glasssysutil - plugin (GSU)
- vikino
GSU Light ver. 1.01
- fix channel info
- fix channel info
- vikino
Re: GSU Light ver.
GSU Light ver. 1.02
- added detection "probably damaged" device (fix detection of a device)
- vikino
- vikino
- vikino
Re: GSU
GSU Full ver. 3.67
-added start/uptime in main oscam info and detection less/bigger version
- added mgcamd 1.36
- newcs 1.70
- removed hypercam 2.14
Note: - mgcamd 1.36 - coming from the last public version 1.35a patched by D2MAC.
1.36 - Added support for ICE EMM stream with both headers (8X 40 and 8X 70)
19.2E Canalsat (022610), 39E ANT1 Europe (021110)
Fixed ORF provider 10
Added support for Irdeto2 providers: 13E JSC Sports (0603), 19.2E C+NL (0622), 39E Bulsat (0604)
Removed some anoying log messages like: [newcamd] ... new card.... or RSA nagra2 key not found for ID.....
Download
- added mgcamd 1.36
- newcs 1.70
Download
- eemil
Re: GSU
GSU Full ver. 3.91
- from this version of the GSU plugin, cam and srv (binary / scripts) are not a part of GSU, after pressing 0 in the UCM can be added, after pressing 8 can be removed, of course there is a check if I want to take a running cam / srv - does not allow it, autorefresh added / withdrawn is commonplace, as well as functionality / connectivity to the internet server is checked if it does not work correctly, will report an error
- GSU itself has a size of about 500kB
- in the menu for download: cam are marked with a yellow and srv blue color
Summary said: UCM to download only what I need and I can add cam/srv how I need
Warning: Before installing stop all running cam and srv in UCM, UCM terminate, install the update, restart the GUI - all done, update will remove all binary and scripts, the update will be installed through download-on, all delivered out of bin scripts and components of earlier versions remain untouched in the GSU - if someone created and add your own
- vikino
Re: GSU
GSU Full ver. 5.07
- fix hdd state (animated icon-system info)
- fix hdd temperature (system info)
update is available online
thx shamann
thx shamann
- vikino
Re: glasssysutil - plugin (GSU)
GSU Full ver. 5.09
- 2nd fix hdd state (animated icon-system info)
- 2nd fix hdd temperature (system info)
- pre zobrazenie teploty hdd je potrebne aby bol v stave running.
thx shamann
thx shamann
- vikino
GSU Full ver. 5.11
- 2nd fix oscam info: user info
thx shamann
thx shamann
- vikino
GSU Full ver. 5.15
- updated conax, viaccess logo
thx shamann
thx shamann
- vikino
GSU Full ver. 5.16
- fix satellites.xml download/update
thx shamann
thx shamann
- gorick
GSU Full ver. 5.34
- UCM: changed(setup): removed using number buttons on RC, blue - move cursor, yellow - activate
- UCM: added new option - enable/disable Srv restart if Cam is running
- vikino
GSU Full ver. 5.35
- UCM: fix options indexing
thx shamann
thx shamann
- vikino
GSU v 5.36
- added autodetect and autoconnect to backup server if primary failed (UCM, update)
thx shamann
thx shamann
- vikino
GSU Full ver. 5.40
- fix devices manager
