Kompletný plugin pre fw 1.08.34 a vyššie
Společné pluginy pro HDBox.9100,9105,9200,9300,7110,8000
dempsey
Příspěvek od dempsey »
Please use attached new plugin for your HD receivers.
You have to use it on IRD S/W over v1.08.34
You just need to unzip and move to USB memory stick and then press Red button on plugin upgrade section
Release note
- There was bug when you use Mcas, XcamClient, Kain2r and ExSIM in same time, but now it is solved.
- You can use your receiver as server and client.
Please refer to the below detailed explanation.
Home Network Sharing
Both Server and Client receiver need to be connected by internet.
Client Server receiver and client receiver have to have same Gate way address to share card key data in case Home Network
You can also use this feature to share your card key data to others who are living some other places, but they have to use public IP address and not having Gateway
Mcas
Instruction
- make started by Green button and then press OK button
- you will see ‘smart card 2’ and ‘server setting’ menu if your receiver has smart card inside
- enter ‘server setting’ menu by press OK
- ‘port’ : don’t need to change port and it is better to leave as default, but you can change it as 5 digits if you need and it is safe.
- ‘user setting’ : you can input user id and password to allow connecting to server receiver by client who is listed inside user setting menu.
- ‘auto start’ : you can change as ‘on’ if you want to start this server menu when you start Mcas plugin
- login confirmation : you can change as ‘on’ if you want to check user id and password from client receiver
Mclient (Mcas client - don't change name to Mclient : there is a bug on plugin menu)
Instruction
- there is a input space for server address (IP address of server receiver), port, user id, password
- To edit server address, you need to press your own master key then input the IP address of server receiver (no need //)
- lastly, go to the ‘connect to server’ and press ‘OK’ button
Mgcamd
To use mgcamd with other plugin, it has to be released newly by using 1.02 version plugin API
please don't use mgcamd with the other plugin at the same time before renewal ! ! !
We will send this API separately and it’s up to you use this file or not.
There will be no problem with mgcamd auto start issue with this new plugin, but there is less possible to be disconnected.
It can be debugged mgcamd provider to make stable auto start option.
He can use ‘res_init() when gethostbyname’ function is failed and if it is failed he can try again
after few seconds using ‘WiTimer_AfterQueue’ function( refer ibox plugin sample ).
Zpět na „Společné pluginy pro HDBox“
