Oscam v et9x00
dym1
Re: Oscam v et9000
Zapis ti musi prist aspon tusim 1geckovy kazdych 24 hodin inak sa karta zablokuje.
otto69
Re: Oscam v et9000
Ahoj chlapi, jak mám nastavit oscam aby se mi sám přepínal na cccam? Díky za odpověď.
Tohle mám v:
oscam.server
[reader]
label = horna-sky.link_irdeto
enable = 1
protocol = internal
device = /dev/sci1
caid = 0624
force_irdeto = 1
detect = cd
mhz = 600
cardmhz = 600
group = 1
emmcache = 1,1,2
lb_weight = 100
deprecated = 1
blockua = 1
blockga = 1
blocksa = 1
blockemm-u = 1
blockemm-s = 1
blockemm-g = 0
blockemm-unknown = 1
[reader]
label = dolni-sky.link_CW
enable = 1
protocol = internal
device = /dev/sci0
fix9993 = 0
detect = cd
mhz = 600
cardmhz = 357
group = 1
emmcache = 1,3,2
lb_weight = 100
deprecated = 1
audisabled = 1
blockua = 1
blockga = 1
blocksa = 1
blockemm-u = 1
blockemm-s = 1
blockemm-g = 1
Tohle mám v:
oscam.server
[reader]
enable = 1
protocol = internal
device = /dev/sci1
caid = 0624
force_irdeto = 1
detect = cd
mhz = 600
cardmhz = 600
group = 1
emmcache = 1,1,2
lb_weight = 100
deprecated = 1
blockua = 1
blockga = 1
blocksa = 1
blockemm-u = 1
blockemm-s = 1
blockemm-g = 0
[reader]
enable = 1
protocol = internal
device = /dev/sci0
fix9993 = 0
detect = cd
mhz = 600
cardmhz = 357
group = 1
emmcache = 1,3,2
lb_weight = 100
deprecated = 1
audisabled = 1
blockua = 1
blockga = 1
blocksa = 1
blockemm-u = 1
blockemm-s = 1
blockemm-g = 1
Re: Oscam v et9000
Dopln si
[reader]
label = cccam
enable = 1
protocol = cccam
device = ip,port
user = username
password = passworld
group = 1
cccversion =
[reader]
label = cccam
enable = 1
protocol = cccam
device = ip,port
user = username
group = 1
cccversion =
otto69
Re: openAAF 2.0 ET9X00
Mám v přijímači binárku oscam-svn6879-test7a-MIPS a kartu Irdeto 0624 v horní čtečce a v dolní 0D03. Po zapnutí přijímače z hlubokého spánku mi obraz naběhne až tak za dvě minuty a více. Dělá vám to taky? Po naběhnutí už to přepíná rychle.
Re: Oscam v et9000
Z toho si tazku hlavu nerob, z hlbokeho spanku je to normalne, kym nabehne eňa a oscam to chvilku trva...
otto69
Re: Oscam v et9000
Díky za odpověď. Já jsem se ptal proto, že v Open Pli 2.1 to šlo o dost rychleji.
otto69
Oscam 1.20-unstable_svn build #7266 testovacia verzia t8a
Nahrál jsem si tuto binárku Oscam 1.20-unstable_svn build #7266 testovacia verzia t8a a mám tmu. (Použil jsem konfigurační soubory co jdou s binárkou Oscam 1.20-unstable_svn build #6879 testovacia verzia 7 na kterých mi jdou karty 0D96 a 0624). Nemá někdo konfigurační soubory na tyto karty, aby šly stou verzí t8a? Díky za odpověď.
Re: Oscam v et9000
Dnes som si nasiel cas a skusil tu 8-micku s roznymi konfigmi a tiez sa mi moja ICE karta nechytila. Tak som testol este tuto binarku oscam-svn7036-test7b-MIPS ako pises ze by v nej mala ist ir.deto karta a moja ICE sa okamzite prepla do IR.DETO modu a ide pekne aj so zapismi. Takze ostan na verzii 7b.
otto69
Re: Oscam v et9000
Vikino, čím se to dělá že se ta ice karta přepne do irdeto. Mě to jede pořád v 0D96 (cw)?
Re: Oscam v et9000
Ja to robim tak, ze nastavim konfiguraky pre 0624 a 0D96 dam do ignore :
I: 0D0F
I: 0666
P: 0624 1
I: 0D96
I: 0D70
I: 0D03
...no a s binarkou pre ir.deto sa ICE karta spusti v ir.deto mode.
I: 0D0F
I: 0666
P: 0624 1
I: 0D96
I: 0D70
I: 0D03
Alesm
Re: Oscam v et9000
Zdravim panove. Mam velkou prosbu. Do nedavna mi normalne Skylink fungoval, ale jednou jsem udelal online update FW a od te doby to nejsem schopny rozjet. Zapomnel jsem si udelat zalohu :-( Uz jsem zkousel vsechno mozne, ale stale nic.
Muzete mi prosim nekdo poslat konfiguraky na Oscam, pripadne jiny softcam, ktery vam funguje? Pouzivam OpenPLI v jedne z poslednich verzi, Oscam mam v 7b, kartu pouzivam pouze jednu (ICE - Skylink vymena), zadne sdileni, pouze jeden prijimac.
Diky, Ales
PS: nemate nekdo zkusenosti s usb dvb-c tunerem Sundtek s CI modulem SMIT Conax a kartou UPC? Pred pul rokem to chvili jelo, ale zase po nejakem updatu to prestalo. Jedou pouze neplacene.
Diky, Ales
Re: Oscam v et9000
Skus sa porozhliadnut tu viewtopic.php?f=289&t=7146 , a-le-bo aj tu viewtopic.php?f=288&t=7256
- eemil
Re: Oscam v et9000
Tak já si myslím, že je zbytečný pro ICE kartu oscam na irdeto. Použij CCCAM 2.3.0, nebo novější SCAM a mělo by ti to stačit
Alesm
Re: Oscam v et9000
Diky za tipy. Doma vyzkousim a doufam ze pojede :-) Jinak ten CCCAM nebo SCAM neni potreba nejak nastavovat? Proste nainstalovat a melo by to jet?
- eemil
Re: Oscam v et9000
Mělo by to fungovat okamžitě, u toho scamu ani nevím jestli a kde se dá něco konfigurovat.
