Newcs server
Napsal: 05 zář 2009, 21:54
Mam mozno pre niekoho banalny problem ale snazim sa vytvorit share server v newcs ale nedari sa mi. prikladam moj newcs.config
v citacke mam TT kartu, mam na dyndns vytvoreny ucet, cize prihlasovacie udaje
CWS = romanko4.dyndns.org 20000 test test 01 02 03 04 05 06 07 08 09 10 11 12 13 14
cez telnet sa dokazem z vonku dostat do boxu cez prikaz telnet romanko4.dynds.org ale zdielanie nefunguje, kde moze byt problem a ako to spravne nadstavit. dakujem
<?xml version="1.0"?>
<newCSconfig>
<readers name="Card Readers">
<device>
<name>upper</name>
<type>azbox</type>
<node>/dev/scard</node>
<export>yes</export>
<enabled>yes</enabled>
<blocksa>no</blocksa>
<blockua>no</blockua>
<blockga>No</blockga>
<newcamd_port>20000</newcamd_port>
<autosid>no</autosid>
<carddetect>yes</carddetect>
<priority>hard</priority>
<PTShandshake>no</PTShandshake>
<mhz>500</mhz>
<boxkey>79FDC0E18D278138</boxkey>
<rsa>9ED52515321F04BCF7772151149D6895154B559A8D825A4E7D711A9FAFD5C66BF64689501B254DF1832F754C21095379CF97B4E5BE6E0F1C9CEBF0A0E91D5ACD</rsa>
</device>
</readers>
<xmlserver>
<enabled>0</enabled>
</xmlserver>
<radegastserver>
</radegastserver>
<cache>
<emm>10</emm>
<ecm>-1</ecm>
</cache>
<debug>
<darint39>sintoi51</darint39>
<level>internal</level>
<type>all</type>
<output>console, tcp</output>
<logfile>/tmp/newcs.txt</logfile>
<console_options></console_options>
<file_options></file_options>
<udp_host>172.16.1.1</udp_host>
<udp_port>9000</udp_port>
<udp_options></udp_options>
<tcp_port>1001</tcp_port>
<tcp_options></tcp_options>
</debug>
<newcamdserver>
<name>local</name>
<deskey>01 02 03 04 05 06 07 08 09 10 11 12 13 14</deskey>
<user>
<name>dummy</name>
<password>dummy</password>
<hostname>127.0.0.1</hostname>
<port>12000</port>
</user>
<user>
<name>test</name>
<password>test</password>
<port>20000</port>
<au>off</au>
</user>
</newcamd_server>
</newCSconfig>
