Stránka 4 z 5
Re: azbox+skylink - niektore zakladne prg su "zakodovane"
Napsal: 12 pro 2009, 19:09
od jj_sk
od vypadku z piatka mi nejde rozchodit HD programy - hlasi, ze nema signal.... a niektore stanice mam aj tak scramblovane - SKY Link a aj DIGI... je jedno ci pouzijem MultiCAS alebo mgcamd + newcs
pouzil som aj zalohu od dempsey
kluce nevyprsali
| 08 | 0F 52 74 | 2009-11-19 | 2010-03-04 | MULTI_1
| 08 | 0F 52 71 | 2009-10-22 | 2010-02-04 | MULTI_
| 08 | 0F 52 48 | 2009-10-22 | 2010-02-04 | XXX _Xtreme
| 08 | 0F 52 87 | 2009-10-03 | 2010-01-16 | HD_PLUS
| 08 | 0F 52 72 | 2009-10-22 | 2010-02-04 | SPI_pack
| 08 | 0F 52 89 | 2009-10-27 | 2010-02-09 | Test01_Skylink
| 08 | 0F 52 86 | 2009-10-03 | 2010-01-16 | HD_Eurosport
| 08 | 0F 52 47 | 2009-10-22 | 2010-02-04 | HBO_
doteraz som pouzival MultiCAS, ale uz je na case prejst na mgcamd + newcs - 2. mesiac sa coskoro konci...
povolil som AU
modifikoval priority
#V: { 02 07 10 }
#X: { 0D 02 } #UPC
#X: { 0D 0F } #gital (cslink) karta
X: { 0D 03 } #Skylink biela karta
a toto je OK??
| Newcamd Port: 20000 | CAID: 0D03 | Reader: 0 (upper)
| ID | Username | Logon Status | Ok ECM | Bad ECM | EMM | Hostname | Client | Spider | AU | SO |
| 02 | dummy | 00d 00h 10m 00s | 62 | 0 | 0 | 127.0.0.1 | Mgcamd | No | On | Off |
| 03 | test1 | Offline | 0 | 0 | 0 | Offline | Offline | No | Off | Off |
| 04 | test2 | Offline | 0 | 0 | 0 | Offline | Offline | No | Off | Off |
| 05 | test3 | Offline | 0 | 0 | 0 | Offline | Offline | No | Off | Off |
| 06 | test4 | Offline | 0 | 0 | 0 | Offline | Offline | No | Off | Off |
| 07 | test5 | Offline | 0 | 0 | 0 | Offline | Offline | No | Off | Off |
| 08 | test6 | Offline | 0 | 0 | 0 | Offline | Offline | No | Off | Off |
| 09 | test7 | Offline | 0 | 0 | 0 | Offline | Offline | No | Off | Off |
| 10 | test8 | Offline | 0 | 0 | 0 | Offline | Offline | No | Off | Off |
| 11 | test9 | Offline | 0 | 0 | 0 | Offline | Offline | No | Off | Off |
| 12 | test10 | Offline | 0 | 0 | 0 | Offline | Offline | No | Off | Off |
Napsal: 12 pro 2009, 19:24
od visper
Vypadá to OK, nech to chvíli běžet, měly by naskakovat EMM, zatím tam máš nulu. Pokud hlásí nemám signál, tak je to asi problém paraboly.
Napsal: 12 pro 2009, 19:44
od jj_sk
v SKYLinku som klikol reautorizacia karty a stale nic, zmena len v 2. riadku
02 | dummy | 00d 01h 08m 03s | 353 | 0 | 0 | 127.0.0.1 | Mgcamd | No | On | Off |
co su to za pocitadla ECM a EMM ???
hlaska no signal - hlasia to len HD kanaly a zvysok ide. v piatok som mal tu hlasku aj pri STV1, ...
a dekodovanie, napr Nova Cinema - scrambovane, ale Nova ide...
u DIGI Spektrum scramblovane, ale ale napr. Discovery ide, nejak tomu nerozumiem
Napsal: 12 pro 2009, 22:20
od dendy77
tak uz mi to fici.. zapisy dorazili.. ale musim povedat ze nie cez mgcamd ale cez multicas (ten z dempseyho balika "zapisy") - nechal som to na nom asi 3 hodky kym som bol na nakupoch a ked som sa vrail uz to ficalo, vsetky zapisy dosli... dokonca kukam ze dosiel zapis pre HBO od 4.2.2010 (podotykam neplatil som to, mal som demo len do 20/12/2009 tusim)
ale ten mgcamd je kazdopadne zhaluzeny slusne, pozeram teraz ze pise vo web interface uptime ze 3633d 14h 40m 56s :-)) a furt pise AU off aj ked v configurakoch je to zapnute .. no zahada.. skusim ten vatikan, mozno z toho vytrieskam peniaze ktore potom poslem azboxteamu aby najali viac developerov na vyvoj FW :-)))
vsetkym DIK za pomoc a rady ...
Napsal: 12 pro 2009, 22:22
od vikino
azboxteam nema s mgcamd nic spolocne.
Napsal: 12 pro 2009, 22:24
od dendy77
hej viem sak ale aj fw by si zasluzil este doladit no nie ? :-)
inak teraz som si vsimol par prispevkov vyssie co pisal jj_sk priority list pre mgcamd :
#V: { 02 07 10 }
#X: { 0D 02 } #UPC
co je to prve?? ja som v priority liste zakomentoval len tie stredne 2 (upc / gital), to vrchne znamena co ? ma to byt tiez zacomentovane ? v ukazkach co som tu ponachadzal to prve (V {02 07 10}) bolo vzdy povolene ...
Napsal: 12 pro 2009, 22:30
od vikino
posledny fw je super. nemam vyhrady. ten priolist to mas z multicasu?
edit: aha z mgcamd, sorry.
Napsal: 12 pro 2009, 23:44
od jj_sk
jj_sk píše:
Uz mi to ide zmenil som modulaciu a opet vratil zmenu na povodnu hodnotu a uz bol signal...
este s Nova Cinema mam problemy - stale je zakodovana - je jedno ci pouzijem MultiCAS alebo mgcamd + newcs, pricom je aktivna
04 | 0F 52 70 | 2009-04-22 | 2010-05-22 | Nova_Cinema
Napsal: 14 pro 2009, 18:36
od bano2
Ahoj vsichni, mam podobny problem jako dendy77. Po prostudovani tohoto tema jsem nainstaloval zalohu pluginu od Demsyho
viewtopic.php?f=159&t=4031&p=31630#p31630, prez multiCAS to z bile SKYLINK karty jede.
Chtel jsem vyzkouset i newcs+mgcamd; deaktivoval jsem multiCAS, aktivoval newcs a mgcamd, opravil priority.list, v newcs.xml a mg_cfg povolil zapisy. Sice to chodi ale dost podivne - chvili dekoduje, pak obraz zamrzne, pak je chvili hlaseni zakodovano, pak se obraz zase rozjede a tak dokola. To cele se opakuje v intervalu cca 2 minuty na vsech kanalech, ktere jsou na karte aktivovane.
Nevite, co tomu chybi???
Napsal: 14 pro 2009, 18:39
od dendy77
mne to nerobi (to co popisujes), ked uz presli zapisy cez multicas tak som to potom prepol na mgcamd+newcs a chodi to naprosto spolahlivo, dokonca programy sa prepinaju rychlejsie ako cez multicas ....
Napsal: 14 pro 2009, 18:42
Poradie addonov zoraď takto:
mgcamd 1.32
newcs 1.20 RC3
#MultiCAS 161C-A07
#CheopsCAS 1.00
choď na mgcamd a stlač žlté tlačítko
Napsal: 14 pro 2009, 20:02
od jj_sk
bano2 píše: Sice to chodi ale dost podivne - chvili dekoduje, pak obraz zamrzne, pak je chvili hlaseni zakodovano, pak se obraz zase rozjede a tak dokola. To cele se opakuje v intervalu cca 2 minuty na vsech kanalech, ktere jsou na karte aktivovane.
mal som rovnaky problem, postacuje reboot AZ a uz bez problemov, az do okamziku, ked sa prepnem do MultiCAS a nasledne sa vratim spet.. je to chyba, ktora mi nevadi, ved to ani zdaleka nerobim kazdy den...
Dempsey - priorita pluginov - ma to zmysel (prehadzovat MultiCAS dole), ak nie je ten plugin aktivny ??
Napsal: 14 pro 2009, 20:14
od Zakoold
Priorita plati len pre spustanie pluginov - to znamena ze sa spustaju v takom poradi, ako su v zozname, od hora dole.
Pre zakomentovane pluginy priorita neplati.
Napriklad ak chcemne aby nam citacku obsluhoval newcs a nie multicas, dame na prve miesto newcs a za nim multicas.
Napsal: 14 pro 2009, 20:25
Ak sa používa MultiCAS tak ano - hore odremovaný MultiCAS a pod ním veštko čo sa nepoužíva zaremované
Ak sa ale používa newcs+mgcamd treba ho dať v poradí
mgcamd
newcs a spúšťať žltým na mgcamde
Napsal: 15 pro 2009, 19:21
od dendy77
pre zaujimavost... prave som dosiel na pricinu tej zahady ze webinterface newcs hlasilo AU "off" ale v xml-ku bolo on ... som sa len chytil za hlavu ked som to zistil.. radsej to sem napisem ak by sa stalo nieco podobne niekomu nech nemusi koli tomu preinstalovavat cely FW ked sa to da fixnut za 10 sekund :)
takze ... mal som v
/EMU/OpenXCAS/ 2 adresare .. jeden "NewCS" a druhy "newcs" ... uz je to asi kazdemu jasne :-)) ten "NewCS" tam bol z nejakej predchadzajucej instalacie, newcs v dempsey-ho baliku je lowercase (nazov adresara) ... takze mne sa furt spustal ten z foldera "NewCS" a kedze nevidim pre oci vobec som si to nevsimol a vzdy som siel rovno do adresara "newcs" a tam kontroloval configy (ktore boli samozrejme dobre az na to ze to bezalo z ineho foldera)
najprv som hladal v ktorom configu je nastavene ktore pluginy (z ktorych folderov) OpenXCAS spusta ale to som nenasiel tak som to vyriesil uplne prozaicky
killall -9 newcs
rm -rf NewCS
mv newcs/ NewCS/
a potom reboot boxu .. a uz je to ok ..
btw. otazka na miestnych linux-guruov, aj tak by ma zaujimalo v ktorom konfiguraku viem nastavit nazvy foldrov v ktorych sa nachadzaju jednotlive pluginy ...
