Skin HD Glass 16
- schmegea
Re: Skin HD Glass 16
HD Glass16 ver. 3.76
- added support for DE 2.1 (older removed)
- updated encoding.conf
- changed default value of fade in setup to disable (řeší zelenou smrt u azboxu po instalaci skinu)
- schmegea
HD Glass16 ver. 3.85
- added new option in setup: setup with PIG (yes, no)
- help updated (do it via download menu)
- added title if messagebox is type YESNO (setup messages)
- changed restart gui procedure - fix CAM to stay alive on some HW
- added screen 16,17
- added autoreconfiguration windowstyle for screens 16.17
- previews updated for screens 16,17 (do it via download menu)
- increased speed of skin - switch beetween channels menu etc.
- autoblock bitrate if screens 16,17 are activated
- autoblock fade if alpha is not present on HW
Update is available online via setup
http://www.forum.satdigitalne.cz/viewto ... 619#p71533
- schmegea
HD Glass16 ver. 3.89
- added detection of DGCrypt (after restore icons type will be set to default type 1, so after update and autorestore you must download icons and previews and then set/select your prefered icons type)
- added download picon white in download menu
- added new style 3
- added screen 18, 19,20
- fix channel selection type 2,4
- added option set style to screen and edit color of title in style
- icons and previews in download are updated
http://www.forum.satdigitalne.cz/viewto ... 619#p72280
- added new style 3
- schmegea
HD Glass16 ver. 3.91
- fix support for plugin EMC 3.0.0
- fix detection of Nemesis image 101r1( do not use this and next versions in older version of Nemesis)
- fix icon type 1
- icons in download updated
http://www.forum.satdigitalne.cz/viewto ... 619#p72368
- fix icon type 1
- vikino
HD Glass16 ver. 3.96
- small correction in main screen of EMC plugin (3.0.0)
- added enhanced(detailed) support for gbox ecm info
- changed default menu type to list
- changed default user info to event - extended description
- added new user info type: event now and next
- help updated in download
- icon rec moved to hdd state icon(or tuner) position - all screens
- vikino
HD Glass16 ver. 4.01
- added new dynamic icon - subt (subtitle)
- added support of HBBtv detection( new hbb dyn. icon)
- removed crypt icon
- added screen 21
- added style 4
- added icons type 7,8,9
- icons sets updated in download (icons type 7,8,9, screen21 preview, icons type 7,8,9 preview)
how to activate all new options:
1. update the skin
2. restart GUI
3. after autorestore cfg of the skin and autorestart gui, go to the setup of skin
4. in the setup, press button 2 - download menu
5. download icons and previews
6. select your prefered icon type
thx shamann
- added screen 21
- added style 4
1. update the skin
2. restart GUI
thx shamann
- vikino
screen21 v HD Glass 4.01
- okol
HD Glass16 ver. 4.03
- added sreen 22
- added support for BH 1.6.7 (VU+), older removed
- added new oled type: g16 top:channel name, bottom:snr/agc
- added bottom window style - caid ecm pids
- previews updated in download
- added sreen 22
HD Glass16 ver. 4.06
dnes se objevila nova verze skinu
Stahnul jsem primo pres skin
LG 42LV507S, Azbox Elite HD E2 RTi 1.7.0 usb Patriot 16Gb Skylink/Cslink CCcam 2.3.0
- schmegea
HD GLASS 4.07
- fix listing of the history (reaction)
- added colored "ver. X.XX" in the "History"
- schmegea
HD Glass16 ver. 4.08
- providers picon updated in download black and white (thx ftryskac)
- added "rec" icon into VU+ Ultimo - OLED type
- fix GraphMultiEPG - latest Nemesis image
- vikino
HD Glass16 ver. 4.10
- added picon black to download menu (CZ/SK channels only)
- fix refresh of the piconProv - DVB-T and DVB-C tuner type
- JohnCenaWWE
Hd Glass 16 ver. 4.13
- added new option in the setup: Enable default EMC (from plugin)
- added autodetection HW (Brand, model - displayed in the setup) and set the
picture of HW into menu, where is used
- added date and time - both the type "with PIG" of channel selection screen
- added support for BH 1.7.0 (1.6.7 removed, 1.6.6 supported-autodetect)
- schmegea
HD Glass16 ver. 4.14
- added new channel selection type: "G16(+next, date, colored list)"
- schmegea
HD Glass16 ver. 4.16
- added new channel selection type: "Glass16(+next, date)"
- added screen 23, added style 6
