Coolstream Reloaded 12.6.2011 pro ZEE i NEO
postaven na poslením oficiálním 2.03
cs a sk osd,txt ok
oscam, mgcamd, gbox ,newcs ok
cslink, skylink - crytoworks,ice ok
možná záloha celého image z flex menu!!!
picony ok
~ ~ Image 2:03 reloaded based on the SVN version 1537
Changelog:
* Better selection card processing, card for satellite and cable receivers
additional cards entered
* CS Monitor based on mpcs Monitor
* Internet Radio**** Shoutcast active again
* default Oscam 1.0 SVN 5300 active in the Flex menu can be switched to the 0994 SVN 3094
* Test menu in the main menu, re-activated
* Wireless support
* 3d menu icons by Klauser & bazi98
* Piconserkennung improved, jpg, gif, png
* additional channel lists with online update
Important:
Because of changes Oscam, the card reader must be reset, please do not play back from a backup.
Cable users have to do a channel scan, if no backup is recorded
Thanks to all who are in SVN busy operating your plug-ins and deploy, and special thanks to Robby, Duke69, and last but not least JohnDoo Theduke
Ke stažení http://www.2shared.com/file/r5QpCwWM/20 ... e-sum.html
~reloaded~
Images pro přijímače Coolstream ZEE, NEO a Twin.
- EnoSat
- Dostal poděkování: 26 poděkování
Coolstream Reloaded 2.12
Reload image - verzia s PIP
NEW PiP support, tuner setup reworked, persistent favorits. PiG screenshots, Ignore CA messages , youtube player
**GIT Version 874 / 4595-next-cc PIP YT**
+ komplentna slovencina pre tuto verziu
PS: ak by boli navrhy na lepsie vyjadrenie fraz , kludne piste
staci prekopirovat (odstranit priponu TXT) a restartnut
- EnoSat
Re: ~reloaded~
slovencina pre 911-4719
Re: ~reloaded~
Reload - beta verzia 29.05.2014
image funkcny s Doscam V0.19 ! Novsia verzia V0.20 ma problem .
Urcene len pre Nevis stroje (HD1, ZEE, NEO, NEO2 ) - nie pre Apollo stroje !!!
Tu klikni pre stiahnutie
Re: ~reloaded~
Reload - beta verzia z 01.06.2014
odstranuje chyby predoslej verzie , pridane lib pre ffmpeg ...
Zpět na „Coolstream ZEE, NEO a Twin - Images“
