Power of Dream HD+ Image for ET9000
- vikino
05/06/2011
We are pleased to offer you a POD for HD and et9000 et5000 Clarke-Tech / Xtrend. Because the manufacturer does not provide for the time cdk official image is based on OpenPlant. It is slightly different from a dream or vuplus POD HD, but it is a POD HD
Original image from 05/06
Download
Download
- vikino
Re: Power of Dream HD+ Image for ET9000
New Image by SandBox Team based on Openpli 2.1
19.08.2011
ATTENTION:
- It is not possible to go from 2.0 to 2.1 by an updated online, it is mandatory to flash a 2.1 full
- This new image requires an update of the bootloader before it can be installed
Download
19.08.2011
ATTENTION:
Download
- vikino
Power of Dream HD 2.1 - ET9000
21.08.2011
Changes:
- Changing the launch of the card manager. Can resolve the concerns of card that was not recognized at boot.
Download
21.08.2011
Changes:
Download
- vikino
Power of Dream - ET9000 27/08/2011
CAUTION: Changing the complete image management
Before: POD full image does not change when the updates, and install a demo with a POD to date, it falait load an image a little older and do the update
Now: the complete picture is updated POD also:
- To install a full POD: take the picture early in the thread, you are a day
- If you already have a good POD generation installed, ca does not change, just update it (Menu - Settings - Software Manager - Software update)
Download
Download
- vikino
Online update Power of Dream HD+ Image for ET9000 13/09/2011
To take the lastest update of POD Image just go to:
Update of 13/09/2011
- Update routine Enigma2/Openembedded
- Added in the DLC picons OpenPlant
- vikino
Online update Power of Dream HD+ Image for ET9000 05/10/2011
- Modification of hypercam manager: the launch of enigmatic, verify that at least one local card is detected. If this is not the case, recovery hypercam. This should overcome the desire to hypercam etx000 on the launch.
- Changes introduced by OpenPlant etxx00 linux
-update routine Enigma2
- vikino
POD Image HD 2.1 ET9000 26/01/2012
To take the lastest update of POD Image just go to:Updated from 26/01
- Updated Card Manager version 2.17, fixes the concerns of the black screen updates this weekend.
- vikino
POD Image HD 2.1 ET9000 07/07/2012
Update 07/07
- Update routine and Enigma2 Plugins
- Update of drivers:
DVB-T-5V
sci-make single-open devices
Improved scan-tuner
WMV-Support
WMA-media
Medium-WAV (pcm wrapped in polyester, to keep sync with video)
alsa-mixer switch to enable / disable audio decoder
Internally-vfd control symbols
Individual symbol vfd-allow override from userspace
-frontend status: Report correct FEC
-startup in 720p Mode
frontpanel:
-Add ET9x00 and ET6x00 new button for remote wakeup
Update 07/07
DVB-T-5V
Improved scan-tuner
WMV-Support
WMA-media
frontpanel:
- vikino
Power of Dreams HD+ 4.0
We are pleased to introduce the new POD HD 4.0 28/08/2013
The upgrade from 3 to 4 can not be done online and requiers a flash image.
Thank you for reading this post before installing
Tu stahuj PodHD-4-et9x00_usb.zip
