Neutrino Remote Control 1.3
Pluginy a utility pro přijímače Coolstream ZEE, NEO a Twin.
matchboxx
Příspěvek od matchboxx »
Dbox2 1.3
20.10.2011
What is new:
- Remote control
- EPG and channel change I've now put together: At the "Press" of the channel name / channel logo now appears the EPG, the "pressures" on the TV icon on the right side of the screen is switched
- Shift-programmable timer from EPG info out
- Distinction between optical absorption and Shift-timer
IMPORTANT:
According yjogol is in SVN Rev 1686 Coolstream a common mistake, so reading the timer on nhttpd does not work, which consequently also affects my app. This bug should be fixed with SVN Rev 1703 again.
SecretPrivat.com - Don't hesitate
Re: Neutrino Remote Control na Google play
Pre majiteľov androidov je dostupný aj pre Neutrino HD
Cool.Tv
Ten istý maňoš urobil podobnú aplikáciu
https://play.google.com/store/apps/deta ... oltv&hl=sk
Zpět na „Coolstream ZEE, NEO a Twin - Pluginy a utility“
