Open XTA images
Napsal: 19 led 2014, 17:35
od johny72
Re: Open XTA images
Napsal: 28 úno 2014, 15:15
od vikino
OpenXTA V2
is now ready to support the future oe alliance core
All Xtrend boxes supported
et10000, et8000, et9x00, et6x00, et5000, et4000
New updated and supported TechniHD skin,
Commit info setup system
Dedicated metrix skin mod for openxta downloadable from new skin download panel
Reviewed and adjusted xta skin
Integrated and full supported XBMCAddons
attention to use OpenXTA V2 a new software flash is needed
Tu stahuj openXTA img pre et9x00
Re: Open XTA images
Napsal: 02 čer 2014, 05:52
od vikino
New xtrendalliance-4.1 Images by et-view-support
* Bitbake 1.23.1
* OE-Core Mai 2014
* Speed Up build um bis zu 40%
* über 500 Updates an Linux Tools
* erstmaliger Einsatz einer mysql DB für das bauen
* Verbesserung der Qualität beim bauen und bessere Fehlerüberwachung
* Automatische Erkennung von Updates im Source und Automatischen Rebuild der Abhängigkeiten im Build Tree
uvm.
neue OE-A 2.2
Support für Xtrend Modellen
by et-view-support.com Your Xtrend Support nr.1
Tu stiahni Xtrendalliance 4.1 ET 9x00 25/05/2014
Denný update
Re: Open XTA images
Napsal: 17 čer 2014, 17:31
od johny72
OpenXta V3.0
New OE 2.2 with updated Linux tools
Many improvment in building envoirment offering a detection of updates in the source and automatic rebuild of the dependencies in the build tree.
OpenXta V3.0 feature:
-New PiP a unique picture in picture system
-Display improvment (ET10000)
-Updated skins with the newest Red-XT-Global by RogerSSD
-Xbmc addon v6
http://image.openxta.com/index.php?open=et9x00
Re: Open XTA images
Napsal: 01 pro 2014, 18:56
od vikino
!!! Xtrend-Alliance-4.2 !!!
Xtrend-Alliance
http://www.et-view-support.com
We are pleased to announce that from tomorrow on new Xtrend-Alliance Team Image 4.2 is available
After huge request from our users we have decided that we support again Xtrend with our release of image 4.2
Image is based on openPLi4.0 and OE-Alliance 2.3
What is new in OE-Alliance Build-Environment 2.3?
• OpenEmbedded-Core August 2014
• gcc 4.9.1
• openSSL
• TimeZone Updates
• a lot of Linux Tools und libs
• many more.
After huge updates of Bitbake, OE_Core Version August 2014 and new GCC 4.9.1 we had to build all new.
Because of this release get a bump and will be now 4.2
With new GCC Images with Kernel 3.14 are now more stable.
What is new in Xtrend-Alliance 4.2 ?
Could be quite possible that something that has worked before , no longer works in the new driver.
• new Driver / Kernel (not yet all models)
• Update openWeb Interface with Support
• now with AutoTimer Support
• now with Bouquet Editor Support
• Update Skin with reworked Screens
• last E2 Updates und fix available
• updated plugins on feed
• new Cam Center
• openMultiBoot available
• many more
Can i restore old settings on new Trend-Alliance 4.2 Image ?
We recommend not to do so as not to take over old settings and old configurations.
Channel list should be easily reusable.
What happens now with old Xtrend-Alliance Releases ?
Unfortunately, we can not continue to maintain the old releases .
Important changes for all:
With new release at the mipsel boxes the nfs and samba server services are not default in image !!!
SAMBA Shares and NFS Shares as client you can go on to connect your network devices from the box.
But if you want to access from a Windows computer to the box via network browser , you will need to activate it once the services server in the network-menu.
Then the box is again visible in the network
A special thanks goes to the Coders, Beta Tester, Skinner.
Tu stiahni pte et9x00:
download xtrendalliance-4.2-et9x00-016-20141130
Re: Open XTA images
Napsal: 17 říj 2015, 23:43
od johny72
OpenXTA 5.5
Update to latest OE Alliance branch and OE-Core
GST player version: 1.6
Added new forum reader plugin and iptv recording function
Latest version of KodiDirect
updated OpenXTA skins
Plugin backup function via ExtraSetup
