Chystá se opravdu FW s Enigma 2 a co by nám to přineslo ?
tommix
Re: Chystá se opravdu FW s Enigma 2 a co by nám to přineslo
Na holandskom fore som našiel toto:
Enigma2 pre Azbox
Unsupported features and known problems
- CAM slots are not supported yet.
- Timeshift does not work yet.
- Rewind does not work properly. Enigma2 sometimes freezes when rewinding.
"Jump back" can be used instead (see keys playback).
- Samsung LCD TVs will probably have problems with the default resolution
576i.
This is an alpha image. That is some functions may not be available or be
buggy (causing crashes / freezes or loss of data).
The installation of the Enigma2 image formats (ext2) the internal harddrive.
ALL FILES ON THE HARDDRIVE WILL BE LOST.
Installation instructions
You will need either a USB stick or a USB harddrive with FAT32 filesystem.
- Copy the files Enigma_Installer.tfd, uImage and rootfs.tar.gz to the USB device.
- Attach the drive to the USB slot.
- Open the firmware update menu and select the image file Enigma_Installer.tfd on the USB drive.
- Start the firmware update from USB.
- After about 6-7 minutes the installation should be finished.
DO NOT REMOVE THE USB DEVICE UNTIL the installation has finished.
During the installation the VFD shows the current installation step and error messages (if any):
"9 USB Stck" mouting USB stick
"PART 8 HDD" HDD partitioning
"7 HDD FMT" formatting HDD (root fs)
"6 HDD FMT" formatting HDD (FS date)
"5 HDD SWAP" Creating swap
"ROOT FS 4" Installing root file system
"3 LOADER" flashing U-Boot settings
"2 kernel" kernel flashing
"1 fsck" checking file system
"0 REBOOT" rebooting within 2 seconds
It is recommended to attach a cable to the serial port and log the output in a
terminal program (eg TeraTerm) during the installation and the first start.
The USB should be writable filesystem to prevent infinite loop installation.
(The uImage file is renamed to avoid the infinite loop.)
The first play usually takes approximately 3 minutes due to creation of
device nodes.
First start
On the first start the Enigma2 interactively configures the video output to be
used. The following options are available:
- Component
- HDMI
- Scart
- HDMI-PC
Each connection type is switched on for 30 seconds. The VFD displays the
connection type which is currently active. You can either wait until the
connection type you want is displayed and your TV shows a picture or you
can select the connection type with Up and Down buttons on the remote control.
Confirm the desired connection type with the OK button. After that you can
proceed with the configuration supported by the configuration wizard.
The image contains a default channel table. If you want to replace it you can
perform a channel scan later.
Network configuration
The U-Boot settings contain the following configuration by default:
MAC address 00:3 e: 9e: 11:22:33
IP address 192,168,178,100
That is after booting the image you can login via telnet if your computer is in
the same subnet.
These values are set up by the U-Boot. You can temporarily change the values
Enigma2 in the menu "Settings / System / Network... / Adapter Settings" or change the
U-Boot parameters.
Default U-Boot bootargs:
BA1 = console = ttyAS0, 115200 root = / dev/sda1 rw init = / bin / devinit
ip = 192.168.178.100:192.168.178.10:192.168.178.10:255.255.255.0: tf7700: eth0:
off nwhwconf = device: eth0, HWaddr: 00:3 e: 9e: 11:22:33
mem = 128M bigphysarea = 4000 coprocessor_mem = 4m @ 0x10000000, 4m @ 0x10400000
To change the IP addresses interrupt the U-Boot and execute the countdown
following command replaced with IP addresses:
TF7700> set BA1 'console = ttyAS0, 115200 root = / dev/sda1 rw
init = / bin / devinit ip = <own IP>: <server IP>: <DNS
IP>: 255.255.255.0: tf7700: eth0: off
mem = 128M bigphysarea = 4000 coprocessor_mem = 4m @ 0x10000000, 4m @ 0x10400000 '
Please note that the setting has to be split in two lines to bypass the
limitation of the U-Boot. The second line must start with a
white space. The
string is enclosed in single quotes. Any change is temporary unless the
settings are saved to flash using the command "saveenv". Before saving
settings to flash you should test whether the kernel boots with your settings.
Enter "boot" at the U-Boot prompt to start the kernel. (After testing the
settings without saving them you will have to enter your changes again.)
Full key map can be found in the file / usr/local/share/
Enigma2 pre Azbox
576i.
device nodes.
First start
- Component
- HDMI
- Scart
- HDMI-PC
the same subnet.
U-Boot parameters.
white space. The
AZBOX Premium
Tuner B : motor SG 2100
Tuner C : DVB-T
AZBOX Premium
Tuner C : DVB-T
zbyneksk
Zajimave, docela podobny popis je i v nejake verzi Team Ducktales' Enigma2 image for the TF7700HDPVR, ze by nejaky klon?tommix píše:Na holandskom fore som našiel toto:
Jinak to nastaveni seriove komunikace je OK, pouzivam "cu --line /dev/ttyS0 --speed 115200".
Nevím, nevím... Toto je Enigma pro Topfielda. A jakej U-boot? V Azboxu je Yamon, ne?
zbyneksk
Otazkou je zda E2 bude resit i zbytek nebo se bude zajimat jen o tu cast TV, ale jinak mas pravdu:visper píše:Nevím, nevím... Toto je Enigma pro Topfielda. A jakej U-boot? V Azboxu je Yamon, ne?
* YAMON ROM Monitor
* Revision 02.06-SIGMADESIGNS-01-2.8.0.1
Memory: code: 0x11000000-0x11040000, 0x11200000-0x11204000
reserved data: 0x11240000-0x12440000, PCI memory: 0x12440000-0x12840000
Environment variable 'start' exists. After 1 seconds
it will be interpreted as a YAMON command and executed.
Press Ctrl-C (or do BREAK) to bypass this.Kód: Vybrat vše
# Formats,
# command : filename
# If command is 'shell', HXShell will excute 'filename'
# If command is 'install', HXShell will copy all files in 'filename'
# If command is not 'shell' & 'install', command is used as the block device
# and 'filename' is used as filesystem images
# Be careful! 모든 이미지는 erase block의 배수의 크기를 가져야 한다
# examples)
# /dev/mtdblock3+64:kernel.img
# /dev/mtdblock2:appllication.img
# Note.
# STB will parse the follow lists in order
# Never exceed 1024 chars in one line.
shell : /Patch/prePatch
/dev/mtdblock0:/Patch/FLASH/loader.bin <=== toto je nas loader.bin
#/dev/mtdblock0:/Patch/FLASH/zboot2.bin
#/dev/mtdblock3:/Patch/FLASH/yamon.bin
#/dev/mtdblock4:/Patch/FLASH/linux.bin
install : /Patch/Update.list
shell : /Patch/postPatch- JirkaB2
Tak jak jsem psal, je 29 a nic nevyšlo a sekce z odkazu je zavřenáJirkaB2 píše:taky jsem si to četl, ale vůbec tomu nevěřím, proč zrovna v neděli? ....Takže 28.3 nic nebude, jen někde zase vyjde, že to ještě není a někdo napíše další termín, ke kterému se budou všichni modlit.marek66 píše:Vraj 28.03.2010 bude den E2
- panborat
Nevyšlo, nevyšlo ... víš ale jak se fantasticky musela zvýšit návštěvnost těchto (i podobných) stránek. To jsem tu o vikendu byl minimálně 20x
Mate
Trošku se právě bojím, aby to celý nebyl hoax a nešlo právě o to, aby se více prodavaly azboxy (opensat, impex) a popr. se generoval zisk za zobrazeni banneru na www pri vysoke navstevnosti (mya*box.de).panborat píše:Nevyšlo, nevyšlo ... víš ale jak se fantasticky musela zvýšit návštěvnost těchto (i podobných) stránek. To jsem tu o vikendu byl minimálně 20x![]()
19.2 E | 23.5 E | 28.2 E | 1.0 W | AZ Elite (vzdy posledni FW) + Xtreamer eTRAYz 1TB (Samsung F1) | LCD Philips 47PFL7642D/12 | LCD Funai LT7-M32BB
- BextrH
Bude to pecka.
pekne, ale taky obrazok vytvorit na pc dokaze 4-rocne dieta a napis na displeji azboxu tiez nic nedokazuje, napisat sa tam da cokolvek.
- BextrH
To jsem jen oběvil při hledání na jedné stránce, psali tam že už brzo bude a zde je pár obrázků. Bylo tam psané že by mělo být rychlejší EPG a přepínání programů. Nevim, možná si ty obrázky vyrobyli. Každopádně malé okořenění Enigmou 2 by neuškodilo. Necháme se překvapit.
zbyneksk
Treba ty rohliky viewtopic.php?p=39916#p39916vikino píše:pekne, ale taky obrazok vytvorit na pc dokaze 4-rocne dieta a napis na displeji azboxu tiez nic nedokazuje, napisat sa tam da cokolvek.
Jirka 76
Není dnes náhodou 1.dubenec?vikino píše:pekne, ale taky obrazok vytvorit na pc dokaze 4-rocne dieta a napis na displeji azboxu tiez nic nedokazuje, napisat sa tam da cokolvek.
SAMSUNG UE46B6000
SAMSUNG UE46B6000
Já bych koupil tu originál Enigmu z války. Nemáte někdo na půdě? Dal bych za to Azbox. :)
anfro11
Asi je, lebo dost sa na temu E2 a nove "zarucene" informacie" k dnesnemu dnu vedie diskusia na inych zahr. forach. Myslim ze treba vydrzat.Jirka 76 píše:Není dnes náhodou 1.dubenec?vikino píše:pekne, ale taky obrazok vytvorit na pc dokaze 4-rocne dieta a napis na displeji azboxu tiez nic nedokazuje, napisat sa tam da cokolvek.
Mate
ano, hlavne napis ENIMGA na obrazku s welcome logem dava tusit ze je prace profikuBextrH píše:Bude to pecka.
