WeTekPlay PBNIGMA VX 5.1
Moderátor: matchboxx
- matchboxx
Re: WeTekPlay PBNIGMA VX 5.1
EDIT 6.10.15
- Elec RC still in limbo state
- provide info about Kodi partiton
- enable option to save Kodi settings from E2 backup (mark /media/uSDextra/.kodi)
- no need to reflash
ke stazeni http://pb-download.com/images/5.1/wetek ... sdcard.zip
Soukrome zpravy nectu, pouzivejte forum, mozna tim pomuzete ostatnim
- matchboxx
EDIT 8.10.15
- teletext fixed
ke stazeni http://anonym.to/?http://pb-download.co ... sdcard.zip
- teletext fixed
- matchboxx
EDIT 11.10.15
- re flash of micro SD needed
- new kernel, some fixes related to HID devices
- Kodi updated to rc3
- some unrelated Kodi fixes
- feeds updated
- note: as this is not properly tested, the old link is still active
Kodi 15.2 rc3, untested:
- feeds updated
- matchboxx
EDIT 17.10.15
- switched to a different build system
- new kernel, some experimental fixes
- Kodi updated
- more addons should work out of the box, including those that screw your Kodi :)
- new airplay support, possible that iOS 9 works
- feeds updated
- new E2 code
- dozens of fixes
- Elec RC probably works. Thx to all that helped. Select Elec RCU, select Elec keymap.
- backup from E2 now covers Os*am settings and Kodi by default. Kodi stuff could take a lot of space.
- note: as 3 major items have changed, there is more than a reasonable possibility that some things wen't wrong.
- note 2: as this is not properly tested, the old link is still active.
- note 3: if happy with your current image, just do NOT do on-line update as it would probably fail.
ke stazeni
- Kodi updated
- feeds updated
- new E2 code
- dozens of fixes
ke stazeni
- matchboxx
kdo chce muze vyzkouset tureckou zalohu od mach1, pokud se vam podari prepnout na cestinu a odinstalovat nepotrebne pluginy je to hodne dobre vcetne KODI , kde muzete vyzkouset i extra skiny
Confluence
Confluence-hyw2015 mod by TheHighway
Backrow
Eminence
Aeon mq6
Aeon maniac nox5
A iptv pres IPTV simple klienta
http://www.tvimages.com/upload/index.ph ... E2Backups&
Confluence
Backrow
Eminence
Aeon mq6
Aeon maniac nox5
- dpabox
uz vyše tyzdňa používam anglickú verziu backup od MACH1 - veľmi vydarený komplet backup včetne KODI 15.2 , ako som už spomínal v
http://www.forum.satdigitalne.cz/viewto ... 87&t=14479
Odinštaloval som niektoré plugin, avšak tie turecké sa mi nepodarilo odinštalovať. Vrele doporučujem na používanie okrem oscamu a vlastného nastavenia prakticky nič netreba nastavovať v tomto softe ....
matchboxx píše:kdo chce muze vyzkouset tureckou zalohu od mach1, pokud se vam podari prepnout na cestinu a odinstalovat nepotrebne pluginy je to hodne dobre vcetne KODI , kde muzete vyzkouset i extra skiny
Confluence
Backrow
Eminence
Aeon mq6
Aeon maniac nox5
- matchboxx
turecke pouze manualne :-)
- matchboxx
EDIT 21.10.15
- further kernel tuneup
- hopefully increased FS robustness
- misc changes for DVB
- kernel-dvi
- kodi fixes
- sys fixes
- e2 fixes
- kernel-dvi
- kodi fixes
- sys fixes
- e2 fixes
- matchboxx
EDIT 11.11.15
- cumulative updates, including today's E2 fixes
- DVI users should use the 21.10 kernel, actually less chatty than default
- feeds updated
- reflash needed, but it won't be needed ad futuro, except in new kernel instance
- wetek antena probably still off, could be resolved via online update
- feeds updated
- matchboxx
EDIT 16.11.15
- feeds updated
- E2 code fixes
ke stazeni
- feeds updated
- E2 code fixes
ke stazeni
- matchboxx
EDIT 17.11.15
- feeds updated
- removed offending stuff for Kodi
ke stazeni
- feeds updated
ke stazeni
- matchboxx
EDIT 22.11.15
- feeds updated
EDIT 22.11.15
- feeds updated
- E2 updated to PB mainstream
- dozens of E2 fixes, probable problems likely to occur until all polished out
- samba server fix
- on line update should be ok
EDIT 22.11.15
- Videomode Selection fix
- feeds updated
EDIT 22.11.15
- feeds updated
- samba server fix
EDIT 22.11.15
- matchboxx
EDIT 26.11.15
- feeds updated
- E2 code fixes
ke stazeni : http://anonym.to/?http://pb-download.co ... sdcard.zip
- feeds updated
- E2 code fixes
- matchboxx
EDIT 8.12.15
EXPERIMENTAL-PBNIGMA-VX-5.1-20151208_sdcard
ke stazeni http://anonym.to/?http://pb-download.co ... ardEXP.zip
- experimental release. Do not use without spare micro SD card or spare time. Or curiosity:)
- modified uSD creation
- restoration of Kodi settings from E2 backup should work from 1st boot.
- new kernel 3.10.93, ts changes
- E2 code major revision regarding AML DVB-* playback
- known issues: audio out of sync
- matchboxx
image Bleeding edge to radeji nezkousejte , nebo na vlastni zopovednost :-(
posleni funkcni image je ze 17.11.2015
