NTFS pro HD-BOX FS-9100 / 9200 / 9300
Napsal: 20 kvě 2011, 00:05
NTFS plugin pro a výše 1.09.09
* This NTFS plugin is only working with 9xxx series models.
* it can check ntfs file system with HDD which is formatted as ntfs system.
* you can download it into USB memory and then put your receives.
* once you see the pop-up then you can press red button to download it.
* after all process completed, you can find 'ntfsck' item in Plugin menu.
* this 'ntfsck' doesn't need to change 'State' and 'Start Type'.
* later we will improve this menu disable to change setting.
* it is just working without any activation.
* this file size is 800 Kbytes, so it can take some space from Flash Memory and you are not able to download other plugin files as much as ntfs file size.
* if you don't use NFTS system HDD for 9xxx series models, you don't need to download this plugin.
