Trinity original firmware
Images pro přijímače Coolstream Trinity
matchboxx
Příspěvek od matchboxx »
03.02.2014 - Version 2.13 RELEASE
* add persistent /var partition, now all settings preserved when new image flashed
* file player: improved mkv and avi playback
* audio player: add support for AAC codec
* EPG scan now do rescan every 24 hours
* Many fixes and improvments
To switch between the Standard Menu and the Simplified Menu, press
MENU button on your RCU, then press "STOP" button on PVR control section,
follow the on-screen guidance (input pin 0000), then choose YES to reboot your device.
ATTENTION: Only through the Standard Menu you can experience the full functions of Neutrino HD
:arrow: Tu klikni pre stiahnutie Trinity 2.13_03_02_2014
Po stiahnuti rozbalit !!!!
Soukrome zpravy nectu, pouzivejte forum, mozna tim pomuzete ostatnim
Dal poděkování: 3 poděkování
Dostal poděkování: 26 poděkování
Re: Trinity original firmware
slovencina pre 2.13
matchboxx
cestina tank&trinity 2.13
matchboxx
update apollo 19032014
Quellcode
M. Liebmann CLuaInstance: Add runScript() function for using in...
M. Liebmann CLuaInstance: Optional specification of parameters...
M. Liebmann CStringInputSMS: Add '%' to valid chars
M. Liebmann CLuaInstance: Replace cwindow header_height & footer_height
M. Liebmann CLuaInstance: Add various CComponentsPicture functions
M. Liebmann CLuaInstance: Add setCaption & paintHeader function...
M. Liebmann CLuaInstance: Add function 'functionDeprecated()' for...
M. Liebmann CLuaInstance: Add setText function to ctext
M. Liebmann CLuaInstance::ComponentsTextNew: Add 'parent' parameter...
M. Liebmann CLuaInstance: Add additional tableLookup for get userdata
M. Liebmann CLuaInstance: Add debug output to CWindowDelete/Compone...
M. Liebmann CRecordSetup: Fix menu hint specifier
M. Liebmann Update deutsch.locale
FlatTV record menu: add filename template
[CST] Focus neutrino.cpp: set satellite position for generated...
[CST] Focus gui/bouquetlist.cpp: allow to delete whole satellite...
[CST] Focus zapit/src/getservices.cpp: add code to remove channels...
[CST] Focus zapit/src/capmt.cpp: stop cam if channel not found
[CST] Focus zapit/src/bouquets.cpp: use INVALID_SAT_POSITION instea...
[CST] Focus zapit/include/zapit/types.h: add INVALID_SAT_POSITION...
neutrino_update_apollo_27_04_14_1810
[CST] Focus	gui/movieplayer.cpp: while starting file play, process...
[CST] Focus	mdev_helper.cpp: add device hotplug neutrino helper
[CST] Focus	gui/hdd_menu.cpp: convert to singleton;
[CST] Focus	locals: add locale for hdd hotplug messages
[CST] Focus	system/helpers.cpp: add split_config_string helper
[CST] Focus	driver/rcinput.cpp: add NeutrinoMessages::EVT_HOTPLUG
Jacek Jendrzej	make auto ScreenShot with short video
[CST] Focus	gui/scan_setup.cpp: set diseqc options only for satelli...
martii	gui/movieplayer: compare timeshift to TSHIFT_MODE_*
[CST] Focus	fix warnings if some want to use c++11
[CST] Focus	gui/movieplayer.cpp: auto-create movie thumbnail, if...
[CST] Focus	gui/moviebrowser.cpp: prevent title and movie info...
[CST] Focus	gui/record_setup.cpp: add option to auto-create movie...
M. Liebmann	MoviePlayer: Fix display 'info clock' and 'file time...
martii	gui/movieplayer: show epg info in non-movieplayer modes...
Jacek Jendrzej	make info copy only in timeshift mode
Jacek Jendrzej	nhttpd: -add Chech by marsim21
Jacek Jendrzej	src/neutrino.cpp -fix timer zap with mode (TV/Radio...
Christian Schuett	movieplayer: add possibility to show movie infos
Jacek Jendrzej	use auto lang only with more as 1 audio pid
[CST] Focus	gui/hdd_menu.cpp: fix menu, if format canceled;
[CST] Focus	gui/videosettings.cpp: add option to enable/disable...
[CST] Bas	settings: implement 23.97hz and 29.97hz video modes.
[CST] Bas	lib/libcoolstream2/video_cs.h: add 23.97hz and 29.97hz...
Novy update pre CST 2.13 HD2 - original image v Trinity.
:arrow: http://www.forum.satdigitalne.cz/viewto ... 74#p105674
Update driver a neutrino pre original image CST 2.13
- drobne opravy (ecm info, aktivacia piconov kodovacich systemov atd...)
- oprava FastScan - -skylink
- rozsirena podpora prehratelnych medii - kombinacii kodekov
Najskor nahrat dirver_update.bin a az po restarte neutrino_update.bin
Po nahrani je potrebne opat nastavit tuner !!!!
Update je spolocny pre boxy Tank a Trinity .
:arrow: :arrow: http://www.forum.satdigitalne.cz/downlo ... p?id=12091
Update neutrino 09.07.2014
Subory su spolocne pre Tank a Trinity.
Najskor nahrat driver update a az po restarte neutrino update .
driver/record: auto-terminate temporary timeshift recor...
M. Liebmann CLuaInstance::SignalBoxNew: Add 'parent' parameter...
svenhoefer - moviebrowser: prevent segfault at movies w/o channellogo
[CST] Focus gui/moviebrowser.cpp: fix off-screen draw, if OSD heigh...
[CST] Focus gui/scan_setup.cpp: add signal test menu on request
[CST] Focus gui/scan.cpp, gui/motorcontrol.cpp: increase signal...
[CST] Focus gui/network_service.cpp: add dropbear
[CST] Focus gui/network_service.cpp: change djmount charset option...
[CST] Focus gui/motorcontrol.cpp: change signal/snr layout to vertical
[CST] Focus gui/scan.cpp: change signal/snr layout to vertical
[CST] Focus neutrino.cpp: zap also with page up/page down buttons
M. Liebmann CMovieBrowser: Use CComponentsChannelLogo for display...
M. Liebmann CChannelList: Use CComponentsChannelLogo for display...
M. Liebmann CComponentsChannelLogo: disable paint of logo backgroun...
M. Liebmann CTextBox: Add Flag m_renderMode (Font::FULLBG) for...
M. Liebmann Fix sort order in english.locale
svenhoefer - neutrino_menue: add own personalize item to standby...
Thilo Graf CChannelList: disable paint of clock background, it...
Thilo Graf CComponents: implement scroll functionality into CCompo...
Thilo Graf CComponentsPicture: use current instance of CPictureViewer
Thilo Graf CComponentsForm: add functions to get first and last...
svenhoefer - osd_setup: don't show colored progress bar option...
svenhoefer - yWeb: show correct RCU at Zee²
svenhoefer - neutrinoyparser: detect Zee²; fix Boxmodel for Trinity
Christian Schuett libconfigfile: accept booleans as int32 or int64
Thilo Graf CChannelList/COsdSetup: use showOsdChanlistSetup()...
Thilo Graf CComponentsWindow: add missing comment for sidebars
Thilo Graf CComponentsForm: don't consider frame for position...
Thilo Graf CComponentsForm: add comment
Thilo Graf CComponentsItem: remove unnecessary calculation of...
Thilo Graf CComponentsPicture: structure of class highly simplified
Thilo Graf CComponents: epand method setFrameThickness() to change...
Thilo Graf CProgressWindow: implement CComponent classes
Thilo Graf CMenuWidget: add member to suppress paint of details...
Thilo Graf CComponentsText: add function to get current text conte...
Thilo Graf CComponentsForm: add methode killCCItems()
Thilo Graf CComponentsWindow: add possibilty to add sidebars in...
Thilo Graf CComponents: inherit COSDFader class
Thilo Graf CFrameBuffer: reduce fade time
Thilo Graf COSDFader: rename member functions, adapt implementations
svenhoefer - channellist: add colored progressbars
martii gui/infoviewer: remove no longer used class member...
svenhoefer - yWeb: fix MODE_RADIO/MODE keys in RCUs
[CST] Focus zapit/src/frontend.cpp: fix cable tune log
martii gui/epgview: replace left/right chars with correspondin...
[CST] Bas fastscan: fix astra1 scan in case there is only one...
[CST] Bas src/gui/streaminfo2.cpp: fix possible integer overflow...
[CST] Focus gui/luainstance.cpp: add function to start file/url...
[CST] Focus gui/movieplayer.cpp: add 'http' action key, with cut...
:arrow: driver_update
:arrow: neutrino_update
Dal poděkování: 174 poděkování
Dostal poděkování: 261 poděkování
Příspěvek od marsim21 »
Update neutrino 30.08.2014
Soubory jsou společné pro Tank a Trinity.
1) Na originál 2.13 nejdříve nahrát driver update. bin
http://www.forum.satdigitalne.cz/downlo ... p?id=12153
2) Poté nahrát soubor prepare-apollo-cst_img-2.13
http://www.forum.satdigitalne.cz/downlo ... p?id=12154
3) Poté nahrát soubor neutrino update apollo 30.08.14 1826
http://www.forum.satdigitalne.cz/downlo ... p?id=12155
Trinity CST 2.15 beta ! dostupny uz aj ako online aktualizacia .
Velkost image 33,85MB .
slovencina od EnoSat :arrow: download/file.php?id=12283
Doscam v23 pre tuto verziu image :arrow: viewtopic.php?f=492&t=13461&p=106884#p106884
Coolstream Originalimage 2.15Beta z 08.01.2015
fix 8PSK , pilot HW/WS detekcia , fix playback
PS: stale neopravena chyba s EPG na 1W/11727V
Update CST original 2.15 beta - 02.02.2015
* fix auto-timeshift interrupted after stop playback
* add option to cache EPG only on channels present in favorite bouquets
dostupny aj ako online aktualizacia.
2.15 Final 02.04.2015
* bug fixes including some crashes
* speedup channel list and image info GUI
:arrow: Download-Trinity
Dnes nám po delší době vyšla nová verze images 3.01 pro Tank a Trinity.
Dostupná je na Ftp v menu přijímače.
VAROVÁNÍ! downgrade je možný pouze 2,15 image, ne starší!
Quoted
Software Update Wizard - Agreement
Do not perform updates using any data other than the official update data from our website.
Using Software Updates You expressly acknowledge and agree that use of this Software is at
your own risk.
In no event shall Coolstream LTD be liable for any damages whatsever.
Contact info@coolstreamtech.com for any questions about our Software.
Warning:
We offer 2 Images, please be aware and use the correct Software for your Unit!
Bitte die Software entsprechend der Hardware downloaden!
18.11.2015 - Version 3.01 release
* youtube playback fixed (thanks FlatTV)
* add var and root1 backup (thanks M. Liebmann)
* add option to auto-answer CI pin code
* add file/TS/webtv average bitrate in stream info
* fix webtv parental locking
* various fixes and improvements
WARNING! downgrade only possible to 2.15 image, not older !
reboot your device.
of Neutrino HD
Opět po delší době vyšla nová verze images 3.02 Beta z 28.03.2016 pro Trinity.
Download
Zpět na „Coolstream Trinity - Images“
