AZ BOX HD sw version 0.9.1086
ShaMan
Příspěvek od ShaMan »
Release Notes - version 0.9.1086
1. Becareful! All channels will be removed after updating
A. Channel structure is changed
2. New OpenXCAS API is available
A. SmartCard Interface is added (reference HXOpenXCAS_Sample)
B. Managed by GUI(Install/Uninstall, Enable/Disable, Set priority)
- for changing server address, edit /EMU/OpenXCAS/addon.conf
CAMD_MY_SERVER for Cam1.tgz
CAMD_SERVER_1 for Cam2.tgz
CAMD_SERVER_2 for Cam3.tgz
CAMD_SERVER_3 for Cam4.tgz
- for example,
If you set CAMD_MY_SERVER as "http://azupd.com", Samples will be installed when you select CAMD_MY_SERVER from GUI
If you set CAMD_SERVER_1 as "http://azupd.com", MultiCas will be installed when you select CAMD_SERVER_1 from GUI
If you set CAMD_SERVER_2 as "http://azupd.com", gCam will be installed when you select CAMD_SERVER_2 from GUI
C. Debug message on/off
D. Time debug message is added
E. Improved PMT, ECM return time
3. Fix bug about AC3 audio
A. Please check ac3 audio output after 1 or 2 hours
B. ProLogic is not supported yet
4. Movie Player
A. Fix bug about SRT subtitle(disapper after 1 hours)
B. Test results of some contents
a. File name; Matrix.Reloaded.Trailer-640x346-XviD-1.0beta2-HE_AAC_subtitled.mkv
- Video is somtimes broken( Popcorn has same problem)
b. File name; Matrix.Reloaded.Trailer-RV9-Karl640x432_HE_AAC_subtitled_chapters.mkv
- Not supported(Poscorn has same problem)
c. File name; big_buck_bunny_1080p_h264.mov
- Good
d. File name; big_buck_bunny_1080p_stereo.avi
- Not supported(Popcorn can decode audio only)
e. File name; big_buck_bunny_1080p_surround.avi
- Video is sometimes broken(Popcorn doesn't have any problem. I am debugging on it)
f. File name: big_buck_bunny_1080p_stereo.ogg
5. Recording CAS Channel(if EMU can support 2 stream)
6. Timer is added
7. You can use a drop down list for changing video resolution
8. DEL/BACK and CAPS/NUM to history navigation at TV Mode
Zpět na „AzBox HD diskuze“
