HD GLASS
- schmegea
HD GLASS
v 3.79
- schmegea
Re: HD GLASS
HD Glass16 ver. 3.85 - pro ty co nepoužívají update přímo ze skinu
- added new option in setup: setup with PIG (yes, no)
- help updated (do it via download menu)
- added title if messagebox is type YESNO (setup messages)
- changed restart gui procedure - fix CAM to stay alive on some HW
- added screen 16,17
- added autoreconfiguration windowstyle for screens 16.17
- previews updated for screens 16,17 (do it via download menu)
- increased speed of skin - switch beetween channels menu etc.
- autoblock bitrate if screens 16,17 are activated
- autoblock fade if alpha is not present on HW
Update is available online via setup
http://www.forum.satdigitalne.cz/viewto ... 619#p71533
- schmegea
Re: HD GLASS
HD Glass16 ver. 3.89
- added detection of DGCrypt (after restore icons type will be set to default type 1, so after update and autorestore you must download icons and previews and then set/select your prefered icons type)
- added download picon white in download menu
- added new style 3
- added screen 18, 19,20
- fix channel selection type 2,4
- added option set style to screen and edit color of title in style
- icons and previews in download are updated
http://www.forum.satdigitalne.cz/viewto ... 619#p72280
- added new style 3
- schmegea
Re: HD GLASS
HD Glass16 ver. 4.07
- fix listing of the history (reaction)
- added colored "ver. X.XX" in the "History"
- schmegea
Re: HD GLASS
HD Glass16 ver. 4.08
- providers picon updated in download black and white (thx ftryskac)
- updated encoding.conf
- added "rec" icon into VU+ Ultimo - OLED type
- fix GraphMultiEPG - latest Nemesis image
- vusolo2
- Dal poděkování: 40 poděkování
- Dostal poděkování: 61 poděkování
Re: HD GLASS
HD Glass 16 ver. 11.00
- added detection of Ncam (after restore icons type will be set to default
- piconCam updated in download
- weather: yahoo pressure autofix if yahoo generate wrong recalculate units
- updated and added et translation (thx zeros, Henkka) to eWea
- fix Find a city if is selected from main menu
- added new option: Detection Progressive/Interlaced in resolution info line
- updated pl, sk, cz, en, ru, de, it, uk, pt, tr, es, fa, al, ro, hu, nl, et, lt
- help updated in download menu
- fix Channel number calculation
- added new Menu type: simply PIG
- added all config values to translations
- pridana detekcia Ncam (po obnove bude zmeneny typ ikon na 1, nasledne
je potrebne stiahnut znova sady ikon a ukazky a potom zvolit svoj oblubeny typ)
- piconCam aktualizovany v downloade
- pocasie: yahoo tlak autooprava ak je zly vypocet zo servera yahoo
- aktualizovany a pridany et preklad(thx zeros, Henkka) - eWea
- oprava "Najdi mesto" ak je predvolene pre Menu
- pridana nova volba: Detekcia Progressive/Interlaced v info riadku s rozlisenim
- aktualizovane pl, sk, cz, en, ru, de, it, uk, pt, tr, es, fa, al, ro, hu, nl, et, lt
- help aktualizovana v ponuke stahovania
- oprava vypoctu cisla kanalu - infobar
- pridany novy Menu typ: simply PIG
- pridane vsetky cfg hodnoty do prekladov - aktualne len sk preklad obsahuje kompletny preklad
update is available online (setup and website)
Thx@shamann
viewtopic.php?f=638&t=14856
[OE2.2] Skin HD Glass 16
Thx@shamann
- vusolo2
Re: HD GLASS
HD Glass 16 ver. 11.22
- updated enhanced weather translations
- changed User defined path to selection of dir by using Location box, if is
Picons/Icons path used as User defined path the one will be set to default value
and you can set your prefered options after autorestore
- updated help sk, cz, en, lt
- setup of the skin: added moving to last item/section if is active first item
press Up/Ch + and moving to first item/section if is active last item press
Down/Ch -
- fix TP info a ECM status
- added new option: Calculation of channel numbers - static/dynamic, section OTHERS
static - recommended for old HW
- added color "grey 5" at all color selection
- added new option: Date format - in sections: INFOBAR/EXTRA INFOBAR, OTHERS,
CHANNEL SELECTION, MENU
- splitted section INFOBAR to sections: INFOBAR,EXTRA INFOBAR,INFOBAR/EXTRA INFOBAR
- added new options: Date (color), Time (color), Seconds (color) in section
EXTRA INFOBAR
- added autodetection of possible OLED type by hw
- fix detection of decoding type - dynamic icons
- added autohiding of options unusable in image/hw
- aktualizovane preklady pre rozsirene pocasie
- zmenena Uzivatelom def. cesta na vyber adresara s pouzitim Location box, ak je
Cesta k picons/ikons nastavena na Uzivatelom def. cesta dojde k jej resetnutiu
na defaultnu, po auto obnove nastaveni je mozne ju nastavit na oblubenu
- aktualizovana napoveda sk, cz, en, lt
- nastavenie skinu: pridane prepnutie na poslednu polozku/sekciu ak je zvolena prva
stlacenim hore/Ch +, a presun na 1 polozku/sekciu ak je zvolena posledna
stlacenim dole/Ch -
- oprava TP info a ECM stav
- pridana nova volba: Vypocet cisla kanalov - staticky/dynamicky, sekcia OSTATNE
staticky - odporucane pre starsi HW
- pridana farba "seda 5" vo vyberoch vsetkych farieb
- pridana nova volba: Format datumu - v sekciach: INFOBAR/EXTRA INFOBAR, OSTATNE,
VYBER KANALOV, MENU
- rozdelena sekcia INFOBAR na sekcie: INFOBAR,EXTRA INFOBAR,INFOBAR/EXTRA INFOBAR
- pridana nova volba: Datum (color), Cas (color), Sekundy (color) v sekcii
EXTRA INFOBAR
- pridana autodetekcia mozneho vyberu typu OLED podla hw
- oprava detekcie typu dekodovania - dynamicke ikony
- pridane auto skrytie volieb ktore v image/hw nie je mozne aktivovat
Thx@shamann
Down/Ch -
EXTRA INFOBAR
stlacenim dole/Ch -
VYBER KANALOV, MENU
EXTRA INFOBAR
Thx@shamann
- vusolo2
Re: HD GLASS
HD Glass 16 ver. 11.34
- updated enhanced weather translations: sk, cz, en, et, lt
- updated pl, sk, cz, ru, de, it, uk, pt, tr, es, fa, al, ro, hu, nl, et, lt
- updated help translations: sk, cz, lt, ru
- INFOBAR: removed - Simple base infobar
- INFOBAR/EXTRA INFOBAR - removed - Date format
- INFOBAR: added - Date format
- INFOBAR: added - Standard Infobar type (including def. Simle base infobar)
- EXTRA INFOBAR: added - Date format, Channel name (color), Event now (color),
Event next (color)
- OTHERS: added - Ignore leading 0 in time
- INFOBAR: added - Standard Infobar type - Standard2
- fix channel number calculation - static
- MENU: added - menu type - with PIG2, with PIG3, with PIG4
- updated in download menu - Menu icons big
- fix date format parser
- added support and detection of DVB-S2X system
- TUNER: added - Hide tuner in standby or missing
- added Extra Infobar 54
- added support for DM900UHD
- OTHERS: added Single EPG type: with PIG(+number, ch.name)2
- OLED: added - oled type (DM900UHD, Vu+ 4k) - Classical, with ZZPicon
- changed Location box to Dir browser for path setting of picons/icons
- HDD: added type Auto (autodetection)
- aktualizovane preklady pre rozsirene pocasie: sk, cz, en, et, lt
- aktualizovane: pl, sk, cz, ru, de, it, uk, pt, tr, es, fa, al, ro, hu, nl,
et, lt
- aktualizovane preklady pre help: sk, cz, lt, ru
- napoveda aktualizovana v ponuke stahovania
- INFOBAR: zrusene - Jednoduchy zakladny infobar
- INFOBAR/EXTRA INFOBAR - zrusene - Format datumu
- INFOBAR: pridane - Format datumu
- INFOBAR: pridane - Typ standardneho infobaru (obsahuje def. pre zakladny infobar)
- EXTRA INFOBAR: pridane - Format datumu, Nazov kanalu (farba), Akt. program
(farba), Nasledujuci program (farba)
- OSTATNE: pridane - Ignoruj 0 ak cas zacina 0
- INFOBAR: pridane - typ standardneho infobaru - Standard2
- oprava vypoctu cisla kanalu - staticky
- MENU: pridane - typ menu - s PIG2, s PIG3, s PIG4
- aktualizovane v downloade - Menu ikony velke
- oprava parsera pre format datumu
- pridana podpora a detekcia DVB-S2X systemu
- TUNER: pridane - Skryt tuner v pohotovosnom rezime alebo chybajuci tuner
- pridany Extra Infobar 54
- pridana podpora pre DM900UHD
- OSTATNE: pridany typ pre "Jeden EPG" - s PIG(+cislo, nazov kanalu)2
- OLED: pridane typ OLED (DM900UHD, Vu+ 4k) - Klasicky, s ZZPicon
- zmeneny Location box na Dir browser pre nastavenie cesty k picons/icons
- HDD: pridany typ Auto (autodetekcia)
Thx@shamann
Event next (color)
et, lt
Thx@shamann
- vusolo2
Re: HD GLASS
HD Glass 16 ver. 11.38
- fix getting of HDD tmperature
- edited: Standard Infobar2 and Extra Infobar 33, 54 and Extensions list
- CHANNEL SELECTION: changed - New style(colored list) changed to New style2
- added Extra Infobar 55, 56
- help, extrascreens graphics a previews updated in download
- OLED: added - oled type (DM900UHD, Vu+ 4k) - Classical2
- fix USER INFO - system info
- WEATHER: fix SSL certificate error - Yahoo provider
- fix management of path setting of picons/icons
et, lt
- oprava ziskania teploty HDD
- upravane: standardny infobar2, extra infobar 33, 54 a zoznam rozsireni
- VYBER KANALOV: zmenene - typ Novy styl(farebny list) zmeneny na Novy styl2
- pridany Extra Infobar 55, 56
- OLED: pridane - typ OLED (DM900UHD, Vu+ 4k) - Klasicky2
- oprava pre USER INFO - system info
- napoveda, extrascreen grafika, a ukazky aktualizovane v ponuke stahovania
- POCASIE: oprava chyby certifikatu SSL pre Yahoo v OE 2.5
- oprava riadenia pre nastavenie cesty k picons/icons
Thx@shamann
et, lt
Thx@shamann
- vusolo2
Re: HD GLASS
HD Glass 16 ver. 11.63
- aktualizovany lcstrings.list
- oprava zobrazenia titulu vo vybere kanalov
- oprava extra EPG renderera
Thx@shamann [OE2.2]
Thx@shamann [OE2.2]
- vusolo2
Re: HD GLASS
HD Glass 16 ver. 11.65
- oprava renderera orezavania title
- opravy/korekcie roznych screenov
- pridana alternativna metoda pre overenie dostupnosti aktualizacie
ak sa online aktualizacia neponuka mozte spravit 1 z nasledujucich moznosti:
1. zmenit IP adresu v kapitole "SIET" v nastaveniach HDG (aktualne pouzita nefunguje) potom skusit online update znova
alebo
2. instalovat manualne ipk/deb 11.65 a dalsi update uz bude fungovat normalne
[/color]
Thx@shamann
alebo
[/color]
Thx@shamann
- vusolo2
Re: HD GLASS
HD Glass 16 ver. 11.67
- fix/corections more of screens
- fix support extended version of bitrate plugin
- changed update dialog
et, lt
- oprava podpory pre rozsirenu verziu bitrate pluginu
- zmeneny dialog pre aktualizaciu
Thx@shamann
et, lt
Thx@shamann
- vusolo2
Re: HD GLASS
HD Glass 16 ver. 11.70
- added alternative method to detect IPTV stream
- WEATHER: added support of SSL certificates
- OTHER: removed - user encoding.conf (deb version only)
- fix oscam ymod version detection
- added detection of modulation 16APSK, 32APSK (DVB-S/S2 only)
et, lt
- pridana alternativna metoda detekcie IPTV stream-u
- POCASIE: pridana podpora pre SSL certifikaty
- OSTATNE: odsranene - user encoding.conf (len deb verzia)
- oprava detekcie oscam ymod verzie
- pridana detekcia modulacie 16APSK, 32APSK (len pre DVB-S/S2)
Thx@shamann
et, lt
Thx@shamann
- vusolo2
Re: HD GLASS
HD Glass 16 ver. 11.71
- Setup of HDG: removed numbering of chapters
- fix all Extra Screens: displaying 16APSK, 32APSK modulation
- Nastavenia HDG: zrusene cislovanie kapitol
- oprava vsetkych Extra Screenov: zobrazenie 16APSK, 32APSK modulacie
Thx@shamann
Thx@shamann
- vusolo2
Re: HD GLASS
HD Glass 16 ver. 11.72
- added alternative method to searching of picons
- added next alternative method to searching of picons (if missing search 1_0_1...,
1_0_16..., 1_0_19...)
et, lt
- pridana alternativna metoda vyhladania piconov
- pridana dalsia alternativna metoda vyhladania piconov (ak chyba hlada 1_0_1...,
Th@shamann
et, lt
Th@shamann
