E2 - alfa verzia
E2 - alfa verzia
Neutrino dnes uvolnil alfa verziu E2 - pre testerov. ratam tak tri testovacie - no public verzie a snad do mesiaca mame aj na HD9100 E2 .
emirr
Re: E2 - alfa verzia
Příspěvek od emirr »
Hy guys,
I have just bought HDBOX FS-9100 firmware date 03.02.2010 boot loader ver. 2.23. I can not find loader for this. I want load Enigma 2 from pendrive. I found some loaders for Octagon but I afraid that there is not the same hardware. In Octagon are 2 USB ports in HDBOX 9100 is only one. Have you got any experience with this receiver?
Another question is, Can I use loader for HDBOX FS-9210? What difference are between these receivers?
Best Regards.
HDBox is identical with the receiver Octagon 1008, but the earliest backup loader The original!
Then you can use all the utilities for receiver Octagon 1008 .
emirr
Ok, understand, I can use for my HDBOX FS-9100 software for Octagon 1008.
I read that difference between Octagon 1008 and Octagon 1018 are following: Octagon 1008 is single tuner, Octagon 1018 is twin tuner. It means that I can use loaders and images for Octagon 1018?
No ! Image only Octagon 1008 or AAF -ATEVIO 700 .
emirr
Ok thank you for your help. What about loader that one for Opticum 1018 should be ok? I can not find dedicated loader for Opticum 1008. I'll download Image for Octagon 1008 or AAF -ATEVIO 700 maybe loader is inside the pack.
Thanks again.
No - the loader always! record separately. AAF recovery tools - install Maxiuboot
:arrow: http://www.forum.satdigitalne.cz/viewto ... 233&t=5151
AAF Recovery Tool v 3.7
Zpět na „Diskuze HD-BOX FS-9100PVR“
