Dreambox - Experimental OE2.6
Odkaz na Images a diskuze k Images Dreambox ONE Ultra HD
Warder Slovakia
Dostal poděkování: 82 poděkování
Příspěvek od Warder »
Dreambox - Experimental 31.8
Stahovat image mozete z https://dreamboxupdate.com/opendreambox ... /dreamone/
Nosce te ipsum.
Warder Slovakia
Re: Dreambox - Experimental
Dreambox - Experimental 19.11.
Novinky a zmeny:
enigma2: 4.4.2r0
- CEC: fixed some (popular) TV's only turning off every second time
- fixed some autores issues
- ScanSetup: fixed recently introduced crash on DVB-C transponder search
- fixed broken UP navigation in Grid-Lists
- fixed some potential crashes
dreambox-dvb-modules: 20191119r0
- added possibilty to configure the sync mode via /proc/stb/video/sync_mode (slow = slow motion sync, black = black screen until synced, hold = hold first frame until synced)
Developers:
- skins/ConfigList:
- seperation has now been properly renamed to "separation", seperation still works (for backwards compatibility
- added "listFontKeyboard" so the keyboard can have it's own font
- added eLongreader and eUnsignedLongLongreader
- eServiceStream: improved compatibility with dash/hls streams, implement some missing events (evEOF, evVideoTypeReady, sVideoType, sAudioType
Date: 2019-11-19 22:13:35.296381
Distro: opendreambox 2.6.0
Drivers: 4.9-20191119r0-r0.0
Enigma2: 4.4.2r0-r0.2
Kernel: kernel-image-4.9, kernel-image-image.gz, kernel-image-image.gz-4.9, lib32-kernel-image-image.gz 1:4.9.113-641430-ga083aa3-r0.3
Nosce te ipsum.
Warder Slovakia
Re: Dreambox - Experimental OE2.6
Dreambox - Experimental 22.11.
Takze mame tu dalsi update Enigmy na verziu 4.4.2r1
A co je nove ?
- fixed possible segfault on startup
- added new font for virtual keyboard
- added missing imports to Components.TemplatedMultiContentComponent (thx to dre)
Date: 2019-11-22 23:24:32.770188
Enigma2: 4.4.2r1-r0.0
Nosce te ipsum.
Warder Slovakia
Dreambox - Experimental 15.02.
Po malych problemoch bolo vydane nove distro.
Date: 2020-02-15 17:56:58.068101
Drivers: 4.9-20200213r0-r0.0
Enigma2: 4.4.2r4-r0.0
Kernel: kernel-image-4.9, kernel-image-image.gz, kernel-image-image.gz-4.9, lib32-kernel-image-image.gz 1:4.9.113-642242-g3a99f3f-r0.1
enigma2: 4.4.2r4
- fixed crashes caused by broken media database after update from 4.4.2r2 to 4.4.2r3
update from 4.4.2r1 to 4.4.2r3 was no problem...
enigma2: 4.4.2r3
- fixed media db crashes
enigma2: 4.4.2r2
- added trickmodes (ffw/rwd/slowmo) for amlogic platforms (kernel/driver update required)
- improved trickmodes in timeshift mode
- fixed potential sync issues (broken PTS extraction when DTS & PTS are available)
- fixed exif related crashes
- fixed issues when skipping through http streams (servicemp3)
- eServiceStream improvements
- webm support
- subtitle support
- cookie support
- improve hls/dash compatibility
- updated translations
- removed pixmaps from skin_default.xml to avoid having them preset "everywhere"
Link na stiahnutie je v prvom prispevku.
Nosce te ipsum.
Warder Slovakia
Dreambox - Experimental 19.02.
Date: 2020-02-19 00:13:38.505993
Drivers: 4.9-20200218r0-r0.0
Enigma2: 4.4.2r5-r0.0
Kernel: kernel-image-4.9, kernel-image-image.gz, kernel-image-image.gz-4.9, lib32-kernel-image-image.gz 1:4.9.113-642474-g6ca555d-r0.1
Enigma2 4.4.2r5
- fallback to white foreground color for text subtitles when missing in skin
- some HLS/Dash improvements
- don't write to mediadb when disabled in menu
Drivers 20200218
- improved support for TS/M2TS files
- fixed pixelation for some h264 movies (broken since 20200213 drivers)
- fixed deadlock on playback ts files / movies with errors (broken since 20200213 drivers)
Nosce te ipsum.
Warder Slovakia
Dreambox - Experimental 21.02.
A mame tu dalsiu aktualizaciu.
Date: 2020-02-21 10:44:08.994352
Drivers: 4.9-20200218r0-r0.1
Enigma2: 4.4.2r5-r0.1
Kernel: kernel-image-4.9, kernel-image-image.gz, kernel-image-image.gz-4.9, lib32-kernel-image-image.gz 1:4.9.113-642476-g23b3890-r0.1
- enigma2: Move new deps to inc file
- linux-meson64: reverted change which can cause ethernet problems
Nosce te ipsum.
Warder Slovakia
Dreambox - Experimental 03.04.
Date: 2020-04-03 08:16:55.638095
Drivers: 4.9-20200402r0-r0.0
Enigma2: 4.4.2r6-r0.0
4.4.2r6
- fixed memory leak for hls streams
- added support for ID3-ADTS-AAC audio live streams (used in ZDF live streams)
- eFileMonitor: fixed hangups on destroy
- eFileMonitor: handle multiple watches on single dir/file
- eFileMonitor: disabled log spam by default and add a usage setup switch to enable it again
- TimerSanityCheck: fixed possible bug seen in crashlog (TypeError: range() integer end argument expected, got float.
- fixed possible epgcache deadlock
- fixed alpha channel for svg pictures
- optimized SatelliteEquipmentControl lock handling to fix sometimes lost unlocks which caused endless sec lock/unlock loops
- Default/Default-FHD skins: update
- linux-meson64: update to newer amlogic release
dreambox-dvb-modules: update dreamone hardware drivers
- fixed possible crash one clear buffer ioctl
- fixed possible demux problems
- changes for latest kernel
- improved PTS discontinuity detection algo for low framerate content
Nosce te ipsum.
Warder Slovakia
Dreambox - Experimental 16.05.
Date: 2020-05-16 17:50:17.846593
Drivers: 4.9-20200402r0-r0.1
Enigma2: 4.5.0r2-r0.0
Kernel: kernel-image-4.9, kernel-image-image.gz, kernel-image-image.gz-4.9, lib32-kernel-image-image.gz 1:4.9.113-643119-gf4d736f-r0.1
4.5.0r2
- faster processing for remote control passthrough via CEC
- faster audio stop processing (little bit faster service changes)
- lot changes for python3 compatibility
- fixed creation of SC/AP files for recordings of scrambled services
- let eMediaScanner do background metadata updates for recordings
- better mediadatabase integration to prevent harddisc wakeup on show list of recordings
- ServiceStream:
- implement adaptive streaming, starting with the worst quality for DASH content
- HBBTV:
- fixed skipping forward/backward for DASH/HLS content (broken since migration to ServiceStream)
- added support for replay function for "Das Erste" services
(accessible via blue button ... hbbtv services ... replay)
- skin_default_1080: use darker grey for "foregroundColorServiceNotAvail" in service list (now equals default skin)
Nosce te ipsum.
Warder Slovakia
Dreambox - Experimental 28.05.
Date: 2020-05-28 12:51:59.882636
Drivers: 4.9-20200528r0-r0.0
Enigma2: 4.5.0r3-r0.0
Kernel: kernel-image-4.9, kernel-image-image.gz, kernel-image-image.gz-4.9, lib32-kernel-image-image.gz 1:4.9.113-643120-gc5937e8-r0.1
4.5.0r3
- unpause services on service stop to prevent deadlocks
- fixed PluginDescriptor compatiblity (broken since 4.5.0r2)
- fixed InputDevices configuration (broken since 4.5.0r2)
- StreamService
- DASH: start streams with medium quality instead with worst quality
- DASH: fix playback of some non-live streams
- DASH: fix seeking in streams with a PresentationTimeOffset
- DASH: fix backwards seeking
- HLS: fix playback of streams with an undeterminable stream type (assume TS)
- eServiceStream: remove illegal characters from stream urls (line feed / carriage return)
- linux-meson64: fixed sometimes long time black picture after changing channels
- fixed fp_version read after failed fp update
Nosce te ipsum.
Zpět na „Odkaz na Images a diskuze k Images Dreambox ONE Ultra HD“
