snad to může byt v tomto vláknu.
Vitamin Pro a testuji co přehraje - zkoušel jsem následující video (.AVI s bitrate asi 4500Kbps) - dělá to i u dalších podobných
General
Complete name : W:\necoasdf.avi
Format : AVI
Format/Info : Audio Video Interleave
Format profile : OpenDML
File size : 3.34 GiB
Duration : 1h 44mn
Overall bit rate : 4 552 Kbps
Movie name :
Writing application : VirtualDubMod 1.5.10.1 (build 2366/release)
Writing library : VirtualDubMod build 2366/release
Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 5
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 44mn
Bit rate : 3 641 Kbps
Width : 1 280 pixels
Height : 688 pixels
Display aspect ratio : 1.85:1
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.172
Stream size : 2.67 GiB (80%)
Writing library : XviD 64
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : 2000
Duration : 1h 44mn
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Delay relative to video : 35ms
Stream size : 336 MiB (10%)
Alignment : Split accross interleaves
Interleave, duration : 42 ms (1.00 video frame)
Interleave, preload duration : 500 ms
Audio #2
Format : AC-3
Codec ID : 2000
Duration : 1h 44mn
Bit rate : 448 Kbps
Bit depth : 16 bits
General
Unique ID : 206349332736130078030432414820221456408 (0x9B3D6F969FA49AA9A65501681F621018)
Complete name : W:\neco2[3D SBS].mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 9.35 GiB
Duration : 1h 44mn
Overall bit rate : 12.8 Mbps
Encoded date : UTC 2013-11-24 12:21:43
Writing application : mkvmerge v6.5.0 ('Isn't she lovely') built on Oct 20 2013 12:50:05
Writing library : libebml v1.3.0 + libmatroska v1.4.1
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 44mn
Bit rate : 11.2 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.226
Stream size : 8.22 GiB (88%)
Writing library : x264 core
Language : English
Default : Yes
Forced : No
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio #1
Format : AC-3
Codec ID : A_AC3
Duration : 1h 44mn
Bit rate : 640 Kbps
Bit depth : 16 bits
Stream size : 480 MiB (5%)
Title : cz
Language : Czech
Default : Yes
Forced : No
Audio #2
Format : AC-3
Codec ID : A_AC3
Duration : 1h 44mn
Bit rate : 640 Kbps
Bit depth : 16 bits
Title : sk
Language : Slovak
Default : No
Forced : No
Je to tím, že azbox má nějaký lepší čip na akceleraci videa, nebo mám něco blbě nastavené?
Díky.
