ViX4E2PROJECT verze 2.2 Build
Firmware pro přijímače Amiko.
Fishburn Czech Republic
Poděkoval: 32 krát
Poděkováno: 9 krát
Příspěvekod Fishburn » 28 úno 2017, 15:46
CHANGE ENIGMA2 TO USE EXTEPLAYER3 AS DEFAULT PLAYBACK SYSTEM
This represents quite a significant change from previous releases and provides for much better IPTV (streaming) support in many instances. This change is implemented by having both ServiceApp and exteplayer3 installed and activated by default. Many thanks to mx3L and samssamsam for contributing this to the E2 community. This will now become the ViX4 default - You can however switch back to the older default player should you wish at Menu > Setup > System > ServiceApp Settings.
UPDATE ViX4E2PROJECT PANEL FOR NEW IMAGE BACKUP, FLASH AND DOWNLOAD OPTIONS
This sees a significant change in that the 'Image Manager' option originally ported over from OpenViX has been removed and replaced with significantly modified versions from OE-Alliance SoftwareManager - So we now have options 'Image Flasher', Image Backup' and 'Image Downloader' and Backup Manager has now be renamed to 'Settings Manager'. These have been fully skinned for ViX4E2PROJECT with the default Blue-HD skin but even more importantly offer FULL image backup and restore options including 'arm chair' flashing for ALL supported models, yes this even includes the Mut@nt HD51 and we have this now creating a complete image backup in a .zip file that time and date stamped and can be fully used for either USB or arm chair flashing! All these utilities have been heavily modified for specific use with ViX4E2PROJECT and fully tested as working before release! You can find more information on what does what by heading to the screens themselves and reading on-screen for a better idea. Thanks for OE-Alliance members (mainly OpenATV guys) and a massive thanks to Lavatronics John for his help with this in getting it to do what we wanted to make this customised for ViX4E2PROJECT - It took some effort!
RENAME TIMER / RECORDING MENU OPTIONS AS PER REQUEST
While the intention has never been to make ViX4E2PROJECT a copy of official provider receivers (and I can understand why you might think otherwise sometimes!) one of the real aims is to make this familiar to users, especially for those that don't know/care what Enigma2 is - It's not aimed at the satellite enthusiast but rather those users that just want something that works and they are reasonably familiar with. For this reason as per a suggestion received I have renamed some parts of the menu so now 'Timers' becomes 'Planner', 'Add Timer' becomes Record Once' and Add AutoTimer becomes 'Record Series'. This is both in the main menu and from EPG view. The actual screens/functions of timer and autotimer remain the same as previously.
E2 OpenRsi 3.0 v.21.7.2013 CCcam 2.2.1
Amiko Alien Min OpenATV 6.2,OSC r11438 sh4
Formuler F4 Turbo Combo hevc
OpenATV 6.2 ICE irdeto 0624 Oscam svn11401+NewCamd to CCcam 2.2.1 Aktive
efendy55 Slovakia
Poděkoval: 13 krát
Poděkováno: 62 krát
Re: ViX4E2PROJECT verze 2.2 Build
Příspěvekod efendy55 » 28 úno 2017, 16:34
to je pre aké amiko ???
Všetko4K,Linux E2
Poděkoval: 32 krát
Poděkováno: 9 krát
Příspěvekod Fishburn » 28 úno 2017, 17:10
Amiko Mini
Amiko SHD 9800
Amiko 2+
a další.... :89:
Zpět na „Firmware Amiko“
