Stránka 1 z 4
Torrent client
Napsal: 05 čer 2009, 20:31
od bibibo
Len pre zaujímavosť skúšam nainštalovať torrent klienta do AzBox-u a stále mi píše -sh: ./trstart.sh: /bin/ash: bad interpreter: Permission denied. Skúšal to niekto ?
Re: Torrent client
Napsal: 05 čer 2009, 20:55
od monkus
funguje mi to bez problemov (vid screenshot)
zakladny debbuging:
MMP[/]$ ls -al /bin/ash
lrwxrwxrwx 1 1000 default 7 Jan 1 2000 /bin/ash -> busybox
MMP[/]$ /bin/ash
BusyBox v1.00 (2008.04.24-06:54+0000) Built-in shell (ash)
Enter 'help' for a list of built-in commands.
samozrejme, cesty som si zmenil, kedze to nespustam z usb ale z interneho disku
MMP[/]$ /bin/ash -x /DATA/hdb1/torrents/trstart.sh
+ killall transmission-daemon
killall: transmission-daemon: no process killed
+ export PATH=/bin:/sbin:/usr/bin:/usr/sbin:/usr/bin/X11:/usr/local/bin:/DATA/hdb1/torrents/release/bin:/DATA/hdb1/torrents/release/sbin
+ export LD_LIBRARY_PATH=/lib:/usr/lib:/MMP/lib:/MMP/usr/lib:/MMP/lib:/MMP/usr/lib:/DATA/hdb1/torrents/release/lib
+ export CLUTCH_HOME=/DATA/hdb1/torrents/release/share/transmission/web/
+ /DATA/hdb1/torrents/release/bin/transmission-daemon -w /DATA/hdb1/torrents -a *.*.*.* -g /DATA/hdb1/torrents/.config -T
MMP[/]$ ps -aef | grep trans
12934 root 988 S /DATA/hdb1/torrents/release/bin/transmission-daemon -w /DATA/hdb1/torrents -a *.*.*.* -g /DATA/hdb1/torrents/.config -T
12935 root 988 S /DATA/hdb1/torrents/release/bin/transmission-daemon -w /DATA/hdb1/torrents -a *.*.*.* -g /DATA/hdb1/torrents/.config -T
12936 root 988 S /DATA/hdb1/torrents/release/bin/transmission-daemon -w /DATA/hdb1/torrents -a *.*.*.* -g /DATA/hdb1/torrents/.config -T
Re: Torrent client
Napsal: 05 čer 2009, 20:57
od bibibo
monkus píše:funguje mi to bez problemov (vid screenshot)
zakladny debbuging:
MMP[/]$ /bin/ash
A kam to ukladá stiahnuté data ? Na HDD alebo USB ? Aha, zmenil si cestu. Idem vyskúšať.
Re: Torrent client
Napsal: 05 čer 2009, 21:33
od monkus
v startovacom skripte si uprav tento parameter:
-w --download-dir <path> Where to save downloaded data
Re: Torrent client
Napsal: 05 čer 2009, 21:38
od bibibo
monkus píše:v startovacom skripte si uprav tento parameter:
Mám s tým problém. Asi neviem dať dokopy ten script. Ak zadám ./trstart.sh tak dostanem odpoveď ./trstart.sh: not found
Re: Torrent client
Napsal: 05 čer 2009, 21:39
od monkus
predchvilou som ti dal navod, ako debuggovat
Re: Torrent client
od monkus
Re: Torrent client
Napsal: 05 čer 2009, 21:40
od bibibo
monkus píše:predchvilou som ti dal navod, ako debuggovat
Skúšam. S Linuxom sa moc nekamarátim.
Re: Torrent client
Napsal: 05 čer 2009, 22:24
od bibibo
Už sa mi to podarilo. Dík.
Re: Torrent client
Napsal: 06 čer 2009, 20:30
od abdulmp
funguje bez problemov - instalaciu som robil presne podla prilozeneho navodu a bez nejakych chyb (teda pokial som nedosiel nato ze obsah toho release.tgz treba najprv rozbalit a az potom v danom adresari untarnut...), je to parada - napr. oproti transmissionu co som mal na IPboxe je to 1 a 1000000 :wink: :106:
mne to stahuje do toho USB zariadenia v ktorom to spustim - mam to na nainstalovane na USB kluci (sam si vytvori adresare na stahovanie) a taha...
Je tam moznost meni miesto ukladania priamo na stranke cez menu v lavom dolnom rohu
Re: Torrent client
Napsal: 13 čer 2009, 15:30
od formis
Mě se to stále nedaří. Ten trstart.sh je nějaký příkaz nebo soubor? Stále se mi vrací hláška can't open /DATA/usb1/sda1/trstart.sh.
Zkoušel jsem ten debugging.
Re: Torrent client
Napsal: 13 čer 2009, 16:16
trstart.sh je shel - spustaci subor. Maly editovqatelny textovy subor, kde su prikazy . ten tam musis mat a mal by mat atribut 755
Re: Torrent client
Napsal: 13 čer 2009, 16:35
od formis
grantec píše:trstart.sh je shel - spustaci subor. Maly editovqatelny textovy subor, kde su prikazy . ten tam musis mat a mal by mat atribut 755
Díky, už mi to jede.
Re: Torrent client
Napsal: 14 čer 2009, 17:20
od visper
Jak se vám to podařilo? Už jsem snědl všechny vitamíny na chytrost a pořád mi to píše Permission denied :sad:
Re: Torrent client
Napsal: 14 čer 2009, 19:39
od visper
Tak už jsem to taky rozchodil. Na flashce mi to zaboha nechtělo změnit atributy, na harddisku ano. Tady je můj trstart.sh:
#!/bin/ash
export PATH=$PATH:/DATA/hdb1/download/release/bin:/DATA/hdb1/download/release/sbin
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/DATA/hdb1/download/release/lib
export CLUTCH_HOME=/DATA/hdb1/download/release/share/transmission/web/
/DATA/hdb1/download/release/bin/transmission-daemon -w /DATA/hdb1/download/torrents -a *.*.*.* -g /DATA/hdb1/download/torrents/.config -T
Teď jdu stáhnout Firefox nebo Operu, protože s IE to nechodí.
