Tank original firmware
Images pro přijímače Coolstream Tank
matchboxx
Příspěvek od matchboxx »
08.09.2013 - Version 2.13 RC1
- Add xupnpd - eXtensible UPnP agent
This program is a light DLNA Media Server which provides ContentDirectory:1 service for
sharing IPTV unicast streams over local area network
(with udpxy for multicast to HTTP unicast conversion).
Share your Coolstream STB Bouquets in your local network
to your smartphone or Ipad (using upnp app)
Just enable xupnpd under Mainmenu->Network->Network services
and you are done!
Point your Internet browser to 'http://192.168.1.1:4044'
(192.168.1.1 replace with your Coolstream STB address). Upload your playlist (m3u file format). Enjoy
Your Bouquets channel list is automatically added
and ready to share!
- Bug Fixes, Stability Enhancements
WARNING:
This release will upgrade your Kernel and first stage bootloader on first boot!!!
Please dont power off your receiver bevore upgrade is done!
ke stazeni na http://www.coolstream.to/index.php?page ... dataID=396
Soukrome zpravy nectu, pouzivejte forum, mozna tim pomuzete ostatnim
matchboxx
Tank original firmware- 03.02.2014 - Version 2.13 RELEASE
* add persistent /var partition, now all settings preserved when new image flashed
* file player: improved mkv and avi playback
* audio player: add support for AAC codec
* EPG scan now do rescan every 24 hours
* Many fixes and improvments
To switch between the Standard Menu and the Simplified Menu, press
MENU button on your RCU, then press "STOP" button on PVR control section,
follow the on-screen guidance (input pin 0000), then choose YES to reboot your device.
ATTENTION: Only through the Standard Menu you can experience the full functions of Neutrino HD
ke stažení zde - :arrow: www.reviservis.sk/apollo/2_13_tank.zip
Re: Tank original firmware
Update :
driver z 12.03.2014 (instalovat na original verziu ako prvu z tohto balicku .
Instalacia - presunutim do /tmp/ v prijimaci a dialkovym cez Menu - Sluzby - Aktualizacia software- Lokalna aktualizacia .
Neutrino update z 19.03.2014 - pozor nastavenia satelitu (tuneru) sa modifikuju , po instalacii sa zvolia prednastavene hodnoty (len ASTRA 19,2 ), je potrebne tuner (y) nastavit opat !
Dal poděkování: 174 poděkování
Dostal poděkování: 261 poděkování
Příspěvek od marsim21 »
neutrino_update_apollo_15_04_14_1811
PŘED tuto aktualizaci, musí být nutně provedena aktualizace ovladače (driver update).
Quellcode
1.Jacek Jendrzej	compil fix withot mdev
2.Thilo Graf	OPKG-Manager: add opkg manager feature
3.M. Liebmann	Update deutsch.locale
4.[CST] Focus	gui/hdd_menu.cpp: rework HDD menu, add device mount...
5.[CST] Focus	locals: add hdd mount/umount locales
6.[CST] Focus	gui/widget/menue.cpp: fix selected in case saved one...
7.[CST] Focus	zapit/src/fastscan.cpp: fix compile warning
8.[CST] Focus	zapit/src/fastscan.cpp: implement new/removed channel...
9.[CST] Focus	gui/scan_setup.cpp: add explicit option to enable/disab...
10.[CST] Focus	locals: add new locales for fast-scan
11.[CST] Focus	for fast-scan and cable-scan, put bouquets to beginning...
12.Jacek Jendrzej	upnpbrowser.cpp: osd fix with radius
13.svenhoefer	- menu: add possibility to add a footer to the menus...
14.Thilo Graf	CMenuItem: reduce scope of str, trivial
15.Thilo Graf	/gui/widget/menue.cpp: rework constructors, use methode...
16.M. Liebmann	CPersonalizeGui: Replaces CMenuOptionChooser::getOption...
17.M. Liebmann	CPersonalizeGui::changeNotify: Fix display error
18.M. Liebmann	CMenuOptionChooser: Remove bad function getOptionName()
19.Jacek Jendrzej	yWeb: dont zap on channel change
20.Jacek Jendrzej	eitd/sectionsd.cpp void addEven: crash fix, do not...
21.Jacek Jendrzej	streamts.cpp StreamInstance::Send: do not block neutrin...
22.[CST] Focus	neutrino.cpp: log and return messages_return::handled...
23.[CST] Focus	zapit/src/fastscan.cpp: add read FST version, adjust...
24.[CST] Focus	system/settings.cpp: remove delivery_system setting...
25.[CST] Focus	gui/scan_setup.cpp: save FST version after scan
26.[CST] Focus	zapit/src/scan.cpp: reset FST version on normal scan
27.[CST] Focus	gui/scan.cpp: center scan header
28.[CST] Focus	locales: remove extra info from satsetup.fastscan_head
29.[CST] Focus	gui/cam_menu.cpp: remove extra debug
30.[CST] Focus	gui/bouquetlist.cpp: show epg icon for bouquets selecte...
31.[CST] Focus	gui/widget/icons.h: add NEUTRINO_ICON_EPG
32.[CST] Focus	gui/audio_select.cpp: disable analog audio on/off for...
33.[CST] Focus	zapit/src/capmt.cpp, zapit/src/femanager.cpp: fix warnings
34.[CST] Focus	lib/libcoolstream2/dmx_cs.h: update apollo header
35.Thilo Graf	CComponentsFrmClock: add missing init of items
36.Thilo Graf	CComponentsText: rework constructor
37.Thilo Graf	CComponentsHeader: rework context button handling
38.Thilo Graf	CComponentsPIP: use a default frame with thickness...
39.Thilo Graf	CComponentsFrmChain: add missing parameter 'parent'
40.Thilo Graf	CComponents: use neutrino debug mode for debug output
41.Thilo Graf	CMiscMenue: add entry for temporarily debug mode settings
42.svenhoefer	- yWeb: scale channellogos in channellist and epg plus
43.M. Liebmann	Fix commit ae8b6e7efcadcbe1b452fb45ea9d481ed538d30f
44.M. Liebmann	Update deutsch.locale
45.Jacek Jendrzej	dboxinfo.cpp: shov inactive rec icon, if no rec is run
46.svenhoefer	- bouqueteditor_channels.cpp: de-highlight channels...
47.Jacek Jendrzej	bouqueteditor_channels - CBEChannelWidget::paintItem...
48.Jacek Jendrzej	getservices.cpp dont add to remove not existing channel
49.Jacek Jendrzej	getservices.cpp: -fix dont replace not existing channel
50.[CST] Focus	gui/bouquetlist.cpp: another fix for bouquet epg scan...
51.[CST] Focus	gui/bouquetlist.cpp: another fix for bouquet epg scan...
52.Jacek Jendrzej	upnpbrowser.cpp fix for show pic after play
53.[CST] Focus	gui/bouquetlist.cpp: fix warning
54.[CST] Focus	gui/bouquetlist.cpp: fix crash
55.[CST] Focus	zapit/src/femanager.cpp: change free demux for PiP...
56.[CST] Focus	zapit/src/zapit.cpp: remove PIP_DEMUX usage
57.[CST] Focus	zapit/src/capmt.cpp: allocate demuxes in constructor
58.[CST] Focus	zapit/src/fastscan.cpp: fix extra InitFastscanLnb call
59.[CST] Focus	gui/movieplayer.cpp: change playback instance number
60.Jacek Jendrzej	upnpbrowser.cpp -add show logo/pic
61.[CST] Focus	driver/scanepg.cpp: add support to scan selected bouquets;
62.[CST] Focus	gui/miscsettings_menu.cpp: add option to scan epg in...
63.[CST] Focus	gui/bouquetlist.cpp: add menu option to switch bouquet...
64.[CST] Focus	zapit/src/bouquets.cpp: add bouquet flag to select...
65.[CST] Focus	neutrino.cpp: add setting to select box state for epg...
66.[CST] Focus	locals: add new locales for epg scan
67.[CST] Focus	driver/streamts.cpp: optimize poll timeout, cancel...
driver_update.zip
neutrino_update_apollo_15_04_14_1811.zip .zip
Images ze dne 27.04.2014 verze: 1810
Quellcode
1.[CST] Focus	gui/movieplayer.cpp: while starting file play, process...
2.[CST] Focus	mdev_helper.cpp: add device hotplug neutrino helper
3.[CST] Focus	gui/hdd_menu.cpp: convert to singleton;
4.[CST] Focus	locals: add locale for hdd hotplug messages
5.[CST] Focus	system/helpers.cpp: add split_config_string helper
6.[CST] Focus	driver/rcinput.cpp: add NeutrinoMessages::EVT_HOTPLUG
7.Jacek Jendrzej	make auto ScreenShot with short video
8.[CST] Focus	gui/scan_setup.cpp: set diseqc options only for satelli...
9.martii	gui/movieplayer: compare timeshift to TSHIFT_MODE_*
10.[CST] Focus	fix warnings if some want to use c++11
11.[CST] Focus	gui/movieplayer.cpp: auto-create movie thumbnail, if...
12.[CST] Focus	gui/moviebrowser.cpp: prevent title and movie info...
13.[CST] Focus	gui/record_setup.cpp: add option to auto-create movie...
14.M. Liebmann	MoviePlayer: Fix display 'info clock' and 'file time...
15.M. Liebmann	Update deutsch.locale
16.martii	gui/movieplayer: show epg info in non-movieplayer modes...
17.Jacek Jendrzej	make info copy only in timeshift mode
18.Jacek Jendrzej	nhttpd: -add Chech by marsim21
19.Jacek Jendrzej	src/neutrino.cpp -fix timer zap with mode (TV/Radio...
20.Christian Schuett	movieplayer: add possibility to show movie infos
21.Jacek Jendrzej	use auto lang only with more as 1 audio pid
22.[CST] Focus	gui/hdd_menu.cpp: fix menu, if format canceled;
23.[CST] Focus	gui/videosettings.cpp: add option to enable/disable...
24.[CST] Bas	settings: implement 23.97hz and 29.97hz video modes.
25.[CST] Bas	lib/libcoolstream2/video_cs.h: add 23.97hz and 29.97hz...
driver_update.zip
neutrino_update_apollo_27_04_14_1810.zip
Images ze dne 7.05.2014 verze: 1912
1.svenhoefer	infoviewer: only show remaining time if time is set
2.martii	gui/infoviewer: check for time being set
3.martii	locale: rename in => word.in
4.martii	gui/infoviewer, gui/eventlist: localization fixes
5.martii	gui/infoviewer: use localized value for minutes
6.martii	gui/channellist: use localized value for minutes
7.Stefan Seyfried	scan_setup: fix build without ENABLE_FASTSCAN
8.svenhoefer	- drop obsolete code around FONT_TYPE_GAMELIST
9.tomworld	Update locale
10.Stefan Seyfried	luainstance: fix wrong integer type usage
11.Stefan Seyfried	rcinput: fix invalid narrowing cast
12.M. Liebmann	Fix sort order in locales & update deutsch.locale
13.BPanther	missing lua ifdef
14.Jacek Jendrzej	-add sort option for channellist editor
15.[CST] Focus	gui/hdd_menu.cpp: add question to set record directory...
16.[CST] Focus	gui/record_setup.cpp: now, with mount/umount menu,...
17.[CST] Focus	gui/widget/menue.cpp: show right-side item icon for...
18.[CST] Focus	gui/record_setup.cpp: avoid set empty timeshift dir
19.[CST] Focus	gui/hdd_menu.cpp: add question and show format menu...
20.[CST] Focus	gui/hdd_menu.cpp: add mount point mkdir, if mdev not...
21.svenhoefer	- deutsch.locale: update
driver_update.zip
neutrino_update_apollo_07_05_14_1912.zip
Images neutrino_update_apollo_17_05_14_1702.zip
Quellcode
1.Jacek Jendrzej	gui/bedit details line osd fix
2.Thilo Graf	CComponentsText: fix fit of textbox object inside cc...
3.Thilo Graf	CComponentsItem: don't increase x/y position if frame...
4.Thilo Graf	CComponentsIconForm: consider relevant paint direction...
5.Thilo Graf	CComponents/CComponentsItem: add advanced version of...
6.Thilo Graf	CImageInfo: remove superfluous assign of footer color
7.Thilo Graf	CImageInfo: reduce font size of button
8.Thilo Graf	CFrameBuffer: add function to get icon base path
9.Thilo Graf	CBox:remove unused members
10.Thilo Graf	gui/customcolor.h: add COL_OLIVE
11.Thilo Graf	COPKGManager: use of appropriate width
12.Thilo Graf	COPKGManager: remove unused variable
13.martii	gui/keybind_setup:checkLongPress(): return true for...
14.svenhoefer	- deutsch.locale: update
15.[CST] Focus	gui/audio_setup.cpp: add option to set static volume...
16.[CST] Focus	gui/miscsettings_menu.cpp: move epg scan OFF option...
17.Jacek Jendrzej	src/gui/hdd_menu.cpp: remove '\n' for all msg
18.Jacek Jendrzej	src/gui/bedit/bouqueteditor_chanselect.cpp: fix kill...
19.Jacek Jendrzej	widget/listbox.cpp use paintButtons in foot
20.striper	- upnp browser: add menu hint
21.[CST] Focus	driver/rcinput.cpp: re-add shutdown after wakeup cancel,
driver_update.zip
update driver a neutrino - 04.06.2014
Tato verzia update je spolocna pre pristroje TANK a Trinity.
Updatuje sa zasadne iba original image CST 2.13 HD !!!
Najskor nahrajte driver_update - pomoocu USB a Menu - Sluzby - Aktualizacia sw - lokalna aktualizacia.
Po restarte mozete aktualizovat neutrino_full .
Dodrzat presne postup , prosim .
Aj v tejto verzii update je zatial nefunkcny FastScan pre skylink (CZ aj SVK) .
Vypadavanie audia cez SPDIF je mensie,ale obcas sa objavi .
* -add h265 to record and stream
Subor č. 1
:arrow:
driver_update.zip
Subor č. 2
:arrow:
neutrino_full.zip
Po aktualizacii treba prejst do nastavenia tuneru a nastavit opat vyber druzic - ako pouzivana je totiz defaultne len Astra 19,2 !. Nastavit potrebne druzice- exit , exit a zvolit volbu - nacitat zoznam kanalov.
Ostatne nastavenia, vratane doscamu) su nedotknute.
Aktivacia ecm viewer : Menu , 5 , ecmviewer - zmente sipkou vpravo na BIG.
Images neutrino_update_apollo_12_06_14_1844.zip
1.svenhoefer - eventlist: rework header
2.svenhoefer - change RenderString() default to UTF8 (vyriesena diakritika na sietovych diskoch :arrow: http://www.forum.satdigitalne.cz/viewto ... 25#p105725
3.svenhoefer - change getRenderWidth() default to UTF8
4.martii driver/fontrenderer: let RenderString() and getRenderWi...
5.martii driver/fontrenderer: adding an additional bool to Rende...
6.svenhoefer - remove unused ringbuffer code again
7.Jacek Jendrzej src/gui/eventlist.cpp -fix show channel name in search...
8.Svenhoefer - satellites.xml: update freq 12722000 as suggested...
9.Svenhoefer - setting_helpers: ensure to create flagfile to reset...
10.[CST] Focus driver/record.cpp: create record directory before record
11.Thilo Graf CComponents: fix screen rests
12.svenhoefer - filebrowser: fix paint of SMSKey in footer and ...
13.svenhoefer - filebrowser: paintFoot() at every ChangeDir()
14.martii gui/plugins: exclude unused methods
15.[CST] Focus gui/hdd_menu.cpp: ask to set recording path after mount...
16.svenhoefer - delete *.orig crap files
17.svenhoefer styling for EPG view/eventlist (patch from Benny, thank...
18.svenhoefer - helpers.cpp: add shortened strftime() function
19.Jacek Jendrzej fix to Commit 67bb4f7 (thx Gaucho316)
20.Jacek Jendrzej streaminfo2.cpp -fix bitrate calc offset and use...
21.martii gui/eventlist: fix paintItem() [patch from Benny]
22.martii gui/eventlist: utf8 rendering fix (thanks Benny!)
23.Jacek Jendrzej -add h265 to record and stream
24.svenhoefer Revert "styling for EPG view/eventlist (patch from...
25.martii styling for EPG view/eventlist (patch from Benny, thanks!)
26.martii zapit/src/zapit.cpp: simplify
27.Jacek Jendrzej /pictureviewer.cpp CPictureViewer::GetLogoName: don...
28.martii zapit/bouquets: rename bAlwaysLocked => bLockCount
29.martii zapit/bouquets: count locked bouquets a channels is...
30.Stefan Seyfried movieplayer: memset() with zero length is useless
31.Thilo Graf deutsch.locale: use capitalization for now/next button...
32.Thilo Graf CComponents: use paintBoxRel() only in kill()
33.Thilo Graf CComponents/CComponentsItem: simplify statement
34.Thilo Graf CComponentsFooter: use same corner properties like...
35.Thilo Graf CComponents/CComponentsItem: use correct background...
36.Thilo Graf CComponentsFooter: use dynamic font on too small footer...
37.Thilo Graf CComponentsButton: use darker color for Button
38.Thilo Graf CComponents: cc_base.h: expand override of is_painted...
39.Thilo Graf CComponentsHeader: add member getContextBtnObject()
40.Thilo Graf CComponentsFooter: ignore item, if no text and icon...
41.Thilo Graf CComponentsFooter: add member paintButtons()
42.Thilo Graf CComponentsForm: paint log on debug level 2 if dimensio...
43.Thilo Graf CComponentsText: add parameter for text color in member...
44.Thilo Graf CTestMenu: clean up, change some sample comments for...
45.Thilo Graf CMenuWidget: implement CComponentsFooter, remove paintB...
46.Thilo Graf CComponentsFooter: simplified dimensions init for defau...
47.Thilo Graf CComponentsButton: use y position 0 for general alignment
48.Thilo Graf CComponentsForm: fix centering of items inside form
49.Thilo Graf CComponentsForm: use variable instead function
50.Thilo Graf CComponentsButton: ensure matching icons inside button
51.Thilo Graf CComponentsButton: remove additonal y offset
52.Thilo Graf CComponentsFooter: add member to get pointer to button...
53.Thilo Graf CComponentsFooter: set color of button frames to button...
54.Thilo Graf CComponentsFooter: apply showButtonContour() after...
55.Thilo Graf CComponentsFooter: use chain object in global scope...
56.Thilo Graf CComponentsButton: add class with const char* parameter...
57.Thilo Graf CComponentsFooter: fix missing types for log output
58.Thilo Graf CComponentsButton: ignonre objects if no inititalized
59.Thilo Graf CTestMenu: set dynamic size of buttons, use 1/10 of...
60.Thilo Graf CComponentsButton, CComponentsFooter: rework bestfit...
61.Thilo Graf CComponentsButton: reinit button items after changed...
62.Thilo Graf CTestMenu: add samples for new button handling in cc...
63.Thilo Graf CTestMenu: use correct class name for footer object
64.Thilo Graf CComponentsFooter: add possibility to change font type
65.Thilo Graf CComponentsButton: add possibility to change font type...
66.Thilo Graf CComponentsButton: simplify handling of init of buttons...
67.Thilo Graf CComponentsFooter: add functionality to add button...
68.Thilo Graf CComponentsFrmChain: add possibility to use individual...
69.Thilo Graf CComponentsHeader: add icons to button collection for...
70.Thilo Graf CComponentsHeader: add missing init of icon
71.Thilo Graf COPKGManager: simplify intro items
72.Thilo Graf CComponentsHeader: remove superfluous semicolon
73.Thilo Graf CChannelList: ensure erase of clock after stopping
74.[CST] Focus gui/upnpbrowser.cpp: avoid crash, if TotalMatches is...
driver_update.zip
Update driver a neutrino pre original image CST 2.13
- drobne opravy (ecm info, aktivacia piconov kodovacich systemov atd...)
- oprava FastScan - -skylink
- rozsirena podpora prehratelnych medii - kombinacii kodekov
Najskor nahrat dirver_update.bin a az po restarte neutrino_update.bin
Po nahrani je potrebne opat nastavit tuner !!!!
Update je spolocny pre boxy Tank a Trinity .
Update neutrino 09.07.2014
Subory su spolocne pre Tank a Trinity.
Najskor nahrat driver update a az po restarte neutrino update .
driver/record: auto-terminate temporary timeshift recor...
M. Liebmann CLuaInstance::SignalBoxNew: Add 'parent' parameter...
svenhoefer - moviebrowser: prevent segfault at movies w/o channellogo
[CST] Focus gui/moviebrowser.cpp: fix off-screen draw, if OSD heigh...
[CST] Focus gui/scan_setup.cpp: add signal test menu on request
[CST] Focus gui/scan.cpp, gui/motorcontrol.cpp: increase signal...
[CST] Focus gui/network_service.cpp: add dropbear
[CST] Focus gui/network_service.cpp: change djmount charset option...
[CST] Focus gui/motorcontrol.cpp: change signal/snr layout to vertical
[CST] Focus gui/scan.cpp: change signal/snr layout to vertical
[CST] Focus neutrino.cpp: zap also with page up/page down buttons
M. Liebmann CMovieBrowser: Use CComponentsChannelLogo for display...
M. Liebmann CChannelList: Use CComponentsChannelLogo for display...
M. Liebmann CComponentsChannelLogo: disable paint of logo backgroun...
M. Liebmann CTextBox: Add Flag m_renderMode (Font::FULLBG) for...
M. Liebmann Fix sort order in english.locale
svenhoefer - neutrino_menue: add own personalize item to standby...
Thilo Graf CChannelList: disable paint of clock background, it...
Thilo Graf CComponents: implement scroll functionality into CCompo...
Thilo Graf CComponentsPicture: use current instance of CPictureViewer
Thilo Graf CComponentsForm: add functions to get first and last...
svenhoefer - osd_setup: don't show colored progress bar option...
svenhoefer - yWeb: show correct RCU at Zee²
svenhoefer - neutrinoyparser: detect Zee²; fix Boxmodel for Trinity
Christian Schuett libconfigfile: accept booleans as int32 or int64
Thilo Graf CChannelList/COsdSetup: use showOsdChanlistSetup()...
Thilo Graf CComponentsWindow: add missing comment for sidebars
Thilo Graf CComponentsForm: don't consider frame for position...
Thilo Graf CComponentsForm: add comment
Thilo Graf CComponentsItem: remove unnecessary calculation of...
Thilo Graf CComponentsPicture: structure of class highly simplified
Thilo Graf CComponents: epand method setFrameThickness() to change...
Thilo Graf CProgressWindow: implement CComponent classes
Thilo Graf CMenuWidget: add member to suppress paint of details...
Thilo Graf CComponentsText: add function to get current text conte...
Thilo Graf CComponentsForm: add methode killCCItems()
Thilo Graf CComponentsWindow: add possibilty to add sidebars in...
Thilo Graf CComponents: inherit COSDFader class
Thilo Graf CFrameBuffer: reduce fade time
Thilo Graf COSDFader: rename member functions, adapt implementations
svenhoefer - channellist: add colored progressbars
martii gui/infoviewer: remove no longer used class member...
svenhoefer - yWeb: fix MODE_RADIO/MODE keys in RCUs
[CST] Focus zapit/src/frontend.cpp: fix cable tune log
martii gui/epgview: replace left/right chars with correspondin...
[CST] Bas fastscan: fix astra1 scan in case there is only one...
[CST] Bas src/gui/streaminfo2.cpp: fix possible integer overflow...
[CST] Focus gui/luainstance.cpp: add function to start file/url...
[CST] Focus gui/movieplayer.cpp: add 'http' action key, with cut...
Neutrino update apollo 30 08 14 1826.
Quellcode
Jacek Jendrzej	- yWeb: set RangeEnd
svenhoefer	- yWeb: disable threading; there's something to fix
svenhoefer	- yWeb: try to fix empty pages
svenhoefer	- movieplayer: fix 'ask before stop temporary timeshift'
svenhoefer	- miscsettings_menu: remove double include
svenhoefer	- yWeb: link extention to new cst-public-gui-yweb.git...
svenhoefer	- yWeb: remove some links to yjogol.com; site is down
svenhoefer	- yWeb: add hddtools extention source
svenhoefer	- yWeb: add filemanager extention source
svenhoefer	- yWeb: add boxinfo extention source
svenhoefer	- nhttp: enable threading
svenhoefer	- movieplayer: ask before stop temporary timeshift
svenhoefer	- nhttp: some minor code optimizations
martii	nhttpd: extend sendfile mime types (untested)
martii	nhttpd: fix range handling
martii	nttpd: allow sendfile() to cope with files >= 2GB;...
Jacek Jendrzej	Revert "nhttpd: let sendfile() support files >= 2GB"
martii	gui/filebrowser: don't show progressbar unless director...
martii	nhttpd: let sendfile() support files >= 2GB
Thilo Graf	CProgressWindow: optimize fontsize handling
Thilo Graf	CComponentsWindow: add missing comment for allignment...
Thilo Graf	CComponentsSignals: add signal OnError
Thilo Graf	CComponents: add new header file cc_signals.h with...
Thilo Graf	configure: add libsigc++ support
M. Liebmann	Rework display LOCALE_SERVICEMENU_RELOAD_HINT message
Thilo Graf	CTextBox: fix return value of getMaxLineWidth()
[CST] Focus	gui/widget/menue.h: fix suppressDetailsLine()
Thilo Graf	CTestMenu: remove unused variables
Thilo Graf	CProgressWindow: user request: increase size of descrip...
Thilo Graf	CComponentsItem: fix percentage dimensions setters
Thilo Graf	CComponentsHeader: add methode getCaptionFont()
Thilo Graf	CProgressWindow: dont't paint frame on progressbars
M. Liebmann	Neutrino: Stop info clock when box shutdown
M. Liebmann	CLuaInstance: Add function checkMagicMask() for use...
M. Liebmann	CLuainstance: Use lua_Unsigned for color definitions
M. Liebmann	CLuainstance/cwindow.new: Add parameter for show or...
[CST] Focus	libiw/iwscan.cpp: fix crash in case of different cmd...
M. Liebmann	CUpnpBrowserGui::paintItemInfo: Set transparency for...
M. Liebmann	CLuaInstance::MenuAddItem: Add separator typ 'subhead'
M. Liebmann	CLuaInstance::CPictureNew: Add parameter 'transparent...
M. Liebmann	CComponentsPicture: Add parameter 'transparent'...
Na originál 2.13 nejdříve nahrát driver update. bin
driver_update.zip
Poté nahrát soubor prepare-apollo-cst_img-2.13
prepare-apollo-cst_img-2.13.zip
Poté nahrát soubor neutrino update apollo 30.08.14 1826
neutrino_update_apollo_30_08_14_1826.zip
Tank CST 2.15 beta ! dostupny uz aj ako online aktualizacia .
Velkost image 33,85MB .
:arrow: Tu klikni pre stiahnutie
slovencina od EnoSat :arrow: download/file.php?id=12283
Doscam v23 pre tuto verziu image :arrow: viewtopic.php?f=492&t=13461&p=106884#p106884
Coolstream Originalimage 2.15Beta z 08.01.2015
fix 8PSK , pilot HW/WS detekcia
:arrow: http://www.coolstream.to/index.php?page ... dataID=482
RCS
Příspěvek od RCS »
grantec píše:Coolstream Originalimage 2.15Beta z 08.01.2015
Bohužel nemám konto a ani se mi nedaří získat přístup na "www.coolstream.to" šlo by nějak umožnit přístup nebo přeposlat? díky RCS
Zpět na „Coolstream Tank - Images“
