.0-240 ONLINE UPDATE AVAILABLE
e2-git changelog
no changes to list.
oe-git changelog
openvix: build 240
[tmtwin] dvb-modules update 20120829
[tmtwin] linux update
openvix: build 239
[open4d] as basic support
openvix: build 238
[oe-alliance-plugins] add AutoBouquets
[enimga2-3rdparty-feeds] remove AutoBouquets as now part of oe-alliance-plugins
Re: ViX Team Image
OpenViX 3.0-249 AVAILABLE NOW
e2-git changelog
openvix: build 249
openvix: build 248
openvix: build 247
[about] another try to fix possible BSOD, another try
openvix: build 246
openvix: build 245
[graphepg] fix possible BSOD.
openvix: build 244
openvix: build 243
[translations] NL update thanks Rob
po file update
use pgettext for ambiguous translations
Revert "NextEpgInfo: See the previous commit - for translations"
Revert "NextEpgInfo: Fix a typo"
Revert "EventName: Make Now Next better translatable"
add pgettext support
oe-git changelog
openvix: build 249
openvix: build 248
openvix: build 247
[tmtwin] linux update 20120831.1 2nd update.
[tmtwin] dvb-modules update 20120831 2nd update
[openmips] update bootlogo
openvix: build 246
DVB-T2 support, mkv, wav fix, timeshift fix
[enimga2-3rdparty-feeds] try to clean current feed before updating.
openvix: build 245
[oe-alliance-plugins AutoBouquets, fix depends.
[enimga2-3rdparty-feeds] update enigma2-plugin-extensions-subtitleplayer to version 3.20
openvix: build 244
openvix: build 243
[enimga2-3rdparty-feeds] remove 'enigma2-plugin-systemplugins-pipservicerelation'
images can be downloaded directly from the openvix server
or via a online update
menu> setup> software update.
Re: ViX Team Image
OpenViX 3.0-262 AVAILABLE NOW
e2-git changelog
openvix: build 262
[SoftwareUpdater] add option perform a Settings Backup
openvix: build 261
fix merge issue that caused a E2 restart loop.
openvix: build 260
openvix: build 259
code cleanup.
openvix: build 258
openvix: build 257
openvix: build 256
oe-git changelog
openvix: build 262
openvix: build 261
openvix: build 260
Merge branch 'master' of github.com:oe-alliance/oe-alliance-core
opensif: restore of opensif-3rdparty-plugins.bb
opensif: update description for skin adriatic
opensif: update bootlogo
[gigablue] add gb800solo splash.bin support  please use new cfe version september.2012 update ue and quad new lcd infos please use new cfe september.2012
openvix: build 259
openvix: build 258
openvix: build 257
[tuxbox-common] bump PR
openvix: build 256
opensif: remove task-openplugins in opensif-feeds (it's a duplicate)
Initial commit for opensif image
Add libsocket recipe
[dreambox] update linux to patchlevel 28
[tuxbox
:arrow: Tu stiahi openvix-3.0.262-et9x00
Re: ViX Team Image
K dispozicii dalsi update... OpenViX 3.0-264 AVAILABLE NOW
Vzhladom k tomu, ze tento img zrejme v CR-SK nepouziva skoro nikto, nebudem tu dalej davat dielcie info o updatoch...
e2-git changelog
openvix: build 264
Revert "revert removal of softcam settings."
Add flag for invisibles services
[TaskView] added the ability to control afterEvent as opening.
[SoftwareUpdate] add options for performing automatic Setting/Image Backups. Setting backup is now performed on update as default.
ChannelSelection: Better fix for GSOD when stream is playing
ChannelSelection: Avoid GSOD when going to satellite bouquet list
InfoBarGenerics: Alternative numbering stay in same bouquet
openvix: build 263
[translations] NL
openvix: build 262
openvix: build 261
InfoBar: Avoid to get approx same question when quit Movieplayer
openvix: build 260
openvix: build 259
code cleanup.
openvix: build 258
openvix: build 257
openvix: build 256
openvix: build 255
[feed check] update for new location.
openvix: build 254
[InfobaGenerics] increase NumberZap timeout to 5 secs.
openvix: build 253
[keymap] remove 'EXIT' button for MovePlayer
[FileList] fix possible BSOD.
[ServiceScan] stop timer if closed.
[ServiceScan] stop timer if cancel scan.
[ServiceScan] fix possible BSOD and add time-out to close completed scan window automatically after 30 seconds.
ServiceOrbitalPosition: Also indicate non 'gstreamer' streams as stream
ServiceOrbitalPosition: Add streams and alternatives indication
Add option to display tuner type in case of no orbital position (DVB-S)
openvix: build 252
VideoMode: add 1080p50/60 mode if hardware supports it
db: properly initialize bool and remove as global
VideoMode: fix typo
Set eDVBDB::setNumberingMode to the correct place so that it will be swigged
VideoMode: fallback to 'bestfit' when 'auto' aspect ratio is not available
Revert "UsageConfig: Add per accident removed multiepg_ask_bouquet config"
some cleanup
openvix: build 251
openvix: build 250
Introduce alternative numbering mode
UsageConfig: Instantly change Channellist when setup of it is changed
eGTable: allow number of retries to be overridden
configure.ac: restructure DREAMBOX conditionals
dvb: fix compiler warnings
openvix: build 249
InfoBarGenerics: Prevent GS when preferred recording path is None
configure.ac: fix DREAMBOX conditionals
oe-git changelog
openvix: build 264
[openmips] add samba and nfs to image build
[odin] update drivers to 07.09.2012
[ocram-picons] move over to git
[gigablue] update bootlogo
[venton-drivers]Fixed Tuner C, Improved timeshift, improved rrw,ffr, improved recording and pip
adding tuncay kabledeutschland and combo settings
openvix: build 263
openvix: build 262
openvix: build 261
openvix: build 260
openvix: build 259
openvix: build 258
openvix: build 257
openvix: build 256
[tuxbox
openvix: build 255
openvix: build 254
Revert "[vuduo] add missing dvb-c tda binary"
openvix: build 253
[gbquad] remove dtsdownmix flag
[gb800xx] <gigablue-drivers-3.1.1-20120903> - fixed timeshift hang up - fixed single LNB without DiSEqC does not work 22KHz Tone
[gbquad] enable gst options
openvix: build 252
fix typo openwebif
[gigablue] gb800xx driver 01.09.2012 und gbquad 01.09.2012 - changed inputdev from dreambox to gigablue - fixed timeshift hang up - fixed mediaplayer previous/next jump does not work. - fixed scrambled channel audio does not work after audio change.
[openwebif] fix Ventron Box.
openvix: build 251
openvix: build 250
[dreambox] add hdmi_cec
[gigablue] dvb-c utils fix typo.
[gigablue] drivers 20120831 - fixed mp3 does not work 0~4 secs. - fixed volume dB range - fixed /proc/stb/fp/was_timer_wakeup (when wakeup from deepstandby) - added /proc/stb/fp/rtc_offset (different secs from UTC) - improve DVB-C tuner performance - support tda1002x interface for AutoScan
[gigablue] add dvb-c utils
openvix: build 249
Re: ViX Team Image
Zpět na „Clarke-Tech ET9000 HD , Xtrend ET9x00 Images“
