Newcs server
romoror
Re: Newcs server
Nevie niekto poradiť čo tu mám zle nechce mi to chodiť ako server je AZboxHD premium
<newcamdserver>
<enabled>yes</enabled>
<name>local</name>
<deskey>01 02 03 04 05 06 07 08 09 10 11 12 13 14</deskey>
<user>
<name>dummy</name>
<password>dummy</password>
<hostname>127.0.0.1</hostname>
<port>12000</port>
</user>
<user>
<name>heslo</name>
<password>heslo</password>
<hostname>192.168.1.189</hostname>
<port>20000</port>
</user>
newcamd.list
CWS = 192.168.1.189 20000 heslo heslo 01 02 03 04 05 06 07 08 09 10 11 12 13 14 wan cardserv
<newcamdserver>
<name>local</name>
<user>
<name>dummy</name>
<port>12000</port>
</user>
<user>
<name>heslo</name>
<port>20000</port>
</user>
newcamd.list
Re: Newcs server
<newcamdserver>
<name>local</name>
<user>
<name>dummy</name>
<port>12000</port>
</user>
<user>
<name>heslo</name>
</user>CWS = ipadresa_azboxu skutocny_port_citacky heslo heslo 01 02 03 04 05 06 07 08 09 10 11 12 13 14 wan cardserv
a hlavne nepridavaj hluposti do nastaveni klienta
romoror
- schmegea
Re: Newcs server
Moje nastavení s kterým funguji
newcs.xml:
<?xml version="1.0"?>
<newCSconfig>
<readers name="Card Readers">
<device>
<name>upper</name>
<type>azbox</type>
<node>/dev/scard</node>
<export>yes</export>
<blocksa>no</blocksa>
<blockua>yes</blockua>
<blockga>yes</blockga>
<newcamd_port>20000</newcamd_port>
<autosid>no</autosid>
<carddetect>yes</carddetect>
<priority>hard</priority>
<PTShandshake>no</PTShandshake>
<mhz>500</mhz>
<boxkey>79FDC0E18D278138</boxkey>
<rsa>9ED52515321F04BCF7772151149D6895154B559A8D825A4E7D711A9FAFD5C66BF64689501B254DF1832F754C21095379CF97B4E5BE6E0F1C9CEBF0A0E91D5ACD</rsa>
</device>
</readers>
<xmlserver>
<enabled>0</enabled>
</xmlserver>
<radegastserver>
</radegastserver>
<cache>
<emm>10</emm>
<ecm>-1</ecm>
</cache>
<debug>
<darint39>sintoi51</darint39>
<level>internal</level>
<type>all</type>
<output>console, tcp</output>
<logfile>/tmp/newcs.txt</logfile>
<console_options></console_options>
<file_options></file_options>
<udp_host>172.16.1.1</udp_host>
<udp_port>9000</udp_port>
<udp_options></udp_options>
<tcp_port>1001</tcp_port>
<tcp_options></tcp_options>
</debug>
<newcamdserver>
<name>local</name>
<user>
<name>dummy</name>
<port>12000</port>
</user>
<user>
<name>test</name>
<password>test</password>
</user>
</newcamd_server>
</newCSconfig>
newcamd.list
CWS = XXX.XXX.XXX.XXX 20000 test test 01 02 03 04 05 06 07 08 09 10 11 12 13 14
newcs.xml:
<newCSconfig>
<device>
<name>upper</name>
<type>azbox</type>
<mhz>500</mhz>
</device>
</readers>
<xmlserver>
</xmlserver>
<radegastserver>
</radegastserver>
<cache>
<emm>10</emm>
<ecm>-1</ecm>
</cache>
<debug>
<type>all</type>
</debug>
<newcamdserver>
<name>local</name>
<user>
<name>dummy</name>
<port>12000</port>
</user>
<user>
<name>test</name>
</user>
</newcamd_server>
</newCSconfig>
newcamd.list
Re: Newcs server
skutocny port citacky je 20000 - v default newcs.xml . Ak si ho umyselne nezmenil . Preto som to dal ako nazov, lebo ani boh nevie,co si tam ozaj pomenil.romoror píše:Skutočný port čitačky je12000?
romoror
Re: Newcs server
Stále sa mi nedarí rozbehať to zdielanie server je azboxHD premium mam v nom newcs a potrebujem aby mi chodila skylink katra v dreamboxe ktorý je tiež doma nadstavenie som spravil podla hore uvedeného príspevku.netreba ešte niečo v azboxe nastaviť?oba boxy mam doma v sieti ide o to aby mi išli obidva na jednu kartu.
- schmegea
Re: Newcs server
Jakou ip má azbox (server) ?192.168.1.189?
a předpokládám, že oba přijímače máš za jedním routerem v domácí síti.
Pokud sdílíš jinam potřebuješ veřejnou IP.
Dreambox musí mít Newcamd 5.25, nebo mgcamd
romoror
Re: Newcs server
IP adresa AZboxu je :192.168.1.189.AZbox a dream su zaroutrom v domacej sieti.V dreamboxe mam mgcamd tam to je určite ok.Skorej niečo s AZboxom ale neviem čo?
- schmegea
Re: Newcs server
zkus těmito soubory zaměnit v newcs (azbox) a mgcamd (dream).
romoror
Re: Newcs server
Ja som s toho jeleň lebo to nejde ani po prekopírovaní tvojich suborov.A v nadstavení priority sttingu nebude problém?
- libco
Re: Newcs server
ak som ta spravne pochopil, v az ti karta ide a v dreame nie. vyskusaj ping z az na dreama, ci mas vobec spojenie. ak mas, pozri ci v dreame nemas newcamd.list a newcamd.cong, ak ano, prednost ma newcamd.list (/var/keys), teda spravny riadok na share musi byt v nom. ak to ani tak nebude fungovat, mas chybu v niektoro configu,tak ich sem pastni (cele subory), niekto ti to urcite upravi.romoror píše:Ja som s toho jeleň lebo to nejde ani po prekopírovaní tvojich suborov.A v nadstavení priority sttingu nebude problém?
ICQ 563 123 279
- schmegea
Re: Newcs server
Zkontroluj ještě IP boxu a jakou verzi máš Newcs?
romoror
- Cvacho
Re: Newcs server
ahojte
snazim sa rozbehat moj AZBox Elite ako klient voci IPBoxu 200S na ktorom bezi newCS server a je v nom zastrcena biela SkyLink karta, na Ipboxe som rozbehal NewCS a vytvoril 3 uzivatelov (frs,dm500,azbox) prvy je aby Ipbox videl na seba do klienta teda AZBoxu som pridal len riadok do suboru NEWCAMD.LIST stylom (CWS = mojaip.no-ip.org 35600 azbox azbox 01 02 03 04 05 06 07 08 09 10 11 12 13 14) nasledne som na routri spravil NAT (port forwarding) na IPadresu IPboxu200S v lokalnej sieti, ked sa prihlasim do web rozhrania NewCS tak vidim mojeho uzivatela AZBOX ktory je pripojeny ale na AZBoxe je stale napisane ZAKODOVANE, zapisy na karte su OK kedze vsetky programy z ponuky na IPBoxe200 slapu, neviem prist nato kde robim chybu, prikladam vsetky subory co mam nakopirovane na SERVER (IPBox200S) aj na KLIENT (AZBox Elite)
IPBox200S - NewCS v1.65
AZBox Elite - MgCamd (zo zalohy USB od Dempsey, v AZBoxe mam aktivovany len emulator Mgcamd)
AZBox Elite (RTi core 1.5.3) @ Samsung LE40B620 , Dreambox 500 , AB IPbox 200S , Multibeam E-85 , 2xLNB GI-202 Twin
Re: Newcs server
Ten portforwarding si robil úplne zbytočne - ak neplánuješ klienta mimo Tvojej lokálnej siete.
Priložil si CWS
zmeň to na
CWS = ip-ipboxu 35600 azbox azbox 01 02 03 04 05 06 07 08 09 10 11 12 13 14 lan newcs
Priložil si CWS
zmeň to na
