Cyklicky restart
Napsal: 30 srp 2013, 11:28
Po nastartovani prijimaca dochadza k jeho opakovanemu restartu. Mam fw 2.11.61. Pripojil som ho cez RS232 s PC a spustil program Putty, cez ktory som dostal k nasledovnemu logu:
-- ST7111 Sat Loader ( IR ) -- V3.11
▒▒wD▒FrTs
init started: BusyBox v1.14.2 (2012-03-12 15:08:37 KST)
root::0:0:root:/root:/bin/sh
/etc/rcS: line 497: udevtrigger: command not found
/etc/rcS: line 498: udevsettle: command not found
Starting app: #### ERROR Get System Information ##### (0)
STLIB_Init......
VOUT_FindI2cNumForHDMI 2
SECTOOLFUSE_Setup(SECTOOLFUSE_00)==============================================================================
[00:00] --STLIB_Init OK
..... [WiA8293_IicInit] error 0
Front_IrInit : et6202_fd(ffffffff)
[FRONT] fd_front=31
# VFD type : 10002, ver : 1
_micom_type : 65538
..... pes start [0][0], buffer 0
..... pes start [0][0], signal 0
..... pes start [1][0], buffer 0
..... pes start [1][0], signal 0
..... pes start [0][1], buffer 0
..... pes start [0][1], signal 0
..... pes start [1][1], buffer 0
..... pes start [1][1], signal 0
StarCi_I2c_Read I2C_Read error3 : 7 (1 0)
StarCi_I2c_Write I2C_Write error1 7 (1 1)
StarCi_I2c_Read I2C_Read error3 : 7 (2 1)
StarCi_I2c_Write I2C_Write error1 7 (2 2)
====== Start Main Application =============
[01:52] --Init Wi OK
Fri May 31 22:00:01 UTC 2013
STSECTOOLFUSE_CRYPT_SIGCHK_ENABLE_OTP_ITEM 0x1
STSECTOOLFUSE_DIRT_DISABLE_OTP_ITEM 0x1
statusReg 0x00010001
output->fstatus 1 1 1 0, statusSw 0x01010001
V logu su vykazovane chyby, moze v tomto pripade pomoct postup uvedeny v prispevku viewtopic.php?f=166&t=6834 ohladom vymazania pamate uptd_user, alebo je prijimac zrely na reklamaciu?
▒▒wD▒FrTs
STLIB_Init......
[FRONT] fd_front=31
_micom_type : 65538
