AZBOX HD INCUBUS
- ShaMan
AZBOX HD INCUBUS
Incubus How-to AzBox HD
1. Unpack Incubus Cam AzBox v055.rar and copy 3 files in it (incubusCamd.conf,
incubusCamd.prio and incubusCamd.sigma ) to /EMU/OpenXCAS/incubus
2. Make file called openxcas.conf inside incubus directory
[module]
name = incubusCamddaemon = incubusCamd.sigma
version = 0.55
and
in /EMU/OpenXCAS edit the file module.seq
and enter the registered incubus cam in first line before MultiCAS
[module]
version = 0.55
and
Re: AZBOX HD INCUBUS
a nemelo by to byt nahodou taktoShaMan píše:Incubus How-to AzBox HD
[module]
version = 0.55
and
[module]
name = incubusCamd
version = 0.55
a vsechny soubory musi mit atributy 755
Konfiguraky urcite nepotrebuju 755 . program ano .
Ano, má to být:
[module]
name = incubusCamd
version = 0.55
a pouze ten daemon musí být executable - 755. Ale stejně se mi incubus automaticky nespouští, možná to je tím, že skript start.sh je prázdný? Asi jo, tak to tam dopíšu ručně. Akorát, že MultiCAS se automaticky spouští i když v tom start.sh taky není.
[module]
name = incubusCamd
version = 0.55
ten start.sh som tam videl, ale nic som v nom nemenil. Asi bude rovnako ako stop.sh urceny pre users . vsetky programy startuju prikazom scriptu, len tie co boli bundle maju script skryty- takze ho nevidime.
Instalacia OpenXCAS cez telnet.
1 - extract the files.rar
2 - Put them in /EMU through ftp
3 - Set 755 for :
A - emu_module ( it's in Multicas )
B - openxcas.conf ( it's in openxcas )
C - sample_module ( it's in Samples )
D - addons.conf ( it's in EMU )
Now reboot, your cardreader is working now if all rights are set correct, just select menu ( not home! ) then on the bootom cas module and then cas settings and select encryption.
Now for Incubus:
Add incubusCamd.sigma, incubusCamd.conf and incubusCamd.prio to:
/EMU/openxcas
set 755 for all 3 files
Edit openxcas.conf so it show this :
Quote:
[modules]
count = 1
active_auto = false
active_1 = incubusCamd
[module_1]
name = incubusCamd
path = EMU/openxcas
version = 1.00
Then add serverline (twice) to incubusCamd.conf
Reboot box then log in with telnet and do the following commands:
cd /EMU/openxcas (enter)
./incubusCamd.sigma (enter)
For start-up on reboot I did the following
( WARNING!! DO AT YOUR OWN RISK!!!!!!)
S.sh contains the start-up commands so we need to add the command there, but............... it's read-only so we need to make it RW:
1 - Login with telnet.
2 - give command:
Quote:
mount -o remount,rw -t ext3 /dev/hda1 /MMP
3 - Now you can edit with you're favourite editor the S.sh file, add the follwing on the bottom of the file
Quote:
sleep 10
cd /EMU/openxcas
./incubusCamd.sigma
Now reboot and Incubus will start @boot.
3 - Set 755 for :
Now for Incubus:
/EMU/openxcas
Quote:
[modules]
count = 1
active_auto = false
[module_1]
name = incubusCamd
path = EMU/openxcas
version = 1.00
2 - give command:
Quote:
sleep 10
cd /EMU/openxcas
./incubusCamd.sigma
Lepší řešení MultiCAS a incubusCamd, automatický start po zapnutí boxu a funguje i restart EMU v menu Plugins (žlutým tlačítkem).
Je to vlastní výroba, ale funguje snad dobře
Doplnit tyto dva soubory do /EMU/OpenXCAS/incubusCamd
openxcas.conf:
[module]
name = incubusCamd
daemon = incubusCamd.sh
version = 0.55
incubusCamd.sh:
#!/bin/sh
killall -9 incubusCamd;
cd /EMU/OpenXCAS/incubusCamd;
./incubusCamd;
Pozn. Přejmenoval jsem si incubusCamd.sigma na incubusCamd protože se mi to nechtělo pořád vypisovat, tak pokud tam necháte původní jméno, tak druhý soubor bude:
incubusCamd.sh:
#!/bin/sh
killall -9 incubusCamd.sigma;
./incubusCamd.sigma;
Případně stačí rozbalit přibalený archív do /EMU/OpenXCAS a je to .... V případě ZIP přílohy je nutné ještě ručně nastavit atributy spustitelných souborů na 755. Jedná se o soubory - incubusCamd (nebo incubusCamd.sigma), incubusCamd.sh a emu_module
openxcas.conf:
[module]
name = incubusCamd
version = 0.55
incubusCamd.sh:
#!/bin/sh
./incubusCamd;
incubusCamd.sh:
#!/bin/sh
ja len doplnim, ze linux je case sensitive - cise je citlivy na male a velke pismena, takze ak niekto bude chciet instalovat kopirovanim - bude potrebne premenovat rozbaleny adresar na OpenXCAS . V takom pripade nieje potrebne mat prislusny plugin vopred predinstalovany. Atributy u programov treba nastavit na 755 .
Jo - a funguje. :)
Jo - a funguje. :)
- Quido56
Dobra prace Tome,. funguje to, ale jak se ti zobrazuje ten restart pod zlutym tlacitkem, me tedy nijak.Dreamer píše:Lepší řešení MultiCAS a incubusCamd, automatický start po zapnutí boxu a funguje i restart EMU v menu Plugins (žlutým tlačítkem).
openxcas.conf:
[module]
name = incubusCamd
version = 0.55
incubusCamd.sh:
#!/bin/sh
./incubusCamd;
incubusCamd.sh:
#!/bin/sh
@QUIDO56: Díky Zatím nevím, jak poslat message na obrazovku. Ale budu bádat dál, taky mě vadí, že při restartu emu o tom není nikde žádná hláška. No a vůbec by pluginy měly spouštět jedním tlačítkem přímo v TV, tak jako je v Gemni "modré" tlačítko. Ale do toho už vůbec není vidět .... bohužel Enigma to není, ale snad to nějak půjde.
IncubusCamd - auto instalacia
Prilozeny subor sluzi na "automaticku" instalaciu incubusCamd z USB kluca. Po nainstalovani uz staci konfigurovat server a klient.
Inštalácia incubusCamd-pomocou USB
1. Skopíruj všetky súbory z archívu na USB disk. (po rozbaleni, vzniknú tak dva súbory- incubusCamd.plugin a plugins.lst)
2. Pripoj USB disk do prijímača.
3. Choď do menu Plugins a stlač červené tlačidlo pre pridanie plug.
4. Vyber "incubusCamd" a stlač tlačidlo OK.
Po stiahnutí firmware mi nefunguje spustenie emu pomocou žltého tlačítka,kde robím chybu...??? dík.
skontroluj atribut incubuscamdu -mal by byt 755 . Inak - o tom,ze je vobec spusteny sa dozvies len z vypisu aktivnych procesov -aktivacia pomocou zlteho tlacidla nieje na obrazovke nijak indikovana.
pripoj sa telnetom k boxu a napis ps . zobrazi sa ti vypis spustenych procesov. Ak ho najdes (spusta sa vo viacerych vlaknach) , tak by mal fungovat.
může mi někdo poradit co to je ten INCUBUS a k čemu je dobrý?? Mám přímač nově a moc tomu nerozumím. Díky
incubus sluzi na share - teda umoznuje zdielat kartu v citacke ,alebo sa pripojit na iny server s kartou. Mne sa podarilo len proti CCcamu spravit zdielanie . Na newcs v druhom boxe sa mi ho nepodarilo pripojit. Ak chces len citacku a sw emulaciu - nainstaluj MultiCAS.
