HD Glass16
- vikino
Re: HD Glass16
HD Glass16 ver. 3.25
- added screen 13,14,15 and icon set 6 - if you will use screen13, switch icons set to 6 (short icons)
- small update piconProv
ver. 3.26
- fix user info screen
thx shamann
ver. 3.26
thx shamann
- vikino
Re: HD Glass16
HD Glass16 ver. 3.61
- fix gbox ecm parsing
- added a new user screen: side bar consistent with enhanced bar, but is activated press 2xOK, enhanced infobar is automatically disabled (not blocked!!!)
- added bitrate limiter - set in the range 15000 to 40000 kb/s - after exceeding the limit bitrate will automatically stopped
- added help in the setup - downloadable from the server - 8 button - automatically activated for each item and value in the setup
- added support BH 1.6.6 lower unsupported
- in a special Screene: changed TP values from hex to hex/dec
- update piconProv (thx ftryskac)
Version is available via online update
thx shamann
thx shamann
- vikino
Re: HD Glass16
HD Glass16 ver. 3.74
- added neutrino keymap option in setup
- added vcr_switch item in menu types (if available)
- added HDD state detection in infobar, can be enabled via setup
- help updated
- icons type updated
- fixed lcsting.list - enigma 3.2
Warning:
1. if you do not default icons type1, after restore, icon type will be reset to default set 1, then go to setup and download updated icons pack and set your prefered icon type
2. if there is the new enigma(3.2) in your image, before update remove or delete /etc/lcstring.list
3. Version is available via online update
thx shamann
- help updated
Warning:
thx shamann
- vikino
Re: HD Glass16
HD Glass16 ver. 3.79
- added selected picon_default, next, marker... black/white
- added enable/disable OLED off in standby
- help updated
- code optimalisation - acceleration
Update is available online via setup
thx shamann
- help updated
thx shamann
- vikino
Re: HD Glass16
HD Glass16 ver. 3.85
- added new option in setup: setup with PIG (yes, no)
- help updated (do it via download menu)
- added title if messagebox is type YESNO (setup messages)
- changed restart gui procedure - fix CAM to stay alive on some HW
- added screen 16,17
- added autoreconfiguration windowstyle for screens 16.17
- previews updated for screens 16,17 (do it via download menu)
- increased speed of skin - switch beetween channels menu etc.
- autoblock bitrate if screens 16,17 are activated
- autoblock fade if alpha is not present on HW
thx shamann
thx shamann
- vikino
Re: HD Glass16
HD Glass16 ver. 3.89
- added detection of DGCrypt (after restore icons type will be set to default type 1, so after update and autorestore you must download icons and previews and then set/select your prefered icons type)
- added download picon white in download menu
- added new style 3
- added screen 18, 19,20
- fix channel selection type 2,4
- added option set style to screen and edit color of title in style
- icons and previews in download are updated
thx shamann
- added new style 3
thx shamann
- vikino
Re: HD Glass16
HD Glass16 ver. 3.91
- fix support for plugin EMC 3.0.0
- fix detection of Nemesis image 101r1( do not use this and next versions in older version of Nemesis)
- fix icon type 1
- icons in download updated
thx shamann
- fix icon type 1
thx shamann
- vikino
Re: HD Glass16
HD Glass16 ver. 4.14
- added new channel selection type: "G16(+next, date, colored list)"
- help updated in download
thx shamann
thx shamann
- vikino
Re: HD Glass16
HD Glass16 ver. 4.18
- previews updated in download
- added screen 24
- added screen 24
- vikino
Re: HD Glass16
HD Glass16 ver. 4.21
- fix recording paths screen
- added new user screen: Event now/next and side infobar
- added new option in setup: Show sat position in TP info only
- vikino
Re: HD Glass16
HD Glass16 ver. 4.33
pre niektorych userov pridany cz jazyk
viewtopic.php?f=260&t=6766&p=81331#p81331
- vikino
Re: HD Glass16
HD Glass16 ver. 4.39
- added autopositioning of the message box
- added uk - ukrainian translation (thx bodyan)
- added ukrainian locale in lcstring.list (thx bodyan)
- added screen 25, 26 and style 7
- added screen 27 with realtime LED signal strength
thx shamannodporucanie pre openli: instalovat do cisteho image alebo urobit update image a potom instalacia skinu
- vikino
Re: HD Glass16
HD Glass16 ver. 4.47
- fix pl translation (thx kosmacz)
- added video resolution in screen 29
- added new option in the setup: Volume position - press button 9
- fix download icons sets and previews
- added icons set 10 in download
HD Glass16 ver. 4.48
- fix screen 26 (picon)
thx shamann
thx shamann
- vikino
Re: HD Glass16
HD Glass16 ver. 4.50
- added icons set 11
- added new menu type: new style
- help, previews updated in download
- fix user info - event now and next
- fix screens 28, 29
thx shamann
thx shamann
- vikino
Re: HD Glass16
HD Glass16 ver. 4.51
- added new channelselection type: new style and new style(colored)
- added better formatting of EPG info - event now and next
- fix TP info in main code
thx shamann
thx shamann
