Drivers and bootloader
Re: Drivers and bootloader
Bootloader
Place the bootloader on a USB the map looks like
ET9000 model /et9000/cfe.bin
/et9000/imageversion
/et9000/splash.bin
(The ET6000 and ET9200 have at the moment allready fom factory the latest bootloader)
Place the USB-stick into the receiver and reboot the box by the powerswitch on the backpanel.
To activate bootloader uploading you must press on the frontpanel of the ET9000 the OK button and on the ET5000 the arrowup button. Just wait till the box has loaded the bootloader and is restart.
After it you can load the image for the ET9000 models with directory /et9x00/.
/et9000/splash.bin
New Drivers 2011-09-30
Changelog:
-lnb disable (with DvbOptions Plugin)
-fancontrol proc entries for et9x00
-pcm delay adjustable A/V Settings
sposob instalacie:
1. rozbalit prilohu IPK.
2. zkopirovat balicek IPK do TMP a cez telnet zadat:
opkg install /tmp/et9000-dvb-modules_2.6.31-3.2+20110930-r4.1_et9000.ipk
3. po instalacii restart boxu
Changelog:
sposob instalacie:
Support for LINUX3
FIRST RELEASE OF LINUX3 DRIVERS
driver 3.0.3
(Needs linux3 firmwate and et9x00 bootloader)
driver 3.0.3
Splash.bin s Clarke-Tech Logo - Linux 3.0.3
-zmena uvodneho loga BL. Pred nainstalovanim BL, si zamente subor splash.bin v adresari bootloadera et9x00.
-ak uz mate instalovany BL et9x00, preinstalovanie s novym splash logom potvrdte na prednom panely sipkou dole.
New Drivers 2011.10.29
Changelog:
-fixed vtuner non-auto bandwidth for DVB-T
-full hd framebuffer with bmem>=210M (fullhd skin support)
only for Linux3.0.3 based Images.
extract zip
copy to /lib/modules/3.0.3/extra/
reboot
Changelog:
extract zip
reboot
new driver 3.1.0 linux ET9000, 9200 drivers 2011-11-05
::: Drivers Update ::: - 12.12.2011
Changelog:
-DTS downmix support
-fix AC3+/DDP passthrough support
-fix separate 50hz/60hz videomodes, autoselect based on media format
-fix keeping correct 3dmode after videmode switch
-fix keeping correct PiP position after videomode switch
-scaler sharpness: split into pep_scaler_sharpness, pep_hscaler_sharpness, pep_deinterlacer_sharpness
-fix aspect ratio detection for certain media formats.
-fix aspect ratio for PiP, PiG
-fastforward/rewind (TS)
-add pep_digital_contour_removal
-fix initial audio playback after startup
EDIT: Do not install on Clarke-Xtrend Support V3 Image!
Changelog:
Drivers Update 20120107
New drivers for ET9x00.
Changelog 2012-01-07:
-fix /proc/stb/lcd/show_symbols ( Special tnx to VIX-Team )
-fix rc type 11
-fix rc type 11
bootloader-20111210-et9x00
Na AAF fore som nahodou objavil novsi bootloader ako ten naposledy zverejneny z offico fora, tak neviem ci mi na offico fore usiel pozornosti... alebo?
Prikladam hned dva kusky, jeden je s bootlogom Xtrend, druhy s bootlogom Clarktech-Xtrend, je na Vas, ktory si vyberiete.
Rozbalit a subor et9x00 nakopirovat na flash usb, vypnut box vzadu vypinacom, zasunut flashku, zapnut box zadnym vypinacom, box sa opyta ci ma flashnut novy image, potvrdte tlacitkom "sipka dole" na prednom paneli, po flashnuti, vypise box, ze bol upgradovany bootloader.
Neue Driver - linux-3.2.2 /20120204/
Changelog:
-added '/proc/stb/video/videomode_preferred'
-switch to linux 3.2.2
Changelog:
Splash.bin do Bootloadera s Xtrend Logom
New Drivers - linux-3.2.2 - 24.03.2012
Changelog:
-DVB-T 5V
-make sci devices single-open
-improved tuner scan
-WMV support
-WMA support
-WAV support (pcm wrapped in PES, to keep sync with video)
-alsa mixer switch to enable/disable decoder audio
-internally control vfd symbols
-allow individual vfd symbol override from userspace
-frontend status: report correct FEC
-startup in 720p mode
Frontpanel:
-Add ET9x00 wakeup button for new remote
- Jednoducho dekomprimovať 4 súbory a potom tu:
/ Lib/modules/3.2.2/extra /
výmena, reštart, hotovo.
- alebo ak sú k dispozícii ako IPK inštalácie.
- alebo ak ste na OpenPLi a aktualizácujte on-line.
Changelog:
-DVB-T 5V
-WMV support
-WMA support
Frontpanel:
New Drivers - Linux Kernel 3.3 - 08.04.2012
New Drivers for Images based on Linux Kernel 3.3
Changelog:
-working for Kernel 3.3
-DVB-T 5V
-WMV support
-WMA support
new Linux Kernel 3.3 is now available for ET-Series by onlineupdate for OpenPli Images.
Changelog: link
- or as complete Image (OpenPLi-2.1-beta-et9x00-20120408_usb) for Usb-Flash.
Changelog:
-DVB-T 5V
-WMV support
-WMA support
Changelog: link
Drivers and Kernel 3.6.0 (17-10-2012)
- v img Open PLi 3.0 staci urobit online aktualizaciu - software update.
- vymazat cez ftp starsi 3.4.3 v lib/modules.... ktory tam aj po update ostane.
New Drivers - Linux Kernel 3.6.0 - 15.12.2012
Changelog:
etxx00: align PiP/PiG video output with osd position adjustments
etxx00: show agc
extract to "/lib/modules/3.6.0/extra/" full reboot.
-alebo aktualizacia PLi img od 18.12.2012
Changelog:
etxx00: show agc
