OSCAM
OSCAM
Oscam ver 22 pre fw. verziu 1.08.22
Interne citacky vypnut !!
- citanie kariet skylink 0D70 - dolna citacka + 0D0F cslink -horna citacka (prednastavene)
mozno samozrejme prekonfigurovat na pouzivane karty. Konfiguracia pre citacky je v subore oscam.server (vo /var/tuxbox/config/) .
Horna citacka je na SC1 a dolna citacka na SC0
Nakonfigurovany aj ako newcamd server
parametre zapisu do dalsieho prijimaca -protokol newcamd
* IPadresa- realna lokana ipadresa boxu s Oscamom
* port 15000 karta 0D70 / 15001 karta 0D03 / 15002 karta 0D02 / 15003 karta 0D0F
* user hdbox
*password hdbox
* DES key 01 02 03 04 05 06 07 08 09 10 11 12 13 14
Instalovat cez USB kluc , najskor sformatovat /var/ - pozor zmaze sa tym aj helper pre start enigmy , je to mozne ale kedykolvek doinstalovat cez AAf recovery Tools.
V menu -plugins zapnut autostart oscamu a potom restartovat prijimac.
* user hdbox
*password hdbox
Re: OSCAM
Nastavenie v subore oscam.server pre rozne verzie CCcam serveru :
cccversion = 2.0.11
cccbuild = 2892
cccversion = 2.1.1
cccbuild = 2971
cccversion = 2.1.2
cccbuild = 3094
cccversion = 2.1.3
cccbuild = 3165
cccversion = 2.1.4
cccbuild = 2598
cccversion = 2.0.11
cccbuild = 2892
cccversion = 2.1.1
cccbuild = 2971
cccversion = 2.1.2
cccbuild = 3094
cccversion = 2.1.3
cccbuild = 3165
cccversion = 2.1.4
cccbuild = 2598
Re: OSCAM
Nastavenie dolnej ciitacky na kartu 0D03 (skylink, predtym TaT) , pre blokovanie zapisov:
## Skylink-dolna
[reader]
Label = Skylink
Protocol = internal
Device = SC0
detect = CD
#EMMCache = 1,3,2
group = 1
CAID = 0D03
IDENT = 0D03:000000
blockua = 1
blockga = 1
blocksa = 1
blockemm-u = 1
blockemm-s = 1
blockemm-g = 1
blockemm-unknown = 1
Re: OSCAM
Oscam v22 - fix newcamd client+htttp support
rozbalit na PC az do adresara plugin - prekopirovat na USB kluc, vlozit do prijimaca a nainstalovat.
Podrobne info platne tie hore uvedene.
dvbapi aktivne- cize robi server, klienta a aj dekoduje. Pouziva sa ako samostatny plugin.
Odskusane:
newcamd client
cccam client
newcamd server
pristup k web rozhraniu:
do prehliadaca zadat : http://xxx.xxx.xx.x:8888 (namiesto xxx.xxx.xx.x zadat skutocnu ip adresu hdboxu .)
meno : root
heslo: oscam
thx : slavo@vld
Odskusane:
newcamd client
cccam client
newcamd server
meno : root
heslo: oscam
thx : slavo@vld
Re: OSCAM
Nastavenie oscamu pri problemoch s internou citackou a share
Najlepsi parameter je penalty = 1 (send fake CWs)
Filtrovanie podla SID funguje.
dvbapi (oscam ho puziva ako klienta !) sa orientuje podla zapisu v subore oscam.conf (uvadzany priklad -mam karty 0D03 a 0D0F)
samotny newcamd klient sa orientuje podla zapisov v subore oscam.services . Treba mu pridat aj oznacenie providera, ktoreho ma pouzivat . Do oscam.server som si k portu, kde mam skylink kartu pridal :
V istych pripadoch moze byt jednoduchsie oscam.services nepouzivat vobec a spolahnut sa radsej na ignore a priority zapis pre dvbapi klienta.
prikladam aj svoj oscam.services
Kto ma kartu 0D70 a bude ju chciet pouzivat aj na ine ako zakladne programy (neplatene), bude musiet dopisat SID k skylink_blue (0D70) - ja sam tam dal len zaklad, lebo taku kartu som mal v internej citacke.
Bol tu spominany aj problem s rovnakymi SID. Na Astra23,5 su to celkovo tri SID, ktore pouzivaju 2 programy naraz:
1F42 : STV1 +Prima
1F43 : STV2 +CT1
1F44 : STV3 +CT2
Standartne problem s tymito SID nemusi nastat vobec, jedine v pripade zapnutia regionalizacie a konkretne pri SID 1F44 - priklad z nedavnej minulosti - ZOH 2010 a ochrana autorskych prav.
Asi ste uz aj prisli na to, ako narabat s dvomi kartami s rovnakym CAID - jedna v internej citacke a jedna na servery ale kazda s inymi opravneniami.
pomoc je jednoducha - pouzijem v oscam.server ku kazdej reader parameter services .
vytvorim si vlastny oscam.services kde si zapisem napriklad:
[dvbapi]
priority = 0D03
ignore = 0100,0D96,0624,09C4,09C7,0D70
to cervenym oznacene som pouzil vlastne zo suboru oscam.services , cervenou som oznacil ,ktory parameter to je :[reader]
label = newcamd_skylink
enable = 1
protocol = newcamd
device = xxx.xxx.xx.x,10001
account = azbox,azbox
services = skylink
disableserverfilter = 1
caid = 0D03&FFFF
ident =
group = 1
ecmcache = 1
Odladit to - teda k jednotlivym providerom pridat SID podla realneho stavu je ale celkom umenie a najlepsie sa to odladuje kontrolou cez web rozhranie oscamu - hlavne ked nejde nejaky program a viem,ze by mal ist a viem aj z ktorej karty .[cslink]
caid = 0D0F
provid = 000000
srvid = 1F42,1F43,1F44,3352,1F41,3338,334F,334B,13AB,1F47,3353,1F45,36F6,334A,3354,2337,232D,13AE,13AC,333B,3333,3336,333A,2335,232E,3351,332C,332F,3331,3330,3335,2336,3339,334D,334E,332E,13BA,332D,1F55,1F56,1F57
[skylink]
caid = 0D03
provid =
srvid = 1F42,1F43,1F44,3352,1F41,3338,13AB,1F47,3353,1F45,36F6,13B4,13B3,5156,13B1,13AF,1B71,1B62,13B2,13B5,13A6,13A7,13BD,13BC,13AC,13AD,232F,232F,2330,2331,2329,232B,13B6,2334,2333,13B7,333B,13B4,13B9,13BA,232D,13BD,3334
[upc hd]
caid = 0D02
provid =
srvid = 791B,791A,791E,791C,0B77,106A,0EDE,0EDD
1F42 : STV1 +Prima
1F43 : STV2 +CT1
1F44 : STV3 +CT2
V takomto pripade ale dvbapi klientovi dam priority = 0D0F[cslink_interna]
caid = 0D0F
provid = 000000
[cslink_share]
caid = 0D0F
provid = 000000
srvid = 3353,1F45,36F6,334A,3354,2337,232D,13AE,13AC,333B,3333,3336,333A,2335,232E,3351,332C,332F,3331,3330,3335,2336
Re: OSCAM
slavo spravil krasny prehlad SID na ASTRA23,5 - pre cslink a skylink . Dufam,ze mu nebude vadit, ked jeho pracu pouzijeme aj pre nase ucely tu
slavo píše:Kto sa s tým chce hrať, malá pomôcka v excel formáte.
Sú tam 2 záložky, skylink a cslink, v stĺpci "mám ?" si len doplnte, či daný program máte, alebo nie.
Potom dole je reťazec potrebný pre oscam.services, takže ctrl-c a ctrl-v do oscam services.
Kto má skylink 0D03, zmente hore CAID (ja mám 0D70).
Okrem toho sú modrým označené dáta, ktoré môžu ísť do oscam.srvid. Ľahšie sa potom orientuje vo web rozhraní.
Re: OSCAM
Pridavam este patch na sledovanie Sky germany HD programov , v pripade, ze na servery je karta s CAID 1702 .
Do suboru oscam.conf -parameter dvbapi pridat:
priority = 0D03,1702
ignore = 09C4,09C7,0100,0D96,0624,0D70,1834
Do suboru oscam.server , link cccamu pridat:
services = sky
caid = 0D02&FFFF,1702&FFFF,1833&FFFF
ident =
group = 1
Do suboru oscam.user k defaultnemu uzivatelovi pridat :
au = 1
services = sky
caid = 0D03&FFFF,0D0F&FFFF,0D70&FFFF,0D02&FFFF,1702&FFFF,1833&FFFF
betatunnel = 1833.FFFF:1702
ident =
keepalive = 1
services = sky
ident =
group = 1
au = 1
services = sky
ident =
keepalive = 1
Re: OSCAM
Update CS zoznamu SID .
doplnena platforma UPC-DTH z pozicie Thor.
thx Billy-sk
thx Billy-sk
Re: OSCAM
CAID nasich providerov :
0D03 - karta skylink (biela) , starsia karta TaT (rozne verzie bios)
0D70 - karta skylink modra, karta Skylink -modra
0D96 - karta ICE skylink (bios 3)
0D0F - karty -gital, CSlink
0D02 - karta UPC -cryptoworks
1815 - karta UPC Nagravision , parovana s prijimacom
CAID, s ktorymi sa este mozte stretnut na nasich programoch - z roznych dovodov (napr. spolocne vysielanie s inym providerom -koli uspore nakladov)
0100 - Seca system - zvycajne na HD programoch skylinku, vysielane spolocne s providerom CanalDigital NL na Astra 23,5
0624 - Irdeto 2 - providerom je skylink a CAID patri novemu systemu (je uz aktivny) .Je uz na kazdom programe skylinku
Dobrou pomockou pri praci s inymi kartami moze byt aj tato stranka http://streamboard.gmc.to:8001/wiki/CardsList#CardsList
Re: OSCAM
Oscam 0.99.4 svn 2901 - HDBOX
Opraveny a predkonfigurovany Oscam , umoznujuci citanie kariet skylink ICE a inych ....
Prednastavene :
HDBOX 9100 - skylink ICE karta (CAID 0D96)
HDBOX 9200/9300 - dolna:skylink ICE (CAID 0D96) , horna: cslink (CAID 0D0F)
Testovane na fw verzie 1.08.26 .
Predchadzajucu verziu Oscamu si zmazte - komplet , vlastne pristupy na karty si zalohujte vopred.
Oscam je nastaveny ako kartovy server pre domacu siet (nielen) - max. 9 uzivatelov
Pristup na kartu je potom mozny bud v newcamd a/alebo cccam protokole. Oba protokoly pracuju sucasne (pre cccam povolene reshare hop2) .
Parametre pristupu ,ktore sa zadavaju na dalsom (klientskom prijimaci):
N: ipadresa_boxu 15001 meno heslo 01 02 03 04 05 06 07 08 09 10 11 12 13 14 (ice karta)
N: ipadresa_boxu 15002 meno heslo 01 02 03 04 05 06 07 08 09 10 11 12 13 14 (cslink karta)
a/alebo
C: ipadresa_boxu 40000 meno heslo yes (ICE karta+cslink karta)
Prednastaveny uzivatelia na zdielanie v lokalnej sieti (nielen) :
meno/heslo
user1 /user1
user2/user2
az
user9/user9
Oscam sa vyznacuje mimoriadnou stabilitou - pri minimalnom zasahu do nastaveni . PIP a dual records samozrejmostou .
Nieje funkcny prechod zapisov emm (netreba blokovat citacku - neprejde ziadna emm instrukcia )
Po nainstalovani a restartnuti okamzite funguje , je dobre pred instalaciou vypnut internu citacku v boxe. Vypnutie citacky je pre spravnu funkciu nevyhnutne . Ak instaluje uplne novu ICE kartu- je potrebne nechat prejst zapisy v internej citacke (samozrejme zapnutej a oscam musi byt stopnuty.
Aktualizovane service info (pre web rozhranie )
Pristup na web rozhranie : http://ipadresa_boxu:8888
meno: root
heslo: oscam
a este z dnesneho testu - vypis z weboveho rozhrania:
vo velkom obdlzniku su klienti s pouzivanym protokolom (cccam + newcamd)
v malom zas celkova dlzka testu - 12hodin , 36minut 27 sekund - 0 bad ecm !
Prednastavene :
a/alebo
meno/heslo
user1 /user1
user2/user2
az
user9/user9
meno: root
heslo: oscam
Re: OSCAM
Oscam v 3017
Aktualizovana binarka oscamu (staci stopnut beziaci proces oscam-u a vo /var/bin/oscam/ nahradit staru verziu novou)
Podpora internych citaciek
podpora klient + server CCcam
aktualizovane pomocne subory (providers, service ....)
do oscam.conf treba zadat
boxtype = fortis
Re: OSCAM
Oscam v 3047
Re: OSCAM
Oscam v 3042 + konfiguracne, komplet
prednastavene
dolna citacka - ICE karta (teda pre HDBOX9100+ ICE)
horna citacka - cslink
citacky sa zapinaju parametrom "enable = 1 " , vypinaju parametrom "enable = 0"
newcamd ide na porte:
ICE karta: 15000
cslink karta : 15001
skylink karta : 15002
cccam na porte 40000
klientom treba zadat meno / heslo:
hdbox1/hdbox1
hdbox2/hdbox2
webif na porte 8888 , meno: root , heslo:oscam . Nastaveny autorefresh webu .
instaluje sa pomocou USB kluca
pred instalaciou si odzalohujte svoje konfiguracne subory - prepise ich komplet !
prednastavene
ICE karta: 15000
hdbox1/hdbox1
hdbox2/hdbox2
Re: OSCAM
Oscam v 3074 - len binarka . Pripravena na vymenu namiesto starsej verzie, cize konfiguracne subory v boxe uz musite mat .
Rozbalit na PC a adresar /plugin/ presunut na USB kluc. Vlozit do prijimaca a po vyzve k instalacii nainstalovat. Staru verziu Oscamu nemazat . Po restarte uz nastartuje veria 3074 .
Re: OSCAM
Oscam v 3133 - len binarka . Pripravena na vymenu namiesto starsej verzie, cize konfiguracne subory v boxe uz musite mat .
Rozbalit na PC a adresar /plugin/ presunut na USB kluc. Vlozit do prijimaca a po vyzve k instalacii nainstalovat. Staru verziu Oscamu nemazat . Po restarte uz nastartuje veria 3133 .
