Stránka 4 z 4
Re: oscam
Napsal: 22 dub 2014, 19:27
od pilgrim
Zdravim, mal by som prosbu: ako je mozne ze oscam napise conected a aj tak nedokaze rozkodovat kanal ?
napise nieco taketo:
2014/04/22 19:22:07 1837 2B6D94C8 c dvbapi: new program number: 02D5 (0624:02D5 unknown)
2014/04/22 19:22:08 1837 2B6D94C8 c dvbapi (0D96&000004/02D5/02F3/0000/80:F970/00-00): rejected group (123 ms) (no matching reader)
2014/04/22 19:22:08 1837 2B6D94C8 c dvbapi: Found 1 IRDETO ECM CHIDs
2014/04/22 19:22:08 1837 2B6D94C8 c dvbapi: try pids again #1
2014/04/22 19:22:08 1837 2B6D94C8 c dvbapi (0624&000000/02D5/02DF/0000/45:6ED4/00-00): rejected group (122 ms) (no matching reader)
take ale na chlp presne nastavenie mam na svojom hyperione 3 a slape to bez problemov.
Re: oscam
Napsal: 24 dub 2014, 15:22
od satlan
Hello All,
I have a Vitamin with 256 NAND where E2 Talisman is installed. The problem is with OSCAM. I use 2 versions - 1st is OSCAM: 1.20-unstable_svn Build: r9564 which works in fact very well, however 2nd Oscam Ymod 18t51 freezes my local card/reader after some time. The card is Conax TNK SmartHD, which stops responding after some time. In both cases configs are pretty much the same
oscam.conf
[global]
logfile = /var/log/logfile
clienttimeout = 10000
fallbacktimeout = 2600
netprio = 1
nice = -1
maxlogsize = 64
waitforcards = 0
preferlocalcards = 1
readerrestartseconds = 1
usrfile = /var/log/oscamuser.log
cwlogdir = /var/log/oscam.cw
failbantime = 1440
failbancount = 5
[cache]
[newcamd]
port = 15000@0B01:000000
keepalive = 1
[cccam]
port = 18000
nodeid = 95919DB610951552
version = 2.0.11
reshare = 1
reshare_mode = 0
ignorereshare = 1
stealth = 1
[dvbapi]
enabled = 1
au = 1
user = local
boxtype = duckbox
[webif]
httpport = 8888
httpuser = ixxxxxxxn
httppwd = sxxxxxxxp
httprefresh = 15
httpallowed = 0.0.0.0-255.255.255.255
httpdyndns = xxxxx.dyndns.org
hideclient_to = 15
oscam.user
[account]
user = local
pwd = local
monlevel = 4
au = 1
group = 1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22
cccmaxhops = 1
cccreshare = 0
[account]
user = sxxxxa
pwd = sxxxxxx3
uniq = 1
monlevel = 4
au = 1
group = 1
cccmaxhops = 2
[account]
user = uxxxxxxa
pwd = uxxxxxxx3
monlevel = 4
au = 1
group = 1
cccmaxhops = 2
[account]
user = sxxxxxr
pwd = sxxxxxx3
uniq = 1
monlevel = 4
au = 1
group = 1,3,4
cccmaxhops = 2
oscam.server
[reader]
label = tnk
protocol = internal
device = /dev/sci0
caid = 0B01
detect = none
mhz = 500
ident = 0B01:000000
group = 1
emmcache = 1,3,2
blockemm-unknown = 1
blockemm-u = 1
blockemm-g = 1
lb_weight = 300
oscam.dvbapi
As I mentioned OSCAM: 1.20-unstable_svn Build: r9564 reads TNK channels all over and with no interruption while all ymod freez local reader after a while.
Can you help?
Re: oscam
Napsal: 25 dub 2014, 07:11
od pilgrim
Tak uz som na to prisiel na co sluzi polozka group.
Re: oscam
Napsal: 27 dub 2014, 09:22
od satlan
Ok, I installed Mgcamd alongside Oscam what resulted in EMU functionality. Works very well.
Re: oscam
Napsal: 10 bře 2015, 19:07
od otto69
Tak už jsem v koncích, prosím o pomoc s tím křápem.
1) oscam mám spouštět přes menu/nastavení/softCam/ci/nastavení softcamu/oscam10202
nebo se to spouští v modré tlačítko a emu manager?
2) mám tam kartu 0D96 ale v oscamu to píše v logu Read ATR fail, attempt 2/5 fs = 4
kde dělám chybu?
Re: oscam
Napsal: 10 bře 2015, 20:39
od jirkav23
Pokud používáš Hyperion 4,5 nor tak tady máš vše.
http://www.....
Re: oscam
Napsal: 11 bře 2015, 12:51
od s@pro
jirkav23 píše:Pokud používáš Hyperion 4,5 nor tak tady máš vše.
http://www.....
Někdo ti to smazal , asi to bude tím že odkaz na cizí linky sem napatří , když tak tady dej soubor apod .
