EGAMI team image
Napsal: 16 čer 2011, 20:33
Egami - 1.0 - et9000
Overview:
- Image based on Oe 1.6
- Kernel 2.6.18-7.4
- Drivers 16.05.2011
- Most of USB Wifi Dongles should works
- Most of USB Tuners - DVB-C / DVB-T / DVB-S2 should works - UP to 2 dongles !
Installed Plugins:
- HDMI-CEC Support
- BLIND SCAN Support
- Web Interface
- MyTube Player
- FAN Setup
- OSD 3D Setup
- OSD Position setup
- Cross EPG SVN 300
Buttons Mapping:
OK button = LITE SKIN ( need to be turned on on GREEN PANEL -> EXTRAS -> OSD SETTINGS )
OK button x 2 = Extra Info Skin
Blue button = EGAMI Blue Panel
Blue button and then Yellow button = INFO Panel
Blue button and then Blue button = EGAMI Settings
Blue button long press = Extensions
Yellow button = Time Shift
Green button = EGAMI Green Panel
Green button long press = Subservices
Green button and then Red button = ADDONS
Green button x 2 = EGAMI Settings
Green button and then Yellow button = FILE MANAGER
Green button and Blue button = SCRIPTS
Button Red = EPG List
Button PIP = Turn ON / OFF PIP
Button PIP long press = PiP Menu - Move/Switch Windows
Infobar:
- CAM Name
- ECM INFO
- NETCARD INFO
- CA INFO
- TUNER INFO
- CHANNEL INFO
- NEXT EVENT INFO ( in channel list !! )
- AnalogicClock renderrer
- Lite and Full infobar skin
much, much and more...
Egami Panel include:
- Green button and then Red button takes You to EGAMI ADDONS MANAGER
--> Download Egami Addons - Download extensions from Egami Server
--> Manual Egami Addons Install - Install packages from /tmp
--> Remove Egami Addons - Remove installed packages
--> Download GUI Addons - Download CVS Extensions
--> User Addons - Here You can install extensions from Your own server ( put in /etc/user_addon.txt url to catalog: example: http://..... )
- 2x Green button takes You to EGAMI Extras
--> Kernel Modules Manager - start/stop kernel modules
--> Devices Manager - here You can easily mount/map/format/settings Your extra memory storages like HDD, USB. REMEMBER TO MOUNT HDD BEFORE RECORDING !!!
--> Services Panel - here You can Start/Stop/Check Status/Setting up:
+ NFS Server
+ HTTPD
+ Inadyn
+ Cron
+ DjMount ( UpNp Client )
+ uShare ( UpNp Server )
+ Syslog
+ Samba
+ OpenVPN
+ FTP
+ Telnet
+ Pcscd
--> Mount manager - here You can mount Your networks share - CIFS/NFS
--> Decoding Setup - You can disable some messages like eg. "Show Tune failed info?"
--> Swap File settings - make Your swap file
--> OSD Settings - Here You are able to Turn ON / OFF options like: Lite Skin, Orbital position, cam name, provider, crypt info in Infobar, Pernamental Clock, Picons and much much more...
--> Stream Information - Get PAT/CAT/NIT/EIT/ECM Info
--> USB Wifi & Tuner Dongles Setup - in this panel You can easily see what kind of Wifi or Tuner ( DVB-c/t/s2 ) you have connected to box and load drivers. The most complete info ever: Manfacturer, Vendor ID, ProID
- Green button and then Yellow button run EGAMI FILE MANAGER
--> You can Move/Copy/Remove/Rename Your files inside Your Box !
--> You can Create New Directory/New Text File/New Symlink !
--> You can change Permission of the files !
--> You can play all movies and music directly from Egami File Manager !
--> You can watch Your pictures from holiday directly from Your USB dongles by Egami File Manager !
--> You can start SHELL scripts
--> You can start PYTHON scripts
--> You can view most type of files by pressing OK
--> 1st EVER - You can download Subtitles to Your movies stored inside your HDD - it finds subtitles exacly to version of the movie You have ! - available languages - ENGLISH, POLISH - more will come SOON...
- Green button and then Blue button run EGAMI Scripts Panel
--> You can run all scripts from /usr/scripts/
--> You can easily add new scripts to /usr/scripts/NAME_smartscript.sh and it will be visible in Scripts Panel
Credits
Thanks to the group of Beta Testers.
Thanks to Rytec for providing us with the server with all epg.dat files.
Thanks to SiF Team for the nicest EPG plugin ever - CrossEPG
Thanks to Skaman from SiF Team for extuner and usbloader
DISCLAIMER
THE EGAMI IMAGE IS BASED ON THE OFFICIAL FIRMWARE PULBISHED BY XTrend AND IN ACCORDANCE WITH THE LAW IT CONTAINS ONLY SYSTEM ADDITIONS & GRAPHIC CHANGES.
THE EGAMI IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.
LASTLY, THE EGAMI IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.
LICENSE (TERM OF USE)
THE EGAMI IMAGE IS ISSUED FOR THE FREE USE FOR ALL USERS PROVIDED THAT IT WILL NOT BE CHANGED IN ANY WAY AND THAT IT WILL ONLY BE USED FOR LAWFUL PURPOSES.
ANY CHANGES OR ADDITIONS TO EGAMI IMAGE THAT INVOLVE UNLAWFUL USE OF THE IMAGE SUCH AS CARD-SHARING AND EMULATORS ARE NOT ALLOWED AND CAUSE THE REWOKE OF THIS LICENSE.
DOWNLOAD
thx Egami Team
Overview:
- Kernel 2.6.18-7.4
Installed Plugins:
- HDMI-CEC Support
- Web Interface
- MyTube Player
- FAN Setup
- OSD 3D Setup
- Cross EPG SVN 300
Buttons Mapping:
Infobar:
- CAM Name
- ECM INFO
- NETCARD INFO
- CA INFO
- TUNER INFO
- CHANNEL INFO
+ NFS Server
+ HTTPD
+ Inadyn
+ Cron
+ Syslog
+ Samba
+ OpenVPN
+ FTP
+ Telnet
+ Pcscd
Credits
DISCLAIMER
DOWNLOAD
thx Egami Team
