http://www.sapro.cz/ftp/index.php?action=view&filename=FAC.HD%20BOX.FS9105HDPVR.v2.10.28.2012Mar23.zip&directory=HD-BOX/HD-BOX%20FS-9105%20HD
- Upgrades & Imporvements :
--> Before Start update pls. stop PlugIns !
--> Weather Forecast function add.
--> Web Radio (Internet Radio+) function add.
--> Series Recording improved
--> Series Recording icon add. to EPG [S]
--> Voulume not working in specific channel solved
--> No Subtitle in BBC World channel solved
--> Tivusat Card Freezing solved
--> Poor SD quality in LED TV improved
--> DVB-T CH LCN not working well solved
--> DVB-T Signal overlapped search solved
--> Terrestrial CH Scan Hotkey Support add.
--> STB Hangup after Pausing and CH Up & Down solved
--> Dissapearing the setting when CI+ message shows solved
--> CI+ Popup Message for Sericelist Manager disabled
--> DVB-C Cable Frequency add.
--> Eternal CI Standard initializing message solved
--> Defult timer setting value changed to Recording
--> DVB-C Service watching & Recorded file play playback problem solved
--> Hang up in continuous EPG in specific channel Solved
--> Noise & Picture Fall-out on certain TV set solved
--> Dolby Digital setting issue solved
--> Background color of Subtitle language changed
--> Freezing with quick zapping solved
--> Cyfra mhw epg doesn't work solved
--> Diverse minor bugs fixed
--> [WebZeal Ver 2.7s / 2.7su ]
--> Arabic QWERTY Keyboard Map add.
--> Available to use English Character with Right Alt key add.
--> Hebrew Language Text Search add.
Internet-Browser_WebZeal_V2.70s:
http://www.octagon-forum.com/index.php?app=core&module=attach§ion=attach&attach_id=11596
