X-STREAMITY
Download Software pro přijímače s E2
Warder Slovakia
Dostal poděkování: 95 poděkování
X-STREAMITY
Příspěvek od Warder »
X-STREAMITY 01.03.2020
Multi Xtreams (IPTV) Playlist Player
- Fixed hbbtv crash
- Added Jedi Playlist if exists
- Changed infobar icon size
- Infobar now auto hides on zapping, only stays if you press OK
- Fixed "none type" crashes for slow and large lists.
- Made the previously selected channel selection a little less jumpy.
- Stopped badly playing streams going back to category list. Need to manually exit if bad stream.
Nosce te ipsum.
Warder Slovakia
Re: X-STREAMITY
X-STREAMITY 03.03.2020
-Removed the top category list, replaced with mini TV.
-Playing live streams - ok to preview, ok twice to play.
-Vod Streams no preview, just play.
-Vod Infobar now starting to take shape.
-Plugin will now tell you if your playlist is not compatible.
-Moving between the lists of categories should all now be alot smoother
Nosce te ipsum.
Warder Slovakia
Re: X-STREAMITY
X-STREAMITY 08.03.2020
- New play state icons now in infobar.
- New Audio stream availablity icon
- New Subtitles available icon
- Changed the way the infobar now works. Now works how you setup your general info bar.
- Added in general settings on main page (Menu Button)
- General bug fixes as mentioned in previous posts.
Nosce te ipsum.
Warder Slovakia
Re: X-STREAMITY
X-STREAMITY 09.03.2020 V.1.0031
- nejake dobne opravy.
Autor sa nam vyhraza ze toto je posledna BETA verzia tak uvidime kedy sa ukaze ta FINALNA . :D
Nosce te ipsum.
Warder Slovakia
Re: X-STREAMITY
X-STREAMITY 12.03.2020 V.1.0034
- fixed gzip errors
Nosce te ipsum.
Warder Slovakia
Re: X-STREAMITY
X-Streamity - Official Release.
V 1.10
- Fixed invalid HD skin references
- Updated Italian and Albanian Language files
Nosce te ipsum.
Warder Slovakia
Re: X-STREAMITY
V 1.14
-Fixed pvrstate crash
-Added in server timeout in main settings (worst one I am testing is 21 seconds to download a simple file -shocking servers)
-Removed the deletion of your json settings file on update
-Fixed max connection = 0 being classed as max active users.
-Fixed Live TV stopping on preview
Nosce te ipsum.
Warder Slovakia
Re: X-STREAMITY
V 1.15
Whats new:
-Catchup - finally got catchup working.
-Catchup menu option can be turned off in settings if you don't have catchup.
-Some providers don't have catchup. Screen will still show but list will be blank
-Some providers seem to have catchup, all the channels are there, but nothing will play. Black screen. This is a provider error, not the plugin.
-Fonts - I have reduced the size of the fonts from 6mb down to 0.5mb. Win win.
-Skin - I have moved all the common elements into one folder rather than duplicating them all in the various skins. Win Win.
-Added in stop button for exitting the player.
-Background, splash screen and vodcover now have 1 pixel transparent pixel bottom right. Hopeful fix a VTI bug. Seagen... I am still not putting in larger 32bit images.
-Re-coded some of the lists so everything should play a little bit nicer.
-Amended the stop player on back. Now shows current tv and not black screen. (if option set in settings)
-Correct unlimited max connections showing as yellow and not green. (again)
-Removed the nag screen if more active users than allowed.
Nosce te ipsum.
Warder Slovakia
Re: X-STREAMITY
V 1.17
-Fixed a bug relating to serviceapp streamtype selection
Nosce te ipsum.
Warder Slovakia
Re: X-STREAMITY
Update 07.04.2020
V.1.21
The skin background code was slowing the plugin down. Fixed it and is now as fast as it used to be.
Catchup default stream type changed back to 4097
Fixed overlapping of labels on back button
Fixed active/max connections amber LED.
Added in Recording option on Live player.
Press Record Button on playing stream. Enter dates and times.
Can have multiple downloads
But be warned no recording conflict test.
Changed the default download location to that of your boxes default movie folder. So no longer has to be primarily set.
Added in front display info for boxes that have it - Not all info is available though like event info and progress
Nosce te ipsum.
Warder Slovakia
Re: X-STREAMITY
Update 16.04.2020 V.1.27
● fixed blank "Add Server" screen
● Added latest italian language file.
Nosce te ipsum.
Warder Slovakia
Re: X-STREAMITY
Update 19.04.2020 V.1.28
-All new skin files. Enabling the skinning of all elements now via TemplatedMultiContent elements
Warning. Old user skins or modded version of my skins will no longer work. You will have to see what I have changed and amend yours accordingly
-Added in a catchup start and end margin into main settings
-Added in full epg listings (up to 50 listings) available via long pressing EPG/Guide button on a channel with EPG. To exit long press EPG or Red button
-Removed all unnecessary imports in every file to help reduce memory load
-Tweaked catchup. This should hopefully play a little better. Also reversed the lists so latest are at the top and not the bottom
-General tweaks in pretty much all files
Nosce te ipsum.
Warder Slovakia
Re: X-STREAMITY
Update 15.05.2020 V.1.36
Nosce te ipsum.
Warder Slovakia
Re: X-STREAMITY
X-Streamity - Official Release. V 2.26
Nosce te ipsum.
Warder Slovakia
Re: X-STREAMITY
X-Streamity - Official Release. V 2.27 - 09/08/2020
- Lets try a totally different approach.
- Dependencies are now (or should be) installed on first run of the plugin if needed, based on whether python 2.7 or python 3.
- Expect a minor delay on first run if missing something.
Nosce te ipsum.
Zpět na „Download - software pro přijímače s E2“
