dreamboxedit
dreamboxedit
Program na upravu programov pre DM
- 005jon
- Dostal poděkování: 157 poděkování
Re: dreamboxedit
DreamBoxEdit 4.0.1.0
- fixed sorting services in bouquet panel was broken after adding channel numbers to the bouquet panel
- fixed error when sorting bouquets with cable and terrestrial services
- fixed some other functions were also broken after adding channel numbers to the bouquet panel
- fixed hour glass didn't get away after loading new settings
- fixed error message when using picon cleanup function and filename wasn't using proper picon reference format
- fixed alternatives are no longer considered as duplicates of fixed services in the same user bouquet
- fixed alternatives handling, now you can use the same service with and without alternatives in one user bouquet
- fixed blacklist entry for radio user bouquets
- fixed all files are now written in proper settings-type 4 format
- fixed auto insert markers for cable and terrestrial services
- added Enigma2 restart button to ftp window, use this button to activate any changes related to lamedb and/or black-/whitelist
use the autoreload or "reload settings on dreambox" button if you only change your userbouquets
- added sorting of profiles in options panel
- changed satellites in filter combobox are now sorted by position from west to east
- changed profile default paths to enigma2 defaults
- window state is now saved on application close, and restored when application is started
- some minor fixes
- language files updated
DreamBoxEdit_setup_4.0.1.0.zip
________________________________________________________________________
4.0.1.1
- fixed alternatives filename generation
- fixed error message after opening Enigma1 settings
- fixed total service counter was overlapped by displayed service counter after startup without settings
DreamBoxEdit_setup_4.0.1.1.zip
4.0.1.2
- fixed userbouquets with renamed services are now written in proper settings-type 4 format
- fixed problem when saving cable or terrestrial settings (some parameters were lost)
DreamBoxEdit_setup_4.0.1.2.zip
4.1.0.0
- added crypto icon in main service list if service is encrypted (Note: this is only working properly on future Enigma2 Images)
- added filter for encrypted and unencrypted services (Note: this is only working properly on future Enigma2 Images)
- added copy service reference to clipboard option to context menu of main service list and bouquet panel
- added a info window with some informations about the new filtering behaviour
- fixed error message when using add new service option in context menu
- fixed application hanging when parsing lamedb with corrupted transponder entry
- fixed problems after adding new services, the services weren't covered by the filters
- some minor fixes
DreamBoxEdit_setup_4.1.0.0.zip
- some minor fixes
4.0.1.1
4.0.1.2
4.1.0.0
- some minor fixes
Re: dreamboxedit
4.1.0.1
- fixed problem with profile selection in options panel
- fixed missing parameters for cable settings after Enigma1->Enimga2 conversion
bez inštalácie, stačí len rozbaliť
Re: dreamboxedit
DreamBoxEdit 5.0.0.0
5.0.0.0
- added completly new GUI with skinning support
- added transparency to crypto icon in main service list
- added transparency to dummy picon in bouquet panel
- added configurable color marker for selected services
- added proper handling of renamed alternatives
- added warning message if multibouquet is disabled on your dreambox
- added signal strength indicator
- fixed renumbering channel numbers after using "sort alphabetically" from context menu
- fixed when sorting by frequency now also sorting by polarisation is applied
- fixed problem with missing objects (service counter, profile selection)
- fixed cut&paste services with alternatives
- fixed saving of current profile when options panel is closed
- integrated language tool (Help -> Language Tool)
- removed LanguageTool.exe from installation package
- removed outdated help files
- some minor fixes
The the following features are only supported on genuine Dreamboxes
with Enigma2-Images based on Release 3.2 or higher
- full support for filtering of encrpyted services is now enabled
- full support for streaming services in userbouquets
- added video streaming support
Note: VLC 1.1.11 or higher is required, the installation directory is detected automatically, if you are using
a portable version set the VLC installation directory in the options panel.
- added support for taking snapshots of currently played stream
"exotické" jazyky som vyhodil, nechal som len Czech, English, Deutsch
Czech.lng som opravil
5.0.0.0
- some minor fixes
Re: dreamboxedit
DreamBoxEdit 5.0.0.1
Changelog:
5.0.0.1
- fixed compatibility problems when running dreamboxEDIT under wine
Note: skinning support is automatically disabled, Wine 1.3.34 or higher is mandatory
- some language file updates
5.0.0.1 - bez inštalácie
stačí len rozbaliť
Czech.lng som opravil - stále tam bol ten bug
u komplet instalace je třeba překopírovat czech.lng do adresáře s nainstalovaným dreamboxedit
Changelog:
5.0.0.1
stačí len rozbaliť
- schmegea
- Mazák
Re: dreamboxedit
5.0.1.0
- added new hints in main list, now with bouquet references
- fixed application closing after canceling
- fixed error message after dropping service on current bouquet
- fixed main service list refresh after selection of another bouquet
http://www.forum.satdigitalne.cz/viewto ... 013#p80013
- vusolo2
- Dal poděkování: 40 poděkování
- Dostal poděkování: 61 poděkování
Re: dreamboxedit
dreamboxEDIT 7.0.0.0
Changelog:
7.0.0.0
- added support for editing of non-TS streaming services with full reference
- added copying of existing service reference to an IPTV service (hold down CTRL while using drag&drop)
- added rename of IPTV services to context menu
- added automatic IPTV service name formating
- added picon support for streaming services with full reference
- added picon setting for using 4097_... service ref for filename (if needed)
- added service type indicators (SD, HD, UHD, H.265, Radio, Data) in front of servicenames
- added more filter options (SD, HD[H.265], UHD[H.265], DVB-T2)
- added support for DVB-T2 (only cosmetic changes, older versions already work with DVB-T2)
- added support for DVB-S2 modulations 16APSK and 32APSK
- added support for multistream MIS/PLS (fully editable in satellites.xml editor, service details, transponder edit)
- added playback of IPTV streams
- added automatic replace of invalid polarization values (some satellites.xml use polarization L/R instead of 2/3)
- added copyable service reference with colons to service details
- added insert hidden marker to context menu (enable fastscan/hidden marker support first in options panel advanced)
- added support for unknown services in userbouquets (includes former known subservices) (options panel advanced)
- added experimental option to save lamedb5 format (OpenPLi)
- added configurable buffer size for streaming player (options panel GUI)
- updated streaming player
Note: VLC 2.2.4 is recommended (32-bit only), any other version may or may not result in error messages
- improved crypto icon (encrypted services) in front of servicenames
- improved reading speed on userbouquet switch
- improved picon resizing speed
- improved marker visualization
- improved Wine compatibility (Wine 1.8.3 recommended)
- improved compatibility with "Parallels Desktop for Mac" coherence mode
- dropped support for obsolete settings format 3
- re-enabled the export of terrestrial services/bouquets in Excel readable format
- fixed hiding of alternatives view after reading new lamedb
- fixed removing alternatives if a service is removed from all bouquets
- fixed user bouquet import with hidden markers
- fixed rendering of disabled menu items
- fixed memory exception when copying IPTV services from one dreamboxEDIT session to another one
- many GUI improvements (including the new MetroUI standard skin)
- language file updates, addes missing ones to setup xe file
- minor fixes
- fixed dreamboxEDIT installer, now the registry is cleaned properly on uninstall again
Note: before reporting any bugs, please try to uninstall first if you experience any issues
if you experience any issues with the file open dialog, switch to the old style dialog (options panel general)
Changelog:
7.0.0.0
- minor fixes
- vusolo2
Re: dreamboxedit
dreamboxEDIT 7.0.1.0
Changelog:
7.0.1.0
- added support for real hidden markers (#SERVICE 1:832:d:0:0:0:0:0:0:0:)
- fixed autoexpand of provider bouquetlist when using create bouquet from context menu
- fixed dreamboxEDIT installer, remove all files properly on uninstall
Changelog:
7.0.1.0
- vusolo2
Re: dreamboxedit
dreamboxEDIT 7.1.0.0
7.1.0.0
- added option to disable service type indicators in front of servicenames (options panel GUI)
- added new cleanup function for local picon directory (removes all picons not found in any user bouquet)
Note: the other option removes only picons not found in both lamedb AND user bouquets
- added High-DPI support / scaling natively without losing sharpness
- added scaling factors 100%, 125%, 150% and auto (depends on system setting)
Note: this will override the font size selection which is now only used on 100% factor
- added 64-bit build of dreamboxEDIT
Note: use VLC 32-bit for standard and VLC 64-bit for x64 version of dreamboxEDIT
- improved dreamboxEDIT installer: new accessibility options (high contrast mode, scaling mode)
- improved automatic VLC path detection for use with 32-bit/64-bit dreamboxEDIT/VLC at the same time
- improved manually set VLC path is now separately saved for 32-bit/64-bit VLC
- fixed writing hidden/numbered markers (some invalid descriptions were written before)
Thx @ dhwz
7.1.0.0
Thx @ dhwz
- vusolo2
Re: dreamboxedit
DreamBoxEdit 7.2.0.0
- pridaná podpora služby eServiceUri
- pridalo sa automatické posúvanie na pohyblivých profiloch
- pridalo sa k pohybu viacerých profilov naraz
- pridali indikátory typu zapnutia / vypnutia bez reštartu
- pridaný faktor škálovania 200%
- lepšie písať všetky linebreaks ako Unix (LF) nie Windows (CRLF)
- vylepšená manipulácia s MIS / PLS
- vylepšené chybové hlásenia
- pevné počiatočné predvolené náplasti
- opravené problémy s dialógom výberu cesty
- opravené nejaké nezvyčajné chyby pri písaní značiek (zavedené poslednou aktualizáciou)
- pevne priradenie a odstránenie picónov v hlavnom zozname služieb
- opravené knižnice OpenSSL (chýbali x64 súbory)
- opravená nesprávne fungujúca funkcia "Označiť služby, ktoré nie sú v Userbuite s príznakom X"
- opravená chyba pri vývoze kytice / služieb
- pevne preskočiť niektoré úplne neplatné vytvorené buketové záznamy niektorých poskytovateľov IPTV
- pevný editor satellites.xml (transpondéry neboli vymazateľné, ak neboli potvrdené otázky)
- pevné odkazy na webové stránky
- niektoré zlepšenia grafického rozhrania
- Aktualizácie zabezpečenia OpenSSL
- aktualizácie jazykových súborov
- added eServiceUri support
- added autoscrolling on moving profiles
- added moving multiple profiles at once
- added switch on/off service type indicators without restart
- added scaling factor 200%
- improved write all linebreaks as Unix(LF) not Windows(CRLF)
- improved MIS/PLS handling
- improved error messages
- fixed initial default pathes
- fixed issues with path selection dialog
- fixed some uncommon bug when writing markers (introduced by last update)
- fixed assign and remove of picons in main service list
- fixed OpenSSL libraries (x64 files were missing)
- fixed not properly working function "Mark services not in Userbouquets with flag X"
- fixed error on export of bouquets/services
- fixed skipping of some completely invalid formed bouquet entries of some IPTV providers
- fixed satellites.xml editor (transponders weren't deleteable if confirmation questions were disabled)
- fixed website links
- some GUI improvements
- OpenSSL security updates
Thx @ dhwz
https://ulozto.sk/!vApOg33ZJ03l/dreambo ... -2-0-0-zip
Thx @ dhwz
